new analog monosynth?
- Real name: Ste
- Gear: ms 20 mini ,sq1,,tr33, Gibson 330,Gibson sg,fender deluxe reverb vermona mono lancet,melodica,various and copious effects pedals,jx3p
- Band: Stockholme Syndrome
so theres gonna be a new analog poly from dave smith?Great news!But how about a mono version?Personally i'd love one.Fair enough i could buy a pro one of ebay but couldn't justify /afford the upkeep.As for the mono he has out at the minute,respect but i dont need digital oscs,seq,memory. leave these off, sell a bit cheaper.SORTED
- johans121
- Gear: Pro One - PEK - Juno60 - 606 - 777 - MOTM format Modular... and Lots of Effects ‘n stuff analog & digital
- Band: Dreams of Psyche
Perhaps you could have titled this thread,
"Where is the DSI Mon08?"
As for your comment, "i dont need digital oscs,seq,memory. leave these off,
sell a bit cheaper". I'm assuming you meant DCO's and not digital oscillators.
Why don't you just go and purchase an MFB synth and be done with it? Or, when DSI releases their new VCO mono you can pawn the MFB.
Or you can purchase the new MacBeth that will be released some time in the future (not specifying whether that future is near of far).
-Jim
-Jim
Don't feed me Indian, you WILL regret it!
I doubt knocking off a bunch of features in the MEK would result in a considerably cheaper mono, especially if those features are the digital components which are cheap. Unless you knock out all the digital components, and hence the need for ROMs it probably wouldn't be any cheaper at all. If you did that you'd need to put analog lfos and mod routings in which would increase the price.
Q, Pulse, MW1, CS60, MEK,
- OriginalJambo
- Gear: Check my sig
Re: new analog monosynth?
The Little Phatty's worth a look. The Stage edition should be slightly cheaper than the MEK.Factory all stars wrote:i dont need digital oscs,seq,memory. leave these off, sell a bit cheaper.SORTED
Yes, yes, yes the MEK can do much more...we know all this. But the LP is simple, effective and most of all fun.
If you want a modern analogue mono that sounds great and has the bulk of the cost going straight into build quality, sound quality and not features that you don't need (sequencers, effects etc.) then it might be worth a shot.
I demoed the MEK when I went into Sound Control and asked for "vintage analogue" and I wasn't impressed with the analogue side of things and found getting basic leads and basses a bit cumbersome. With the LP it's a snap simply because you aren't bogged down with features. It's a winner in that respect.
- Real name: Ste
- Gear: Voyager Select,Little Phatty,ARP Solus,Omni II,Yamaha CS-40M,Prophet 5,Prophet 08,OB-Xa,MaxiKorg,Nord Lead 3,Nord Wave,Eurorack modular, etc.
New Order didn't use the Pro-One too much. The Source was used for its thick bass tones, i.e the bass in Blue Monday. Otherwise the mono sounds you hear in Movement, PC&L, etc. is mostly ARP (Quadra) and Voyetra 8 which was used in unison mode a lot. If you really dig those sounds, then pick up an ARP Solus or a Pro One would work. OR get a MEK which rules for those early New Order sounds!Factory all stars wrote:Good evening!The sort of sounds i have in my head lean towards early new order who i know used among other synths,the pro one and moog source.I've nothing against moog but i just think the sound is too recognisable if that makes any sense[probably not]CHEERS!
Here you go... new monosynth back from the dead:
http://matrixsynth.blogspot.com/2007/08 ... sizer.html
