808 style kick on the Moog little phatty??
- Philly Stress
Has anyone hand any success at creating a 808 style kick on Little phatty??
JoMoX Mbase01
- calyx93
- Gear: PPG Wave 2.2, μWave (x2), Roland JP6+V-Synth+S-220, SCI P5+600, Ensoniq SQ-80, Kawai K-3+K-3m, ARP Odyssey+Omni2, Emulator II+HD, Ensoniq Mirage.
How hard can it be? It's as easy as it would be on any synth with fast envelopes and a self-oscillating filter.
Turn down both the level of both oscillators, raise the filter resonance to 100%, lower the cutoff (and octave if you wish) to suit your taste, and play with the filter envelope amount (probably to a gentle amount, depending on how deep of a sweep you want) and adjust the filter envelope settings until you get something similar then adjust your volume envelope settings to somewhat match.
It's in there, you just need to play with it and use your ears. I'm in front of mine right now (TE #0015) and have come up with several variations upon the 808 kick.
Well, if you didn't know you shouldn't use oscillators, then it would be very hard. Not everyone knows how to program everything.calyx93 wrote:How hard can it be? It's as easy as it would be on any synth with fast envelopes and a self-oscillating filter.
Some analog drums use selfoscillating filters, e.g. the 808, 606 minipops ect. Others use vco's and envelopes to get their sound, e.g. tr-909.JSRockit wrote:Well, if you didn't know you shouldn't use oscillators, then it would be very hard. Not everyone knows how to program everything.calyx93 wrote:How hard can it be? It's as easy as it would be on any synth with fast envelopes and a self-oscillating filter.
All Animals Are Created Equal But Some Are More Equal Than Others.
I've only tried using osc myself... that's probably why I couldn't get those nice round BDs.Dirk wrote:
Onlinemeatballfulton
- Gear: Logic Pro X
The common thread is to use a sine wave, something a lot of vintage analogs don't have.JSRockit wrote:I've only tried using osc myself... that's probably why I couldn't get those nice round BDs.Dirk wrote:
Sines aren't very useful in subtractive synthesis because there's nothing to subtract
If you have neither a sine available from the oscillator and the filter won't oscillate, then you have to use a square or saw and filter it down to just the fundamental to get a sine.
If using the oscillator rather than the filter then you play with the pitch envelope rather than the filter envelope as calyx93 wrote
That's true but most basic synth tutorials (plenty of them are online) discuss how to create kick drum sounds.JSRockit wrote:Not everyone knows how to program everything
Understood... I haven't thought about drum synthesis on analogs alot since I mostly use samples and the machinedrum.meatballfulton wrote:
- OriginalJambo
- Gear: Check my sig
- synthetic88
I got a nice 808 kick on the Voyager following these examples. I would record it if I wasn't so lazy.
Andromeda • Voyager • Super Jupiter + Programmer • TX-802 • Two GigaStudio PCs
http://www.jefflaity.com/studio
- ThinkTanx
- Gear: Elektron MnM SFX-6, MD UW MkII * Virus TI * Moog Voyager S.E. * Lemur * Ableton, FM8, Massive, FAW Circle * Distressors, Great River * Genelec 8050A
Do it and post it!synthetic88 wrote:I got a nice 808 kick on the Voyager following these examples. I would record it if I wasn't so lazy.
I have one or two from my Voyager days, but they are buried in tracks. I never cut them out and put them in my sample folder. Plus they used an OSC...
-I'm gonna go try and make one right now on my 777 using the filter resonance!
Kick on the 777 is the hardest hitting kick I had ever made on any of my gear. I wouldn’t say that it’s as usable as the 909 kick, but it does hit waaaay harder.
Alpha
Alpha
I don't drink water, because fish @&^* in it.
Andromeda, Oddy, FR-777, 909, 101, xoxbox, some diy analog effects. And of course STE running Notator to sync all the s**t.
There's nothing wrong with using a vco for drum sounds. The Tr-909 does this, so this method seems to work well.ThinkTanx wrote: I have one or two from my Voyager days, but they are buried in tracks. I never cut them out and put them in my sample folder. Plus they used an OSC...![]()
Infact a selfoscillating filter is also an oscillator. But it is damped, that means that it's level drops after some time. This has the advantage that you don't need an envelope to control the vca (for level changes)
- ThinkTanx
Oh, I didn't mean there was anything wrong with it. I think they sound great, or else they wouldn't have been in my track!Dirk wrote:There's nothing wrong with using a vco for drum sounds. The Tr-909 does this, so this method seems to work well.ThinkTanx wrote: I have one or two from my Voyager days, but they are buried in tracks. I never cut them out and put them in my sample folder. Plus they used an OSC...![]()
I was just feigning embarassment at not knowing how a 'true' 808 kick was made.
