Tonewise upgrading the SY77 to SY99 specs
Mooger5
Post by Mooger5 » Mon Jul 16, 2018 1:20 pm
I think we all know what´s this about: the SY99 has a cleaner tone than the 77.
Upon looking at the schematics, well there appears to be only one difference between these two in their output stages: one uses NJM4558 opamps while the other uses M5238 opamps. All else seems equal.
Even the DACs are the same PCM56!
So I´m going to order a bunch of 5238s. I´ll try to document the differences with some audio files.
Herrare umanum est.
Mooger5
Re: Tonewise upgrading the SY77 to SY99 specs?
Post by Mooger5 » Mon Jul 16, 2018 1:52 pm
Here are the demos by Katsunori Ujiie (musictrackjp), for reference:
I´ll add pics of the schematics later.
Herrare umanum est.
Mooger5
Post by Mooger5 » Mon Jul 16, 2018 6:19 pm
Hre´s the schematic for the L/R output stages of the SY77.
IC5 is an M5238, but it forms the dual S/H after the DAC. Just for noticing the absence of a capacitor. It´s got to be an error in the schematic. Nevertheless I´ll check it.
IC10 is another M5238 and it´s where the output stage chain begins and where the use of that opamp ends. ICs 11, 12 and 13 are all RC4558s.
Herrare umanum est.
Mooger5
Post by Mooger5 » Mon Jul 16, 2018 7:01 pm
Schematic of the SY99 L/R output stages.
Notice how both channels of IC205 share the existing capacitor. It may be the same case with the SY77 that I might have missed in the mess of crossing lines. Anyway...
Now ICs 202, 203, 204 and 209 and 268 are all M5238s!
Notice how there is one extra stage in there.
While the SY77 has one Sallen-Key module composed by IC11 to filter out at 12dB/Oct. unwanted high-content noise in the audio path, the 99 adds a second module in series for a steeper, 24dB/Oct. cut (ICs 203 and 268).
I´m guessing this extra filtering was meant as a precaution due to the much better response of the M5238 in the frequency extremes.
So, swapping the poor RC4558s for the fast M5238s may not be such a good idea. It could be that Yamaha´s engineers were being overzealous, if not a little paranoid. BUT to go to the extent of modifying the output stage to accomodate faster opamps is a sure sign an upgrade to the tone of the previous model was in their plans.
I´m therefore going to swap the RC4558s not with M5238s but with opamps designed specifically for Audio, the NE5532, which not by coincidence are my favourites. They are not as fast as the 5238, so they´ll be OK with the existing filtering in the SY77, but are Lightyears away from 4558, with a "musically informative" midrange to die for.
I have done a similar experience swapping these two ICs on a Roland D550. Anyone interested please search the forum for the relevant thread.
Herrare umanum est.
knolan
Post by knolan » Wed Jul 18, 2018 1:43 am
Thanks for the very interesting post. Deeper than my knowledge of electronics goes; but I own multiple SY77s and 99s; and know of several exquisite service engineers here in Ireland so will read your posts over a few times to gain clarity on what you've done, and download the schematics with a view to perhaps having one of my SY77's modified.
I have to admit, I do notice a slight difference in the tone of the 77 and 99 with the same programs loaded, but I wouldn't have regarded one as superior to the other; though I make no claim to have listened in any controlled way to identify differences. But - my favourite SY77 preset - Bah Mallet - does sound a tad sharper on the SY99 - but of course I slightly prefer it on the SY77 because I bought that first - so even if slightly less well defined - it's still "the original" :-)
Thanks again for a very interesting post.
Mooger5
Post by Mooger5 » Wed Jul 18, 2018 3:08 pm
Thanks Knolan.
I just got all the parts needed. Going to work on it now. Stay tuned :)
Edit - I just realized I brought five IC sockets instead of six :shock: I think I´m going to swap just the chips in the Output 1 (L+R) for now. It will be easy to compare with Output 2...
Herrare umanum est.
Mooger5
Post by Mooger5 » Wed Jul 18, 2018 4:33 pm
Solder work done. The new chips on their sockets, IC 11, 12 and 13. Not sure if you can read NE5532, but there´s the TI logo.
