Hardware FM or FM8 softsynth?
Soundwave
Post by Soundwave » Mon Jul 23, 2007 10:59 am
23 wrote: Formant sequencing on the FS did get fully resolved, however, it was third parties, and not Yamaha, that picked the ball up running. There's TONS of frames that hit up into a formant sequence, and ultimately, a lot of times it ultimately became as simple as sample something, have the sample anaylyzed, and then proceed to convert it into a formant sequence from there. It was this part of the process that Yamaha asssured to complete but never did.....ultimately, this part of the process did get completed.
In this regard, not only is a good amount of paramaters missing from the screenshots of an editor that were given here, but not a single screenshot in regard to the detailed workings of formant sequence creation were offered.
Again, if one were to fuse each unvoiced op with it's corresponding voiced op, thus making for an 8 OP FM piece, the amount of waveforms each OP is capable of heads way beyond the hundreds....in all honesty, I wouldn't shy away from saying thousands.
The closest thing I know to compare it to would be the Supernova's wave generation system. Where on the surface, you only had Pulse, Saw, and Dual Saw available, which was in and of itself fairly limiting. But then throw into account that Sine waves were actually there for example, but they required that the hardness paramater on a square wave be applied harshly. Pretty much, once not only the fact that each osc could independently serve as it's own master and slave osc, but factors like Sync Skew and Hardness were factored in as well, it quickly became evident that the amount of waves each Osc was capable of independently generating was actually FAR FAR FAR beyond the norm and not at all limited to the 3 waveform range it looked like on the surface.
This same type of outlook truly should be applied to the FS.
The trouble with the FS didn't come in capability. The thing was, and years later still is, pretty much unparalleled in regard to it's capabilities; HOWEVER, I'd almost go as far to say that it was not "A" programing nightmare, but that it was "THE" programming nightmare. Going from the Front Panel, fact of the matter was NOT every paramater was accessible (yes, even with all the menu diving) and at that, what was available was a nightmare to deal with. Further, the way things ultimately rolled out, there literally were two FULLY FEATURED editors that were developed for it. One for it's Fseq capabilities, and another for everything else. Both Editors, as I said, were fully featured, it wasn't as if one was a light handed editor....both were pretty darn indepth. Even if the two editors were to be combined, at the end of the day was you'd end up with even an editor that was so darn indepth/complex that it itself wouldn't exactly be immediately user friendly.
Ultimately, what did the FS1R result in? I really don't know what to compare it to as there simply hasn't really been anything commercially released that has it's abilities. I mean one really could squeeze some things out of it that would liken many to comparing the results to K2000/5000 additive like results, still other things screamed WaveStation Wave Sequence like results, still others more (Waldorf) Wavetable like results, other things threw out the notion of it being some weird sort of vocoder (I'm speaking in terms of result, as of course it had no external input), but then of course there was the more traditional FM like results that could be reached.
Realistic choir voices could be morphed in ways that screamed some sort of Additive process must be going on. Beats and rhythms could be rolled out that all remained in sync regardless of key played (unlike on the wavestation) screaming Wave sequence. The voice of some man clearly speaking into a hand held radio could be accomplished.....but is that a man? because how is that being morphed into a woman? Really all sorts of crazy and quite odd things. Number of things that would have one swearing samples were having to enter into the fray somewhere along the line (like I said, i.e. some guy talking). But of course analog type basses and leads, and crystalline bells also quite possible to accomplish.
TONS of capabilbilty, but like I said, all lying behind what may quite possibly be looked at as "The" programming nightmare.
I'll hit up a demo of the FS some time. Trust me, getting it to go not just a couple steps, but FAR beyond the capabilities of other FM based synths can quickly be shown.
:shock: OMG I did not know this, no wonder they shot up in value a little while back!
Virsyn are doing some similar stuff with formant and complex additive wave sequencing probably inspired by the FS1R. I'm not sure exactly how they compare tho and I would probably favour a dedicated softsynth rather than a 1u rack and software editor but I'm still very intrigued (must resist the GAS :x ).
One other thing in the FM7’s corner apart from the ease of programming is the ability to stack as many voices as your CPU will allow resulting in some very ‘BIG’ FM tones.
SYNbiotic
Post by SYNbiotic » Mon Aug 06, 2007 7:46 pm
Thanks for the advice. The FS1r is so temping. The only thing that's really holding me back is the software editor that's availible for it (PC format)...
http://www4.airnet.ne.jp/k_take/fs1r_ed ... glish.html
For those that have used it, does it support real-time MIDI control editing? This is the deal-breaker for me... I need the editor to react to real-time MIDI input through a knob box, just like how FM8 would behave.
