Vocal/choir patch
gstoelen
Real name: Geert
Gear: Roland Juno Alpha 2, Access Virus TI 2, Sylenth1, Komplete 12, ...
Vocal/choir patch
Post by gstoelen » Sun Mar 03, 2019 3:39 pm
Hey guys,
Looking for the machine that produced the vocal/choir type sound in this oldschool rave track (first seconds/chords of the track). Could of course be a sample-based synth..
Thanks for any feedback!
Z
Re: Vocal/choir patch
Post by Z » Sun Mar 03, 2019 4:40 pm
It's most likely a sampler. Probably an Akai or Roland S series (both used S in their model numbers of samplers).
There was a disk from the Roland S-50/550 sound library call Ooze and Oz with choir sounds like that and I could load it into my W-30 which reads S-50/550 sounds.
gstoelen
Real name: Geert
Post by gstoelen » Sun Mar 03, 2019 5:40 pm
Great, thanks! :)
Then I'm sure the choir sound in the beginning of this track can be found in pretty much the same library - it's from the same label anyway:
I'll be looking for an S-550 ;)
bionary
Post by bionary » Mon Mar 04, 2019 7:44 pm
An S-330 will work for you as well.
Post by madtheory » Fri Mar 29, 2019 10:10 am
I'm not certain but it really sounds like one of the Emulator II choirs, from the factory library.
ppg_wavecomputer
Band: ['ramp]
Post by ppg_wavecomputer » Fri Mar 29, 2019 2:16 pm
madtheory wrote:I'm not certain but it really sounds like one of the Emulator II choirs, from the factory library.
Either the EII Pompous Choir (I think that's what it was called like) or the Emax factory choir disk.
Stephen
https://ramp1.bandcamp.com/
Post by madtheory » Wed Apr 03, 2019 5:52 pm
ppg_wavecomputer wrote:the EII Pompous Choir
Yes! That's it precisely. There's a little bit of fun to be had in figuring out the chord voicing. I had to use the nose on my face to play that top F# to F etc. while also doing the octaves in the bass :) I have the EII patches in Kontakt, where it's much easier than it is on a real EII to get that big bright production sound of these tracks ;) .
It's sounds like they're also using the EII Grand Piano on the first track as well, not the Korg M1 as would be the assumption.
Autosuggestion
Post by Autosuggestion » Sun Apr 07, 2019 8:45 pm
What is the chord voicing, perchance? Thanks!
