Buying Yamaha Tx802
Buying Yamaha Tx802
Postby Graph » Mon Dec 17, 2007 6:00 am
Hi, i have the oportunity of buying a TX802.
Is it worth of buying? i have some experience using DX7(i dont own one), and i love how it sounds. But the seller is selling it quite expensive. Not much, but i may be doubting if it is worth buying, having today FM8(300u$s), or i have the option of buying a TX7 for half the price.
Here, in Argentina, there arent much options to buy :( should i buy the TX802?
Thanks!
Graph
Postby oryjen » Mon Dec 17, 2007 11:36 am
Hi!
Not higher than 100$ for that synth!!!!
It sounds exactly like a DX7, but you can layer 8 different sounds, so it sounds wider.
The programming interface is an absolute s**t! :x
2 hours to make a sound... :?
Korg MS20-MS50-SQ10-X911-SuperDelta-800DV-MP4-Lambda ES50-severely modded Poly800-PE1000-M500SP-Trident MkII-KPR77-DSS1-P61//EkoSynth P15//YAMAHA CS30-CP30-DX9-01V//RSF Blackbox x2//Viscount CL1-R64//SCI Multitrack-P600//Roland GR500-SH1000
oryjen
Postby Altitude » Mon Dec 17, 2007 1:42 pm
The TX802 is the rackmount version of the DX7II. If you want 8 parts to work with, that thing is the way to go. If not, a TX7 would do the trick
Altitude
Postby desdinova » Tue Dec 18, 2007 4:52 pm
8 part multi-timbral, 8+2 output, more algorithms/cleaner outs(vs dx7), performances (dx7ii doesn't do this sans E!, iirc), microtonal scales
I use mine more than I use my soft FM synth. The interface isn't bad once you get used to it :P
rerum concordia discors | genre: wankery
desdinova
Postby i_watch_stars » Fri Dec 21, 2007 6:02 am
Well it depends.
I haven't used mine since I got my TG-77, which essentially supercedes it. If you love FM and don't mind a learning curve, look into the TG/SY series of synths. AFM simply blows regular FM out of the universe.
The TX-802 is just like 8 DX7s, so if you like that synth, then that is a good thing (you will get all of the presets). It is h**l to edit. Yes it is...even after you have used it a lot, still like paiting a room through a keyhole.
Don't pay over 170$ (American) for it, unless you have cash to blow or the pickings are really that slim. Don't be afraid to use eBay, also. I got mine for 150$ and that was a year ago.
JP-8080, Virus B, TG-77, JD-990, D-550, XV-5080, CS1x, Matrix 1000, SE-1, SuperNova II Pro Rack, MKS-50, EMX-1, TX-802, Nord Rack 2X, Korg RADIAS
i_watch_stars
Postby Altitude » Fri Dec 21, 2007 1:05 pm
i_watch_stars wrote: The TX-802 is just like 8 DX7s,
Not really. It still has only 16 voice which you can multi up to 8 channels, which would result in 2 voices per multi ch. 8 DX7s is the TX816. Plus the TX802 is based on the DXII not DX7
Altitude
Postby Synthaholic » Fri Dec 21, 2007 4:50 pm
Programming the TX802 isn't THAT bad, sure it's not like spinning knobs on an analog, but it is certainly doable. A software editor like Midiquest would make it a lot easier though.
I have a TX802 and FM8, and so far I've only used the TX. Sometimes I play with FM8 at work on my laptop, but it's a totally different approach to programming than the TX. For example, there's no direct way to translate parameters on FM8 to the TX and vice versa. For example, if I want "algorithm 5" in FM8, I have to recreate it, or search for it, as the preset algorithms in FM8 aren't named/numbered corresponding to the DX algorithms. FM8 can read DX sysex files, but there's no way to create DX sysex from FM8, so it's a one way road.
Plus, as a child of the 80s, I like playing hands-on with a piece of gear from that area, as opposed to a modern software emulation.
Synthaholic
Postby Altitude » Fri Dec 21, 2007 4:57 pm
Synthaholic wrote:Programming the TX802 isn't THAT bad, sure it's not like spinning knobs on an analog, but it is certainly doable. A software editor like Midiquest would make it a lot easier though.
Did they change that? You used to be able to load sysex dx patches directly into the FM7
Altitude
Postby Synthaholic » Fri Dec 21, 2007 5:29 pm
Altitude wrote:Did they change that? You used to be able to load sysex dx patches directly into the FM7
You can load sysex *into* FM8 but you can't save FM8 sounds as sysex to go *from* FM8 to a DX.
Synthaholic
Re: Buying Yamaha Tx802
Postby dr.blitzen » Fri Jun 27, 2014 4:23 pm
I own a TX802 and it's worth getting these days for those classic sounds.
You may have to replace the battery though. As for those classic sounds that's just it these days - the DX line of synths will always be that - an 80's style sound due to the sheer amount of usage they've had on recordings over the years. To me a DX synth only has a handful of decent sounds and they've all been used in one form or another that being; chunky basses, bells, DX Piano, digital strings and marimbas. So you could find it lets you down in getting something original from it - I guess you'll just have work at it more to program anything unique.
dr.blitzen
Band: dr.blitzen
Postby ninja6485 » Fri Jun 27, 2014 8:19 pm
Don't forget organ sounds! This person was looking to buy 7 years ago. I wonder if they ended up getting the 802?
ninja6485
Postby dr.blitzen » Sat Jun 28, 2014 6:38 pm
ninja6485 wrote:Don't forget organ sounds! This person was looking to buy 7 years ago. I wonder if they ended up getting the 802?
Organ sounds -good call.
7 years ago how time flies and It makes me realize that I've owned mine for 6 now and still use DX manager 1.1.
dr.blitzen
Band: dr.blitzen
Users browsing this forum: Bing [Bot] and 15 guests