Now, to reassemble everything...
Herrare umanum est.
Mooger5
Post by Mooger5 » Wed Jul 18, 2018 5:44 pm
OK, the preliminary tests are disappointing. Switching between Output 1 and 2 with the effects bypassed, I´m not detecting any difference :? More to come...
Herrare umanum est.
Mooger5
Post by Mooger5 » Wed Jul 18, 2018 8:50 pm
I´ll have to look at the schematics but it appears the output routing is also done in hardware via shorting jacks. This means, yet to be confirmed, that just sending output 1 to the audio interface (for a combined outputs1+2) and alternating between volume sliders to select outputs, the signal still goes through the output 1 stages, unless a pair of dummy plugs is used on output 2. OK this sounds confusing.
Another thing that I may have not foreseen is that every stage, including the Sallen-Key filters, is unity-gain.
Just like the noise figures don´t change unless some gain is added, could it be that an opamp "signature" can only be noticed if some gain is added? Wouldn´t that mean a 741 opamp buffer could be placed after the output of a really good preamp without any perceived sonic difference? I highly doubt that :geek:
Herrare umanum est.
Mooger5
Post by Mooger5 » Wed Jul 18, 2018 10:33 pm
Just checked: slew rate remains constant regardless of gain. The RC4558 has a slew rate of 1.7V/uSec. Compare that to the slew rate of the NE5532 at 9V/uSec. It´s impossible not to see an improvement. However, the M5238 reigns supreme at 20V/uSec...
Damn this experiment started on the wrong foot by not bringing all the sockets!
I´ll have to open up the unit, put the 4558s back in place, record an audio file, open up the unit, replace all 4558s with 5532s, and more importantly, replace the display! Then record an audio file and compare.
I´ll leave it for now as I suddenly became lazy just for thinking about it. Why didn´t I try with the TG77 instead? Duh...
Herrare umanum est.
Mooger5
Post by Mooger5 » Thu Jul 19, 2018 10:35 am
Knolan, those differences you notice, is it with the FX turned off as well?
Other synths from the same period that have the clarity of sound I´m pursuing:
The Wavestation uses the 4570 and the JD800 uses - surprise surprise - the 5532!
Herrare umanum est.
Mooger5
Post by Mooger5 » Fri Jul 20, 2018 12:05 pm
This topic has already been debated at Gearslutz, two years ago. Hmm interesting forum.
No one apparently tried replacing the DAC. According to the datasheet, the 18-bit PCM61 is a direct substitute for the 16-bit PCM56.
Will it make a worthy improvement, or a big noisy mess? There´s only one way to find out...
Herrare umanum est.
Mooger5
Post by Mooger5 » Tue Jul 24, 2018 10:23 pm
There were no more 5532 left at my local suplier and couldn´t wait for the 5238 to arrive from Asia, but there were enough TL072s. So, all the opamps being 072s, except for the headphone amp, now we´re takling. A "dawn and day" difference in clarity and definition. All for less than 8 euros :D It costs less than one of those recent "boutique" opamps which miss the point IMHO. This SY77 still sounds early 90s, but much better. I don´t know what Yamaha had in mind with the 4558s, but I don´t think it was preplanned obsolescense. It were probably the bean counters that forced the team of enginneers to choose them. The 4558 isn´t really up to the task. The sound engine can do much better.
Bye.
Herrare umanum est.
baz99
Post by baz99 » Fri Jul 27, 2018 1:50 pm
Could you please rephrase your last post for laymen?
Which components (a picture would be very helpful) need to be replaced with which ones to get better output on the SY/TG77?
Thanks in advance.
Mooger5
Post by Mooger5 » Fri Jul 27, 2018 10:51 pm
Well in that photo I posted in post#7 it´s every eight-pin chip except the top one, which is closer to the output jacks. That one is the phones amp and it´s a good chip, no need to change it. So the remaining eight pin chips are three M5238s and six RC4558s. I replaced all with TL072s. They sounded good to me. They´re cheap and easy to get. Like I said, nine 072s plus nine sockets cost less than eight euros. No big deal if one doesn´t like the change, just leave the sockets in place and put the old chips back.
Herrare umanum est.
