poorly MKS70 - not sure what's up with it, MIDI fault?
squatski
Post by squatski » Mon Jun 15, 2020 12:18 am
So I know I probably won't get a reply soon because forums are so quiet now but it's worth a shot
OK SO! I managed to win an mks70 off ebay. There was a picture of it on showing the version so I though, yeah this should ok.
Had it for a week and it sounds a bit 'circuit bent' without actually being circuit bent. So the firmware turned out to be the notorious old as h**l version 1.0 or.. I can't remember
anyway I bought the v.06 / v.06 / v.08 chips. so that's v.08 for the main board and 2 x v.06 for the JXP8 boards (as I call them hah!)
DIDN'T fix the issue. I'll have to do an audio demo, sometimes you can press 6 keys on your MIDI keyboard and the 6th one will have this circuit bend noise. It's quite a cool noise that I've already sampled but I'd rather have a working mks70 seeing as I paid a c**p ton of money for it.
Would could the problem be.
I even sysex'd over the original bank presets to it and it still sounded messed up... the classic electric piano sound of patch A:1, you have like dips in sound level on some notes, and there a really harsh noise.
When I got the mks70, one of the previous owners had actually left a load of expletive message on the patches which at first I thought was pretty amusing (I won't repeat them here) but I can't help feeling they were put on there out of frustration this mks is damaged beyond repair which worries me!
ohwell, at least I got a pg800 for a ripoff price haha :roll:
I'll post up some sound example soon, it MAY just be that something is setup wrong.....y'know with the whole dual mode/xfade/this that and the other........
Mesmerised
Real name: Chris
Gear: Minimoog, ELKA Rhapsody, MFOS Modular, Matrix 1000, K5000S, MI Ambika, Shruthi (3x) and Anushri, Sonic Potions LXR, JX-8P, D-50, ...
Re: poorly MKS70 - not sure what's up with it, MIDI fault?
Post by Mesmerised » Tue Jun 16, 2020 10:50 am
Does not sound like a setup error to me. Possibly a broken voice on one of the boards. Can you tell if the erroneous sound comes from one of the boards (upper OR lower, or both)?
I would try to isolate the voice - maybe there's a test mode? (get the service manual...)
Good luck!
squatski
Post by squatski » Tue Jun 16, 2020 1:11 pm
test on saw wave, newest firmware 1.08 but was the same on the old eproms.
ALWAYS:
10 normal notes ( - )
1 dead note ( x )
1 weird ringmoddy sounding note (r)
sometimes different variation across the keyboard like
- - - x r - - - - - - -
- - - - - - - x r - - -
- x r - - - - - - - - -
you get the picture, the 2 odd ones are always together.
squatski
Post by squatski » Tue Jun 16, 2020 1:23 pm
ok turns out they're not always together, on this example it's:
- x - r - -
on a 6 note sequence.
also there's a h**l a lot of mains 50hz hum coming out the mks mix out, not so bad on the A / B outs
squatski
Post by squatski » Tue Jun 16, 2020 1:28 pm
and for something extra freaky...
it's in the background quite faint I had to turn it up a lot.
Mesmerised
Real name: Chris
Post by Mesmerised » Sat Jun 20, 2020 10:37 am
Seems like you have two broken voices (2 out of 12). In 12 voice poly mode the assigner plays them in rotary fashion, that's why the patterns/keys are like that.
There is a test mode where you can find out, which voices on which board these are.
It's in the service manual. (Hold "write" during power up for test mode 1)
I can't attach the manual here but you should be able to find it online.
You might need a repair shop, looks like an issue not easy to fix.
