Roland D-10 Battery
slash49
Roland D-10 Battery
Post by slash49 » Sun Jun 21, 2020 2:04 pm
I have a Roland D-10 that hasn't been used for a long time and was bought new in the late 80s?
Just turned it on and it works ok but every time I change patch, it informs me that the internal battery needs replacing. I am quite capable of doing this but I have the following questions.
Will disconnecting the battery remove the sounds even if I do it quickly. Was wondering if there is some capacitance in the circuit which would keep it going till I put the replacement in.
If I leave the power on, will that help (yes I know I shouldn't)
Can I use bandlab or other cheap software to backup all the date and reinstall it when the replacement has been done.
I don want to lose the use of it even though its over 20 years old
Thnks for reading
Re: Roland D-10 Battery
Post by meatballfulton » Sun Jun 21, 2020 10:51 pm
Yes, you need to do a full dump of all the data before replacing the battery. Read the section in the manual about doing dumps over MIDI to your computer.
Programs for MIDI dumps:
Windows MIDI-OX
Mac SysEx Librarian
slash49
Post by slash49 » Tue Jun 30, 2020 9:43 pm
Thanks for the reply.
From you message, I assume that while the power is on, changing the battery quickly ( 30 secs) will still not keep the sounds.
Post by meatballfulton » Tue Jun 30, 2020 11:55 pm
Better to be safe than sorry. Do a backup. The software I linked is free.
