Connecting an analog sensor to an eurorack synth
kaka
Post by kaka » Tue Mar 26, 2019 8:33 am
Hello everyone,
Is it easy to connect a standard resistive (passive) physical analog sensor to an Eurorack synth?
One needs to power the sensor and most Eurorack systems do provide a +5V rail, but is it easy to access this rail from the outside? Also, are there some impedance questions to consider?
I am mostly thinking about a position and/or pressure ribbon.
Thank you in advance.
Janis 1279
Re: Connecting an analog sensor to an eurorack synth
Post by Janis 1279 » Mon May 20, 2019 11:16 pm
Hi,
You need a some Ribbon controller for connecting from a soft pot or a pressure ribbon, I think.
As possible example for it : https://www.gearnews.com/ribbon-control ... ynthrotek/ .
There are a lot of DiY ribbon controllers schematics on the net, too. From Ian Fritz, from the Electronic peasant site
Regards,
Janis
Todd2T
Post by Todd2T » Fri Jul 19, 2019 6:51 am
The module features two input and output channels with level controls. A compact, clean-sounding analog interface for connecting a modular system.
