Additive synthesis? Korg Poly-800 & EX-800
Postby ranzee » Sat Mar 18, 2017 12:34 am
Watch on youtube.com
The Korg Poly-800 and EX-800 have very interesting oscillators (DCOs) - they create these cool waveforms called step waves. This allows you to turn on/off harmonics at different feet intervals. The video explains how.
Is this additive synthesis?
ranzee
Real name: Ranz
Gear: http://www.ranzs.com/gear-list/
Band: ranzee ranz
Re: Additive synthesis? Korg Poly-800 & EX-800
Postby Baus » Sat Mar 18, 2017 12:47 am
I think Additive Synthesis is based on adding Sine waves to create harmonics.
I have a Suzuki SX-500, which is basically a Siel EX-80, which is almost a copy of the Korg EX-800.
It has the same feature of adding four square waves together to create a harmonically richer sound.
I see it more as the drawbars on an organ that you pull out/push in to create a harmonically different sound.
Robin.
Baus
Postby ranzee » Sat Mar 18, 2017 2:12 am
Yeah - that really explains it nicely. I bet the old organs are where they got the idea from too!
ranzee
Real name: Ranz
Band: ranzee ranz
Postby meatballfulton » Sat Mar 18, 2017 1:10 pm
Technically it's additive but so is detuning oscillators by octaves and fifths on any synth.
The Poly 800 has no sawtooth wave and stacking up multiple squares starts to sound something like a saw but there's not really enough footages available. Even Hammond organs have nine footages (partials). Additive synths like the Kawai K5 and K5000 and the many software additive synths can stack up hundreds of partials and then apply different amplitude envelopes to them which is when additive really gets interesting.
Postby Baus » Mon Mar 20, 2017 11:51 pm
Actually I am working on the Mirage with this.
With Soundprocess it's possible to Harmonically define waveforms by adjusting the levels of the first 10 Harmonics.
The Mirage will then calculate the waveform.
Does the Poly-800 really have no saw wave? The manual states it does...or...at least says that Wave 2 is 'a close approximation of a saw wave'.
Baus
Postby mis psiquicios y yo » Tue Mar 21, 2017 2:55 am
meatballfulton wrote:Technically it's additive but so is detuning oscillators by octaves and fifths on any synth.
The Poly 800 has sawtooth wave. It only has sawtooth and square
mis psiquicos y yo
Moog Source, Emax rack, DX 7 II-9-11-100, VFX-SD, Microkorg XL, Poly 800, volcas & DotCom modular
mis psiquicios y yo
Postby ranzee » Tue Mar 21, 2017 3:44 am
Baus wrote:Actually I am working on the Mirage with this.
It isn't a true sawtooth waveform. It uses what they call a "Step Wave" - which is a bunch of harmonically stepped (in level) square waves. My video actually covers this :)
ranzee
Real name: Ranz
Band: ranzee ranz
Postby ranzee » Tue Mar 21, 2017 3:45 am
No it isn't a true sawtooth waveform - it is a harmonically stepped bundle of square waveforms - using the inverse Walsh theory. Please watch the vid ... it does cover it ;)
ranzee
Real name: Ranz
Band: ranzee ranz
Postby cornutt » Tue Mar 21, 2017 6:52 pm
It's a very crude version of something called Walsh functions, which are often used in radio signal processing but haven't gotten much use in electronic music. Walsh functions are somewhat analogous to Fourier analysis, but rely on pulse waves (of varying amplitude and duty cycle) to construct waveforms, instead of sine waves. (Walsh functions were discovered by a mathematician named Joe Walsh, not related to Joe Walsh the musician.)
The Poly-800 and EX-800 are very unusual in terms of circuit architecture. They are based on a video game tune chip that was made by Oki Semiconductor. All of the oddities of those synths (such as the lack of a proper triangle wave, and the paraphonic VCF) are due to the properties and limitations of the tune chip.
cornutt
Gear: 6th
Postby cornutt » Tue Mar 21, 2017 6:56 pm
Here's a writeup I did a few years ago:
http://sequence15.blogspot.com/2013/08/ ... works.html
cornutt
Gear: 6th
Postby ranzee » Tue Mar 21, 2017 11:09 pm
cornutt wrote:It's a very crude version of something called Walsh functions, which are often used in radio signal processing but haven't gotten much use in electronic music. Walsh functions are somewhat analogous to Fourier analysis, but rely on pulse waves (of varying amplitude and duty cycle) to construct waveforms, instead of sine waves. (Walsh functions were discovered by a mathematician named Joe Walsh, not related to Joe Walsh the musician.)
I love that article! Nice to see you are lurking around the boards still. Great work btw!
ranzee
Real name: Ranz
Band: ranzee ranz
Postby cornutt » Wed Mar 22, 2017 5:56 pm
Thanks! I've actually been around here more again lately. And I need to get Sequence 15 started back up... I've got about 10 articles queued up that I need to finish. :shock:
cornutt
Gear: 6th
Postby ranzee » Thu Mar 23, 2017 12:27 am
cornutt wrote:Thanks! I've actually been around here more again lately. And I need to get Sequence 15 started back up... I've got about 10 articles queued up that I need to finish. :shock:
Nice! If you ever need a hand :)
ranzee
Real name: Ranz
Band: ranzee ranz
Users browsing this forum: justin_havu and 1 guest
