1 osc synth with seperate VCA ADSR and Filter ADSR?
JSRockit
Post by JSRockit » Fri Nov 16, 2007 7:12 pm
Is there such a thing?
Soundwave
Post by Soundwave » Fri Nov 16, 2007 7:17 pm
JUGEL
No Longer Registered
Post by JUGEL » Fri Nov 16, 2007 7:43 pm
JenSX1000 !!! (this is the sole reason I defend it!!)
CS-10
Six trak!
the SH-1 on has only AR on 1 of the ENV's I believe.
neandrewthal
Post by neandrewthal » Fri Nov 16, 2007 8:38 pm
Do you mean dedicated to filter and amp, or just 2 that be routed to each, among other things? If the latter then:
What happens at fondue stays at fondue!
dracena
Gear: 2cabinet 100m,Source, MS20, sh09, JP8, OB8,OBSX,106,Performer,DX7, DX21,FB01,CZ101,Maestro, MC4,
909,707,626,Drumtraks,dr110,kpr77
Post by dracena » Fri Nov 16, 2007 9:01 pm
Micromoog has separate env for fiter and vca. They're not ADSR type but just simple AR with separate switchable short or long sustain stage via a dedicated switch.
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Fri Nov 16, 2007 9:57 pm
What the h**l is that neandrewthal?
insky
Post by insky » Fri Nov 16, 2007 10:08 pm
MS-50
Stuff I own:
X Station
ESQ-1
JX-8P
Poly 800
MaxiKorg 800DV
Elka Rhapsody 610
Automatic Gainsay
Real name: Marc Doty
Band: Godfrey's Cordial
Post by Automatic Gainsay » Fri Nov 16, 2007 10:43 pm
insky wrote:MS-50
If only Korg had put two oscillators on that thing... man, it would have been absolutely stunning. Not to say that it wasn't stunning with one... just that it would have been stellar with two.
Of course, they're hard enough to find, and expensive as h**l with one osc...
calyx93
Post by calyx93 » Sat Nov 17, 2007 12:00 am
If you're counting polysynths: Akai AX-60, AX-73 and VX-90, SCI SixTrak, MultiTrak, Split-Eight and MAX, Roland JP-4, Kawai SX-210, Teisco SX-400, Korg Poly-800, PPG Wave 2 ... there's probably a lot more, but I'll stop here.
ronmcdonald
Post by ronmcdonald » Sat Nov 17, 2007 1:01 am
Another vote for the SX1000.
It's one of the most redeeming features it has. Not that they aren't any good for other reasons, but the luxury of separate full ADSR's, with actual knobs, is a very nice luxury to have on such a cheap and compact synth.
And itsss analogue!
Dirk
Post by Dirk » Sat Nov 17, 2007 4:42 am
I was wrong
All Animals Are Created Equal But Some Are More Equal Than Others.
Bitexion
Roland D-50
Creamware Minimax
Yamaha DX7s
Post by Bitexion » Sat Nov 17, 2007 4:47 am
The MS-50 was marketed as an addon for the MS-20, not really a standalone synth.
neandrewthal
Post by neandrewthal » Sat Nov 17, 2007 6:21 am
Looks like it can be played by any v/oct keyboard so I'd say it's technically it's own synth though I'll alway see it as an MS-20 add-on.
Psy_Free
Gear: Synths 'n' stuff.
Band: Klangzeit
Post by Psy_Free » Sat Nov 17, 2007 1:42 pm
Powertran Transcendent 2000 has ADSR for VCA & separate AD for VCF
Bandcamp 1
Bandcamp 2
Soundcloud
JSRockit
Post by JSRockit » Sat Nov 17, 2007 2:01 pm
calyx93 wrote:If you're counting polysynths: Akai AX-60, AX-73 and VX-90, SCI SixTrak, MultiTrak, Split-Eight and MAX, Roland JP-4, Kawai SX-210, Teisco SX-400, Korg Poly-800, PPG Wave 2 ... there's probably a lot more, but I'll stop here.
Nope, wasn't counting them...or synths without keys. :oops: I should have mentioned that. Thanks everyone.
