Analogue mono's with Sub Osc
jasedee
Post by jasedee » Fri Nov 23, 2007 5:56 am
I was at a friends house the other day and had a play on his Roland SH-2, and was blown away by it's super thick bass sounds. I was wandering what other mono synths out there also have a Sub Osc???
Cheers!
l::l CS-10 l::l DX7 mkIIFD l::l Motif Rack l::l D-50 l::l Juno 60 l::l Virus Rack XL l::l ER-1mkII l::l TR-707 l::l MC-303
MYSPACE
WWW
JSRockit
Post by JSRockit » Fri Nov 23, 2007 12:32 pm
Roland SH-101
micahjonhughes
Post by micahjonhughes » Fri Nov 23, 2007 2:12 pm
micromoog
Uncle Screwtape
Real name: Jay
Gear: Access Virus Indigo
Alesis ion
Arturia MiniBrute SE
DSI Mopho
Novation KS4
Vermona DRM1 MkIII
Roland TR-707
Korg DDD-5
Korg Volcas (4)
Band: Uncle Screwtape
Post by Uncle Screwtape » Fri Nov 23, 2007 3:00 pm
Korg Polysix (poly or mono modes)
Your... affectionate uncle,
-Screwtape
OriginalJambo
Gear: Check my sig
Post by OriginalJambo » Fri Nov 23, 2007 8:33 pm
Roland Juno, Octave CAT, Roland SH-09.
steveman
Post by steveman » Sat Nov 24, 2007 12:57 am
Multimoog, Octave Kitten, Oberheim OB-1, Roland SH-1
aeon
Re: Analogue mono's with Sub Osc
Post by aeon » Sun Nov 25, 2007 3:32 am
jasedee wrote:I was at a friends house the other day and had a play on his Roland SH-2, and was blown away by it's super thick bass sounds.
I think and feel the Roland SH-2 is as good at bass as any other synth - which is to say it is stellar in that application.
cheers,
Ian
kayvon
Post by kayvon » Sun Nov 25, 2007 6:20 pm
Also don't sleep on synths where you can have multiple waveforms at once. This is also good for thick bass and you get around any potential phase problems when mixing two separate oscillators with different waveforms.
Often used that on the Juno 6 and alot of nice bass presets on my ATC-1 use the same thing.
jasedee
Post by jasedee » Fri Nov 30, 2007 12:06 am
Thanks for the replies! There's an SH-1 on the bay I might have to check out...
MYSPACE
WWW
artfulideas
Post by artfulideas » Sat Dec 01, 2007 6:55 am
Any Roland SH- Synth. The SH stands for Sub Harmonic.
Drum machines: Machinedrum UW mk II, modded TR-606, TR-707 & TR-727 (both circuit bent), ER-1 mkII
Synths: MFB Synth II, MicroKorg, modded Fatman, Mini theremin
fuckrapsputin
Post by fuckrapsputin » Sat Dec 01, 2007 7:19 am
mc-202
gear: Barry Manilow's Greatest Hits
oryjen
Post by oryjen » Sat Dec 01, 2007 4:28 pm
Korg 800DV; not exactly a sub osc, since it's a SAW wave you can mix and scale independently.
So: 2 multi-scale and multi-waveform oscillators, plus 2 scalable "subs"(1 each)!
Huge sounds!
Korg MS20-MS50-SQ10-X911-SuperDelta-800DV-MP4-Lambda ES50-severely modded Poly800-PE1000-M500SP-Trident MkII-KPR77-DSS1-P61//EkoSynth P15//YAMAHA CS30-CP30-DX9-01V//RSF Blackbox x2//Viscount CL1-R64//SCI Multitrack-P600//Roland GR500-SH1000
JJQ
Post by JJQ » Sat Dec 01, 2007 5:41 pm
Dont forget the Jupiter-4 or Analogue Crazy will be upset.
Gear: Minimoog, Mother-32, Roland MC-202, TB-303, (Boss) DR-110, TR-505, TR-808, Alpha Juno 2, Jupiter-8, Oberheim SEM, .com/oakley/moon/mos-lab/STG/Sputnik/MegaOhm-modular & Microbrute
OriginalJambo
Gear: Check my sig
Post by OriginalJambo » Sat Dec 01, 2007 6:01 pm
JJQ wrote:Dont forget the Jupiter-4 or Analogue Crazy will be upset.
It's a poly though, so it should count really. ;)
