Jabberwalky wrote:I just really couldn't jive with the Ion. Felt very static to me.
The overall build also bothered me. Just a very technical slab, with overly tight encoders, shitty feeling mod wheels and an abysmal keybed.
The sound was always somewhere in that upper mid-range that wore on my ears.
The UI was sprawled around in a fashion that made no sense imo.
The An1x may be lacking in knobs, but sounds infinitely more interesting. The build isn't half bad either (for a mid 90s VA)
Wow we must have played different synths!
The wheels on the ion on some of the best I've ever touched, beautiful resistance and return. The An1x ones are your basic loose/plastic/slap happy yamaha ones. I've had two An1x and let them go no problem. I love the ion. It's a whole other league over the an1x, seriously.
The overall build is gorgeous and feels about 10x more expensive than the rattly an1x, also the AN1x is a pain to use the modtrix/rocker switch/multi select knob thingy, did my head in and stopped me from diving as deep as I'd like. I have none of that problem on the ion, it's super easy once you get your head around how it works.
An1x sounds more interesting? lol, are you sure you weren't swayed by the build in verb/delay? Because the An1x, even with the Free EG (probably its coolest feature) still sounds exactly like a soft synth trying to imitate analog, and yeah it does a good job in some cases but when I compared it to my real analog it always sounded fake, so why bother? Meanwhile the ion actually 'feels' analog in how the sound reacts and breathes, never does it sound like cheap digital, and you put it through outboard FX like a polysix or jupiter and wow, it sounds great, the core sound of it is much more organic/vibey than any other VA i've tried and that includes the An1x which sounds nice but not exactly earth shattering.
AN1x is one of the best VAs ever built (for sound - nothing else certainly not quality of build/feel/components or user inteface), esp considering how cheap it goes for.
ion is one of the best *synthesizers* ever built, VA, analog or digital (and that includes build, feel, components and esp user interface/sound ) - and goes sometimes as cheap as An1x and is solid metal, amazing encoders (overly tight? seriously they work better here than any synth I've had encoders on, I love how they are high res, super smooth and actually help instead of hinder like most encoders do vs pots).
An1x has one filter, and one type of filter with the selectable pole.
ion has 20? filter types, some very unique, others VERY close clones of moog, jupiter, oberheim, ARP etc and can have TWO at once in par/serial which is way above most synths in its class and makes for very cool/unique/usable sounds far beyond the usual stuff the other VAs churn out (also the post filter mixer where you can let a little of the unfiltered sound through and pan ALL THREE sources flt1/flt2/unfiltered, makes for some very wide and complex/full sounds than an1x can't touch (maybe an1x sounds 'nicer' here due to the load of FX it's bathed in? turn fx off and ion will destroy it). Then ion has some great overdrive FX that actually sound usable and add real grit/weight to the sound, AN1x's only useful feature there is the feedback parm, which thickens it up but still doesn't help much to sound "alive". ion's FX I find are perfect for focusing on the sound creation rather than the dressing. You can dress it up after with outboard or DAW verb/delay anyway. And then it sounds way nicer than the other VAs.
As for 'very static' sorry I can not for the life of me understand that jab, this is the least static of all VAs I've ever used, did you actually program it or just take an instant dislike/couldn't get your head around it and dumped it while retaining your bad opinion forever? With ion not only does it have the ability to very subtley mod all THREE osc waveshapes (3 oscs + waveshaping on one VA is a luxury), it also has the analog drift parameter, did you ever use it? set it on 15% and there's nothing static about it.
I think you never put it through outboard FX and felt it sounded a bit 'dry' if anything, but then so does a polysix, but these types of synths often take great to outboard while synths with lots of (old/low budget) fx included are often needed to make the sound seem interesting at all (and then they are usually a pain to mix because you've come out of the synth all dressed up - while ion works more like a vintage analog, and sounds more like one too).
Anyway, its not for everyone, and as I posted in another thread just now, the way it works is different to typical synths (mod matrix for LFO depth/destinations instead of the usual select dest/depth at LFO knob area) which could put some off, but seriously after like, a day, two tops, you are over that and realise how it centralises everything onto the matrix, which is very easy to use here unlike AN1x, and thats exactly what gives it is power and flexibility. I also respect and acknowledge the luxury of design they put into it in the small details, like the little orange lights on each section (filter, lfo, env etc) that lights up with the "mod" legend next to it IF that part is a target in any of the modulation slots you've used. That's great thinking, this is definitely a synth for the deeper sound designer and not the instant noodler though, sure, just how I like them.
I like the An1x, certainly, moreso than MS2k (thin but fun) JP8k (ok but a bit boring) but next to the ion the An1x feels like a tarted up soft synth, ion meanwhile (next to analogs) feels like a 100% valid digital synth doing its own, unique, thing. Up there with other classic digital synths (usually non VA synths). I think the ion, in fact, is the only
interesting VA I've ever used. For all the other VAs I'd rather just go to real analog, with ion I WANT to use it because its digital and because of how it sounds (those filters seriously c**p all over most other VAs), and I love how the screen reacts to the super smooth encoders, when waveshaping etc. LUXURY my friend, luxury!
Yes, you are right the keybed itself isn't great, but then nor is the MS2k (same keybed?), the jp8k has a crappy keybed too and the an1x, while better, is still not exactly stunning.
I can't imagine anyone thinking the An1x looks beautiful though, it's a clean looking unit, kinda cool with its wedge but its pure blue plastic with barely any knobs and very narrow front to back. The ion (slab or not) looks like a serious weapon of sound (and is). Put them next to each other (as I have) and the an1x looks embarrasing, like the awful cs1x its body is taken from. JP8k at least LOOKs good.
But the ion is 10x better build than An1x so what gives? Did you buy a phucked up used unit from trent reznor or something? The ion feels like a V-synth next to the an1x in build quality. If you drop the ion your floor is more likely to be damaged than the synth (it weighs a lot and is one of few synths to have FULL metal body even extended to the wheels area which is normally plastic even on super synths!). Knobs on ion feel 100000000x better than an1x knobs (each ion knob is bolted to the casing for ZERO flex and the knobs themselves feel very high quality/rubber/soft touch not hard plastic). And as said , the wheels are a thing of beauty.
As for sounds more interesting? sorry but you clearly never programmed an ion in your life if you truly believe that, the ion runs rings around the An1x for 'interesting' sounds, unless you are talking about animated/showy things using the evolving free EGs? But core sound is much more interesting on ion, filters are much more interesting (to say the least) and osc selection/count/shaping is much more interesting. Mod matrix on ion is MORE interesting due to it being more likely to be used as its a pleasure to use unlike on An1x (and yeah I used the software editor for an1x a few times but I don't like doing that with hardware synths).
From all you've said I can only conclude, and don't take this as an insult but your comments are so confusing, that you've never actually, really, used one. It can be the only explanation for your weird take on the feel/build of it (other than the keybed). Its actually better built than their own andromeda,