Mr Physician
Post by Mr Physician » Mon Aug 27, 2007 2:13 am
i heard that fm8 is pretty nice, plus it has an arpeggiator, which the original dx7 lacked (i use arpeggiators a ton, so this is a positive for me). i'm trying to find and fs1r, anyone have any suggestions? preferably cheap -- ebay doesn't have them, since last i checked. also, what programs can you hook fm8 to?
Yoozer
Re: Hardware FM or FM8 softsynth?
Post by Yoozer » Mon Aug 27, 2007 5:44 am
Mr Physician wrote:also, what programs can you hook fm8 to?
Anything supporting VST, RTAS or DirectX. (so anything, really).
synthetic88
Post by synthetic88 » Mon Aug 27, 2007 5:48 am
My TX802 sounds much nicer than FM8. It sounds 3D, where FM8 is 2D or 1/2D. I got the plug-in with Komplete and played with it for 10 minutes, haven't launched it since. Plus, the hardware is cheaper and holds its value. And you can easily run it through a filter or stomp box for even more fun. Go for the hardware. Software usually disappoints in the synth department.
Andromeda • Voyager • Super Jupiter + Programmer • TX-802 • Two GigaStudio PCs
http://www.jefflaity.com/studio
Mr Physician
Post by Mr Physician » Mon Aug 27, 2007 6:10 am
hmm, so RTAS is used for ProTools (boo!), VST is primarily Cubase (yay!), what programs use DirectX? I use primarily Reason and Ableton Live and I'll start using Cubase again when I decide to shell out the money for the upgrade from my old version. Besides Cubase, can I use FM8 with Reason or Live directly? Preferably Reason, as I mainly use Live as a sequencer, but can I?
route_electrique
Gear: Clavia Nordlead 2 | Clavia Nord Modular G1 | Waldorf Microwave XT (30 Voice) |
Band: waveformbakery
Post by route_electrique » Mon Aug 27, 2007 7:21 am
Depends what you are after and on the other gear you have in the studio. If sound quality is important to you and you plenty of high quality FX is available, then go for TX-802 or FS1R. I'm not that impressed about NI stuff.
| Fact is, your are going to get bent over by a Record Company..... its just how far, how long and if you let them decide to use vaseline or not." -Unknown |
_
http://www.waveformbakery.com [coming in Q3!]
CS_TBL
Gear: All "In-The-Box"
Mainly FM8
Post by CS_TBL » Mon Aug 27, 2007 10:45 am
Can someone record just one or two notes from a so called better sounding FM synth than FM8? Then I'd like to try to recreate that sound in FM8 and see how bad things actually are..
Just some simple bass with 2 sine ops and one feedback on [2] or so (the most basic FM model so to say).
Code: Select all
/FB\
\->[2]->[1]
FM8 vids
JUGEL
No Longer Registered
Post by JUGEL » Mon Aug 27, 2007 6:27 pm
I'd just love to hear what you guys do with FM ... because I haven't been to impressed with clavs, horns and rhodes..
got anything with some edge? pretty please? I want to get into FM but it's scary...
Synthaholic
Post by Synthaholic » Mon Aug 27, 2007 6:51 pm
My last foray into FM was (shudder) programming patches on the OPL2 chip on old SoundBlaster cards (around 1992 or so). Back then I thought it was pretty cool what it could do, but that was before I discovered "real" synths.
I'd love to get back into FM programming. Just don't know whether to pick up some hardware (DX, TX, or what have you) or software (FM8).
I've dabbled with the limited FM capability on the Microkorg, but I know it's as limited as the OPL if not moreso for FM.
Mr Physician
Post by Mr Physician » Mon Aug 27, 2007 7:34 pm
JUGEL wrote:I'd just love to hear what you guys do with FM ... because I haven't been to impressed with clavs, horns and rhodes..
check out the french producer kavinsky, especially his song testarossa autodrive. his stuff his incredibly electro/house and eighties throw back.
whiteyhouston
Post by whiteyhouston » Mon Aug 27, 2007 7:42 pm
80's basses and clanky arpeggiated patches are what I use FM8 for..
and other oddball stuff... but I never bother to try and emulate bells or electric piano.. never does it for me and sounds really dated.
I sold my DX7 because it was next to useless for my needs.. and I hate menu diving...
that Kavinsky track is merciless
john909kid
Post by john909kid » Mon Aug 27, 2007 9:00 pm
I'd never heard of Kavinsky so I checked out his myspace page. Really nice driving '80s synths and electro fuelled beats. Like it lots.
A quick net search seems to show he's using Logic and FM7.
Nice stuff
CS_TBL
Mainly FM8
Post by CS_TBL » Mon Aug 27, 2007 9:48 pm
There's always the listening lounge no-one ever visits.. *click*
FM8 vids
