Voltage-controlled digital oscillators?
Posted: Wed Sep 06, 2017 5:01 pm
by fh991586
What is this?
Voltage-controlled digital oscillators (VCDO) - two, each with four waveforms: saw, square, pulse 1 (25% rate), pulse 2 (10% rate). Note: Pulse 1 and 2 are similar to PMW but are fixed similar to «Aelita», «Polivoks» synthesizers for e.g. Octave ranges - 3 octaves for OSC1 and 5 octaves for OSC2.
https://ask.audio/articles/the-mbs100-i ... era-synths
How do you place this between VCO and DCO?
Re: Voltage-controlled digital oscillators?
Posted: Wed Sep 06, 2017 8:13 pm
by Solderman
I've seen a few Digital VCO modules for Eurorack, including using the CV for wavetable sweeps. Typically these are generated fully in software, but have a ADC used as an input interface to accept a CV signal at a sufficiently high sampling rate, in the range of that modular's standard. I suspect the AVP synth is similar, but is not designed with modular function in mind, so is less flexible. Fixed pulsewidth implies one CV interface, exclusive to pitch control.
Posted: Wed Sep 06, 2017 10:38 pm
by adamstan
There were also voltage controlled digital oscillators, where high-frequency VCO was used directly as a clock for the lookup table. Cymbal/hihat module from Simmons SDS-V works like this. The chain was VCO -> counter -> EPROM -> DAC.
Posted: Thu Sep 07, 2017 10:30 pm
by meatballfulton
It does seem pretty weird to control a digital oscillator from CV, but with a modular you don't have much choice 8-)
Posted: Tue Sep 12, 2017 12:24 pm
by Modulart_JP
adamstan wrote:There were also voltage controlled digital oscillators, where high-frequency VCO was used directly as a clock for the lookup table. Cymbal/hihat module from Simmons SDS-V works like this. The chain was VCO -> counter -> EPROM -> DAC.
This is how the legendary Digisound 80-21 VCDO works.
As well as our eurorack version which utilizes the same circuits and parts. ;)
Posted: Tue Sep 12, 2017 5:31 pm
by commodorejohn
Yeah, this seems like the most straightforward approach. Doesn't even need a microcontroller.
