What's the worst synth ever made?
AstroDan
Post by AstroDan » Sat Aug 04, 2007 2:30 am
I don't think anyone can truly appreciate the level of despair of being in a band for two years with someone who refuses to purchase or play anything other than a Roland XP-10 fed through a shitty p.a.
So that one gets my vote.
Too futurist to live.
differentbydesign
Post by differentbydesign » Sat Aug 04, 2007 1:56 pm
teknosmoker wrote:
differentbydesign wrote: You mis understand what i said but i thank you for insulting my programing ability based on nothing!
Uh......No need to get defensive there pal...
I never insinuated that you had poor programming ability. I simply stated that I believe people who fail to get a warm sound out of a JP-6 may not know how to program it well and cited an example of an excellent job that a forum member made demonstrating this point.
Dude sorry it seems it bit back a bit hard there I am used to another forum where every second posting is an attack on someone and you learn to get defensive1
Peace
Ross
UF6, Pro 2K, 6 Tracks, SQR, DX-9, JV-880, JV-1080, MKS-70 , NI FM-7&8,Battery 3,Pro53,Absynth 4 Arturia MOOG Modular,2600V,CS-80 V, Minimoog V, Legacy Collection, RGC Pentagon,VirSyn Tera, Sonar 6.2, , Synth 1, MOTU Microlite, D-70, RX-11,Roland MC-500
Analogue Crazy
Real name: Rob
Gear: Alesis Andromeda
Korg MS20 Mini
Korg Micro Preset
Korg DS-8
Yamaha Motif 7
Yamaha DX11
Post by Analogue Crazy » Sat Aug 04, 2007 3:17 pm
Yamaha SK-10
A6 Andromeda, MS20 Mini, M500SP, DS-8, Motif 7, DX11,
teknosmoker
Post by teknosmoker » Sat Aug 04, 2007 5:09 pm
differentbydesign wrote: Dude sorry it seems it bit back a bit hard there I am used to another forum where every second posting is an attack on someone and you learn to get defensive1
Peace
Ross
No worries - it's all good! Sorry if it came across as such. I can understand your apprehension, as know that there are a ton of forums in which members get torn to shreds by trolls and people with ill-intent. I think that for the most part the members of VSE forums are just a bunch of friendly synth nerds looking to chat about our common interests, ask for advice, and help each other out. :)
Shanti,
Alex
TR-909, SH-101, Jupiter-6, Juno 106, ATC-Xi, Microwave 1, FS1R, TX81Z, Odyssey, K2000, Wavestation A/D, E6400 Ultra, MPC 2000XL, Mutator, MF-101, MF-103, Frostwave Resonator, DSP7000, PCM-91, Fireworx, D-Two, DP/4+, MacPro Quad, Logic Pro.
zmd
Gear: ion, djx, su200, fb01, sk50d, dotcom, kodyssey, volcas, minibrute, minilogue, tg33, 522, streichfett, monotrons, cp35
Band: Shrimp ring/usse/wrote/usurper
Post by zmd » Sat Aug 04, 2007 7:41 pm
Analogue Crazy wrote:Yamaha SK-10
an sk10? not familiar with that one..but, i'll submit the yamaha FB01 as the worst synth ever. its FM. its non programable aside from a few basic parameters, it sounds like the very definition of cheese (in fact, preset 14 in bank 3...if you hold down a C0, it actually pronounces the word "cheese").
of course, i'll never part with it. what else would i turn to to end rehearsals when the band members insist on jamming out blues in E for an extra 45 minutes... an FB01'll stop em everytime!
tallowwaters
Gear: LC-MS/MS
Post by tallowwaters » Sat Aug 04, 2007 7:50 pm
godmcgarvey wrote:
Pretentious bullshit
try being nicer.
nathanscribe
Post by nathanscribe » Sat Aug 04, 2007 10:51 pm
OriginalJambo wrote:[Remember the Juno has that bass boost circuit...
What, you mean the Sub Osc?
Joey
Band: BLUSH_RESPONSE
Post by Joey » Sun Aug 05, 2007 1:02 am
No, there is a built in Bass Boost circuit on the circuit board. You cant turn it on or off, its just there.
http://wearereplicants.com
OriginalJambo
Gear: Check my sig
Post by OriginalJambo » Sun Aug 05, 2007 2:15 am
Apparently there is a circuit inside the Juno that boosts the bass a bit probably before the output stage to give a more powerful low-end - as Joey pointed out.
Maybe it's not true but I've heard people refer to it before.
nathanscribe
Post by nathanscribe » Sun Aug 05, 2007 10:48 am
Which Juno are we talking about?
BadTeeth
Post by BadTeeth » Sun Aug 05, 2007 11:01 am
I know that if you set the HPF to zero its boosts the base. ie, its not filtering but rather boosting. Is that what you are talking about?
ROFLMAO
OriginalJambo
Gear: Check my sig
Post by OriginalJambo » Sun Aug 05, 2007 11:48 am
nathanscribe wrote:Which Juno are we talking about?
The 6 at the very least (probably the 60 too although the high-pass filter isn't as smooth in that I hear...just four states?) and what BadTeeth said sounds very accurate actually.
Analogue Crazy
Real name: Rob
Korg MS20 Mini
Korg Micro Preset
Korg DS-8
Yamaha Motif 7
Yamaha DX11
Post by Analogue Crazy » Sun Aug 05, 2007 11:59 am
I have played the Juno-6 and Juno-60 and they have the same amount of power in the bass sounds. The HPF is not as nice on the 60 though. It has just 4 settings instead of being a proper slider. Apparently its because they ran out of prosessing power.
nathanscribe
Post by nathanscribe » Sun Aug 05, 2007 4:22 pm
No offence, but this strikes me as the kind of thing born of rumour and misinterpretation. The Juno HPF is a single-pole, OTA circuit which should not boost anything. At its lowest setting, it should simply not cut frequencies. There's no indication in the circuit otherwise, nor have I ever considered this in 16 years of Juno use.
Of course, I might be wrong, and maybe there's some inherent characteristic of the circuit design at various points that acts to this effect, but from what I can see it's not a designed-in feature of the HPF to boost the low frequencies. I'll remain sceptical until someone can prove the contrary.
In practice, I don't find the 60's stepped HPF much of an issue over the constantly variable one on the 6. It's still useful enough. The improved interfacing more than compensates.
Shleed
Real name: Ashley Dolan
Gear: Doepfer A100
MFB Synth II
Korg MS20 Mini
Ensoniq EPS-16+
TT303
TX81Z
Band: Shledge
Post by Shleed » Sun Aug 05, 2007 6:04 pm
It would only boost bass frequencies if the resonance was put up high...
