Roland SH-2000 stopped making sound.
FatterMistanke
Post by FatterMistanke » Mon Aug 13, 2018 4:57 pm
I had just got my Roland SH-2000 up and running from some issues with some keys and a loose wire. But when i went to calibrate the tuning there just wasnt any sound coming out. i checked a multitude of cables that i know are working so it is not an issue with the cables.
It may be an issue with the output jack but since there are no other outputs on it i dont know how to test it. just before it stopped making any sound i could get some sound out of it momentaneously when i wiggled the jack cable.
The power cable is a bit dodgy but i dont know if thats it.
Please tell me if you have any clue as to what this is.
Thanks
Yekuku
Re: Roland SH-2000 stopped making sound.
Post by Yekuku » Mon Aug 13, 2018 9:06 pm
Hi and welcome aboard.
Is the switch H/M/L working right ? did you clean it?
Other than that , in the sh2000, the wire connectors usually dont make proper contact with the pins , so cleaning them is advisable.
Pin 47 on the OP-12 board is the output, use an oscilloscope or signal tracer to confirm that you have sound there.
If there is sound on that pin , the problem is on the jack or the wires that connect to the jack.
If there is not sound, the problem is more complicated.
Watch out when connecting the OP-12 connectors, they could be easily misplaced on wrong pins.
It is all about sharing...
FatterMistanke
Post by FatterMistanke » Tue Aug 14, 2018 8:39 pm
Thanks for the tips.
It ended up just being a loose connection on the jack output. i gave it some contact cleaner and it is as good as new.
