Guitar Pedals and Synths
in what order would you connect the pedals?
Chorus-Delay-Reverb
6
86%
Reverb-Delay-Chorus
0
No votes
Delay-Chorus-Reverb
1
14%
Other
0
No votes
Total votes: 7
JotaSotodiaz
Post by JotaSotodiaz » Wed Jun 17, 2020 8:42 pm
Hyde
Real name: Hyde
Gear: ASR10
EPS16
EPS
Mirage
S2000
ESI2000
SY35
SQ1+
K1000
K2000rs
Band: When Violets Turn Grey
Re: Guitar Pedals and Synths
Post by Hyde » Fri Jun 19, 2020 4:14 am
Delay & Reverb are essentially very close to the same thing. In guitar I always have delay before reverb. Just in case they are both lit up, the delay generally is better off there. I don't run chorus but I'd probably place it first in line. If you are running stereo chorus, well, last. & probably not run Reverb at the same time. Of course, with synths, effect is generally the point. So, experimentation might just be your best bet.
Post by meatballfulton » Fri Jun 19, 2020 11:05 pm
Reverb always last because it's function is to emulate the sound of a real acoustic environment. Chorus and delay, not so much.
bigbear
Real name: Jon
Gear: A-100, MS20, Microkorg, SQ1, S950, DM5, SR16, SY35, BassStation2, Microfreak, Beatstep Pro, Model D, Guitars, Effects pedals, LostVolts Theremin.
Band: Drumbeg
Post by bigbear » Wed Jul 15, 2020 10:32 am
I use literally dozens of guitar pedals. I have a 19 pedal board that I use as my main live rig on guitar, plus chorus, phaser, Whammy, octaver, Big Muff, analogue and digital delay, plus two different reverb pedals on synths. I've also got an envelope follower wah, fuzz and foot volume on my electric piano. As well as all of this, I have a MEL9 pedal to thicken up strings, etc., and a Ravish sitar pedal to make anything sound 'Eastern'. Using pedals to alter normal synth sounds is one of the creative bits I like best, in fact! My pedal board is connected in the folowing order: autowah, sitar pedal, compressor, whammy, MEL9, fuzz, wah, phaser, flanger, chorus, tremelo, foot volume, analogue delay, digital delay 1, digital delay 2, channel selector, Amp simulator, reverb 1, (spring), Reverb 2 (digital). The separate outputs from MEL9, Sitar, and the spring and digital reverbs all go to a mini mixer and then on to a stereo input on the main mixer. I also use a packed lunch for use while I walk around the pedal board.
squatski
Post by squatski » Wed Jul 15, 2020 1:55 pm
I have over 25 years experience with audio
Delay chorus reverb is the secret combination. Why? well, I could tell you this secret but I'd have to kill you :lol:
squatski
Post by squatski » Wed Jul 15, 2020 1:58 pm
oh I assume we're talking mono delay only? in that case Chorus-Delay-Reverb is acceptable.
