Korg 01W owners: a little help
ItsMeOnly
Re: Korg 01W owners: a little help
Post by ItsMeOnly » Sat Aug 17, 2019 11:27 am
downloaded, thanks
Can you look and tell me the effect settings?
SerErris
Post by SerErris » Sat Aug 17, 2019 3:21 pm
For ease of use - here are all parameters (Pages 0-8).
SerErris
Post by SerErris » Sat Aug 17, 2019 3:23 pm
SerErris
Post by SerErris » Sat Aug 17, 2019 3:24 pm
ItsMeOnly
Post by ItsMeOnly » Fri Aug 30, 2019 8:38 pm
Behold! The fruit of your labours!
https://marcin-roguski.info/music/MOXF6 ... %20Pad.mp3
Bonus points if you tell me where the track is from :)
SerErris
Post by SerErris » Sat Aug 31, 2019 11:13 am
I have no idea where the track is from. If you have the midi, I would record the original 01/W version of that, so that you can compare it.
It sounds awesome.
ItsMeOnly
Post by ItsMeOnly » Sat Aug 31, 2019 8:16 pm
SerErris
Post by SerErris » Mon Sep 02, 2019 4:54 pm
Close, but also different. Find MP3 of Korg 01/w direct recorded without any effects (wav to mp3 by audacity/lame with 260kbit/s joint stereo variable bitrate)
ItsMeOnly
Post by ItsMeOnly » Mon Sep 02, 2019 7:16 pm
I did fiddle with several settings (as I did with on my 01R/W - still comatose btw, but I have one guy with SMD machine who will probably try and fix it for me), most notably filter envelopes (decays and depth) and key follow, plus the effects will always sound a tiny bit different, but I'm immensely satisfied with the result so far.
SerErris
Post by SerErris » Mon Sep 02, 2019 8:21 pm
I believe the biggest difference (for me) is the filter. You have it more open with the filter envelope. Maybe try to close it a little bit more and it should be good.
Remember the Filter of the 01/W is allways active (even at 100% value), as it is also trying to remove the aliasing resulting from the 33khz sample frequency. That might actually be the main difference.
Other than that, the 01/w is a little bit thicker at the bottom end, but that might be also volume which is not the same paired with the filter setting.
Also the VCA ENV is much shorter on the release on the 01/w .. but to be honest your version sounds better in it. I like the smoothness of the 01/w wich mainly comes from the filter already discussed above.
SerErris
Post by SerErris » Tue Sep 03, 2019 2:45 pm
I have another Demo for the Analog Pad Sound.. very good match :-)
SerErris
Post by SerErris » Tue Sep 03, 2019 2:48 pm
And I fell in love again with my 01/w ..
This is from the Piano Card XPC-03. Combi C67 Tutti 1
And this is a Combi I have created layering Analog Pad with some voice and choir programs ...
ItsMeOnly
Post by ItsMeOnly » Sat Sep 07, 2019 7:56 pm
mayjorblayke wrote:
Sat Sep 07, 2019 4:23 pm
Do I understand correct, that you want to have a recording of the multi sounds, correct?
Actually, thanks to SerErris I got what I needed.
