Roland Expansion Card Patches & JV 880
licondam
Post by licondam » Sat Apr 20, 2019 11:04 am
Just found this website in a mad search for info...
I recently purchased the SR JV 80 -98 Experience II board for my JV 880..
For the life of me I cannot access the Patches. I have read my manual and tried the "Load Patch Single and Load Patch Group" but... I get a "Parameter Not Exist" message.
ANY help would be appreciated.
Thanks
urgetoplay
Re: Roland Expansion Card Patches & JV 880
Post by urgetoplay » Sat May 11, 2019 12:03 am
Use the following procedure to load a single patch from an expansion board or
SO-PCM Card in the JV-880 :
Note: This will write over an Internal Patch in the JV-880.
1) Press UTILITY.
2) Turn the DATA dial to select Load Patch Single.
3) Cursor to the bottom left hand side and turn the DATA DIAL to select PCM
(SO-PCM Card) or EXP (Expansion Board). Use the DATA DIAL to select the Patch
number you wish to use (you may preview different Patches from this screen).
4) Press ENTER to load the Patch into the temporary memory..
5) Press UTILITY.
6) Use the DATA dial to select [Patch write].
7) Use the DATA dial to select the Internal (I) or Card (C) location where you
wish to write the Patch.
8) Press ENTER three times.
Use the following procedure to load patches from an expansion board or SO-PCM
Card in the JV-880 in groups of 64:
Note: This will write over all 64 Internal Patches in the JV-880.
1) Press UTILITY.
2) Turn the DATA dial to select Load Patch Group.
3) Cursor to the bottom line and select PCM (SO-PCM Card) or EXP (Expansion
Board).
4) Press the RIGHT CURSOR button and select the desired group of patches to
load (i.e. 1st 64, 2nd 64, etc.). The number of patches will vary depending on
the Expansion Board or PCM Card.
4) Press ENTER to load the Patches.
5) The Patches are now in the I-Bank of your JV-880.
Note: The original “Internal” sounds can be brought back by re-initializing the
JV-880.
Resonance in Humans is called Empathy.
