Jarre lead sound from Oxygene 8
Postby 9ichnails » Wed Nov 14, 2018 1:55 pm
Hello
I wonder how Jarre made this sound. When I listen to it I hear different echo ratio witch all notes. For example in the beginning is faster, and slower on the end of phrase. How is it done?
https://www.youtube.com/watch?v=9YzAZaPIMAI
9ichnails
Re: Jarre lead sound from Oxygene 8
Postby Z » Thu Nov 15, 2018 3:22 am
The echoes all sound in sync with tempo to me. But if you want to vary the delay time with pitch, get a delay pedal with control voltage input and feed the CV out from the keyboard to the delay.
I did something similar with the Moog MF-108M Chorus/Flanger by letting the MIDI note control the LFO speed:
https://www.youtube.com/watch?v=LNzRNnej8yc
Z
Postby 9ichnails » Thu Nov 15, 2018 10:48 am
I think this lead is monophonic because delay is only on the last note (no polyphony ?)
And here:
https://youtu.be/9YzAZaPIMAI?t=64
1:05 You can hear lower echo ratio...
And sometimes feedback is longer , sometimes shorter.
Almost all covers and replicas of this piece on YT have poor lead quality, polyphonic lead with the same echo rating synchronized with tempo.
9ichnails
Postby madtheory » Thu Nov 15, 2018 12:59 pm
It's a regular tempo synched delay. There is echo on every single note, but because it is tempo synched the notes within a phrase don't sound like they have echo on them because he mostly plays the rhythm in time with the echoes. The trick is getting the repeats to have a timbre that doesn't draw attention to itself. Jarre is probably using a pair of Revox B77, so the repeats will be duller as well as having a nice bit of tape distortion. You can get the same, identical, effect with Sound Toys Echo Boy. I can't remember the echo plugin Jarre is using these days, but IIRC he says in one interview that it has replaced the Revox rack for most things.
Band: Minim
Postby 9ichnails » Thu Dec 06, 2018 3:35 am
I think it's not really echo effect, something like i this cover:
https://www.youtube.com/watch?v=yaX7NFrkLwA
It's like 1 echo feedback direct from synthesizer
btw its most realistic cover of O8 on YT, most of cover makers use normal ping pong echo synchronized witch BMP..its not properly way :) It is magic of Jarre music design, little swing in music :)
9ichnails
Users browsing this forum: No registered users and 16 guests
