What does it take to re-create the Roland VP-330 "human voice" sounds with a synth of some kind?
I managed to re-create the "Strings" using a Roland MKS-50 using a single sawtooth waveform and fiddling with the filter. This gave me the basic sound, but of course the thing that makes the VP-330 so special is its "ensemble" effect. So recently I bought the XILS Chor'x ensemble plugin which so far (at least to me) has the most convincing VP-330 ensemble effect. That plugin together with the simple MKS-50 tone resulted in something close enough for the strings.
I suspect the human voice sounds (Male 8, Male 4, Female 4) rely on some sort of special filter that isn't found on most regular synths, or is it just a matter of programming things right?
VP-330 "Human voice" synth recreation?
- ppg_wavecomputer
- Expert Member
- Gear: more keys than hands (and feet)
- Band: ['ramp]
- Location: teutoburg forest, eastern westphalia, germany
Re: VP-330 "Human voice" synth recreation?
Multiple bandpass filters and a nice-sounding BBD chorus (preferably based around Reticon SAD1024A or Panasonic MN3005).
Stephen
Stephen
https://ramp1.bandcamp.com/
Thanks for the suggestion.
That XILS Chor'X plugin works for me (instead of having to buy/build a hardware variant).
Please explain about the multiple bandpass filters as I'm not familiar with them.
Is it fair to assume that it's based on a very simple sound source (i.e. a sawtooth as with the strings sound) and like you say, multiple filters after that, to shape it into the end result?
- ppg_wavecomputer
- Expert Member
- Band: ['ramp]
Exactly -- the VP-330 is based on some simple waveform like sawtooth or pulse-wave (I don't have the schematics around but maybe someone else does to shed some light?).
This simple waveform is filtered, using multiple resonating formants that resemble the human mouth cavity and speech apparatus.
The resulting sound is still a bit bland and not really interesting, and this where Roland's own BBD chorus comes into play.
Stephen
Yes, the ensemble effect is definitely what makes things interesting!
Do you have any suggestion as to how to set up the various resonant filters and how many? I was thinking I'd use one of the many filter plugins available along with the mentioned ensemble plugin after feeding a hardware synth (probably my Roland MKS-50 or MKS-70) into the DAW.
I find those synths easy to work with and I suppose analog is the way to go.
