Novation K-Station: Tremolo ?
Posted: Tue Sep 01, 2020 10:02 am
by bibenu
I thought this would be simple, but I can't find an answer through experimentation or the manual.
Is there a way to get tremolo (amplitude modulation by LFO) from a K-Station ?
I can't find a routing either on the front-panel or through the various menus ... not even via the wheels menu. The only possible option I can see is to treat the synth as mono and use the panning effect.
Any ideas ? Surely this wasn't omitted and it's just I can't find it ?
EDIT: I'm talking about the hardware synth with keyboard and version number 2.1 .
Re: Novation K-Station: Tremolo ?
Posted: Tue Sep 01, 2020 12:34 pm
by meatballfulton
From the user manual, it appears there is no way to route the LFOs to the amp stage. So, panning tremelo is your only option. It will probably sound terrible collapsing stereo to mono :?
Posted: Tue Sep 01, 2020 10:47 pm
by V301H
VCA Modulation can be a useful feature for creating various repeat effects including Tremolo. With a full-featured LFO you can use Sine/Triangle, Square, Sawtooth/Reverse-Sawtooth, or S&H for interesting cycling effects. To simulate Tremolo without VCA Modulation you might try Pulse-Width Modulation using an LFO Sine or Triangle wave and adjust the Pulse-Width of a Square wave so it's amplitude fluctuates with each cycle.
Posted: Wed Sep 02, 2020 1:44 pm
by bibenu
To simulate Tremolo without VCA Modulation you might try Pulse-Width Modulation using an LFO ...
Thanks, I'll keep that in mind. Unfortunately it's applicable to the sound I was thinking of ... sort of piano-like but with a little movement. Vibrato was OTT, so I thought Tremolo would suit ... that's how I discovered this really strange omission from the K-Station.
I mean ... it's not like I'm looking for something really obscure or difficult like multi-tap delay or something ... AM by LFO should be part of the basics. :?
Posted: Wed Sep 02, 2020 5:52 pm
by meatballfulton
You might be surprised how many prized older synths don't support any kind of amplitude modulation.
SH-101 and Junos, for instance. The ARP Odyssey only allowed it via the EG retrigger feature. By the 1990s AM was pretty commonplace, but still not all synths had it.
Even today's Korg Minilogue and Moog Sub Phatty don't allow LFO modulation of amplitude.
Posted: Thu Sep 03, 2020 2:07 am
by V301H
None of the original Sequential Circuits Prophets have VCA Modulation which is surprising since these were high-end Synths. I have had a Pro-One since it was new and didn't notice this until I got a Prophet 5 and wanted to do a repeat effect. The Pro-One does have a dedicated Repeat as does the ARP Odyssey but both sound like a square wave. The Minimoog Model D also lacks this capability as well as other functions that are now common.
Posted: Thu Sep 03, 2020 10:04 am
by SciNote
When I was shopping for a synth recently, I noticed that even the new Korg Minilogue XD doesn't appear to have the ability to have the LFO modulate the amp, either.
Posted: Thu Sep 03, 2020 1:48 pm
by bibenu
I'm mystified.
So are we saying it's still not a commonplace thing ?
I guess that might mean it's a thing that not many people want ? (And that I'm the odd one out ?)
Posted: Thu Sep 03, 2020 2:11 pm
by SciNote
Have you tried using the LFO to modulate the filter? Sure, if it's done to excess, you'll get a wah-wah effect that you may not want with a piano sound, but done subtly, it might give you the effect you want.
Posted: Thu Sep 03, 2020 2:24 pm
by meatballfulton
No, plenty of people want it but some designers leave it out.
Posted: Thu Sep 03, 2020 2:52 pm
by bibenu
That's a really good idea ... I'll try it.
Posted: Sat Sep 05, 2020 1:10 pm
by bibenu
Because the particular problem I was addressing was a sound that was not terribly rich harmonically, this worked a treat ... it was pretty nearly just AM by LFO. Thanks :D
Posted: Mon Sep 07, 2020 5:56 am
by SciNote
Hey, great! Thanks for the update, and I'm glad that worked for you. Sometimes you can sort of "bend the rules" or go about an alternate route to get to the sound that you're looking for.
Posted: Thu Sep 10, 2020 3:21 pm
by bibenu
Hah .... build-it-yourself £100 synth with no filter envelope ... yet has tremolo.
