MIDI channelizer/filter???
celebutante
Post by celebutante » Tue Feb 05, 2008 2:43 am
Hiya.
We're planning on using my MIDI'd Prophet-5 along with a Jup-8 in our live set. These will be MIDI'd to external effects to automate the effects patch changes
Because the Jup-8's Encore MIDI kit doesn't trasmit prg changes (weird, I know), we're using the P-5 to change the FX AND the patches on the Jup-8. The problem is that when the Jup-8 receives prg changes from the Prophet, it also receives note on/off which is bad bad bad.
We need a device to filter out the note on/off data, or at least rechannelize it while retaning the program changes on MIDI ch 1. The only thing I've found that will do this is a MIDI Solutions box that costs $129 (ouch).
Anyone have any other ideas? Anatek used to make a Pocket Filter, but I'm not sure if it'll do what we need, and can't find one anyway.
Any ideas? Any DIY things?
thanks!
Mitchell
synthesizers.com modular • Sequential Prophet-5 • Roland Jupiter-4 • Korg Delta • Oberheim SEM • Ensoniq SQ-80 • Korg MS-20 • Moog Minimoog • Yamaha CS-15 • Cordovox/Moog "White Elephant"
http://www.mitchellsigman.com
http://www.celebusite.com
mistercooper
Post by mistercooper » Tue Feb 05, 2008 10:23 am
iirc, ucapps's midibox diy platform might have some midi filter designs.
m-audio Radium 61, Korg Kontrol49,
Nord Modular rack, ER-1
Soundlab
CS-50
Custom built modular w/ ~30 modules
TX-216, VSS-100, PSR-470
Ableton Live, Reason, Cubase, plugs
stillearning
Post by stillearning » Tue Feb 05, 2008 4:58 pm
Check out the Yamaha MEP4. It's a 1u rack mount box that does quite a bit more than you're looking for, but it's nice to have around.
As always, kindly allow for the possibility I have no idea what I'm talking about.
Re: MIDI channelizer/filter???
Post by meatballfulton » Tue Feb 05, 2008 7:09 pm
You have both a Prophet and a JP8, worth a few grand and you're moaning about spending $129 to fix your problem? :shock:
pricklyrobot
Post by pricklyrobot » Tue Feb 05, 2008 9:20 pm
celebutante
Post by celebutante » Wed Feb 06, 2008 9:23 pm
meatballfulton wrote:You have both a Prophet and a JP8, worth a few grand and you're moaning about spending $129 to fix your problem? :shock:
Point taken, but...
1. Hey I'm poor!
2. I got a REALLY good deal on the P-5 ($1000).... it needed some TLC.
3. The Jupiter isn't mine (it's my keyboard player's).
And besides, it's such a simple thing that we need to do (filter out note data on one channel), I'd rather spend as little as possible for something so dumb.
Thanks to everyone else for the advice... more research!
Mitchell
th0mas
Band: GRAVITRONIC
Post by th0mas » Wed Feb 06, 2008 9:46 pm
midibox.org. build a CORE module, connect it to a cheap AC/DC wall wart, and with a little bit of C coding you'd be done. The forum people are nice as long as you aren't afraid to read a bit first. Probably cost you about $40 if you buy the package, or $20ish if you just get a PIC, the MIDI circuit, and the power supply circuit..
Altitude
Post by Altitude » Thu Feb 07, 2008 12:23 pm
Why dont you just get a midi foot controller?
Something like this
celebutante
Post by celebutante » Thu Feb 07, 2008 11:31 pm
Altitude wrote:Why dont you just get a midi foot controller?
Something like this
If we used a foot controller strictly to switch fx, he'd still have to do all the program changes on the synths simultaneously, which wouldn't leave a lot of time/brainpower for actually hitting the black and white thingees (he's frequently juggling two synth parts that have nothing to do with each other, and the prg changes are pretty hairtrigger quick). One of the reasons we were happy about using the P-5 as the "master program change" controller is that changing programs on the Jupiter 8 always requires pressing two buttons, and they're really touchy making it very easy to flub. (Roland must have figured this out, because the Jup 6 and Junos are "one button" prg changes, just like the Prophet).
We talked about using something like a Ground Control footpedal controller to send program changes to both synths and the fx, but I was against it because they're big, stages are often small, and we're currently using an Apex stand which is a bad combo with a big foot controller.
The other reason is that I don't want him staring at his feet all night. Makes for bad presentation (we aren't a stoic prog rock experience, we're a dancey synth band).
The easy answer to ALL of this is to forget about crazy vintage synths and use Apple MainStage, but we're trying to keep the dream alive with the old monsters :>) (I already have almost everything set up in there).
mitchell
Altitude
Post by Altitude » Thu Feb 07, 2008 11:54 pm
I think a good portion of those controllers allow for more than one message to be sent with the click of a button..
celebutante
Post by celebutante » Fri Feb 08, 2008 10:17 am
Altitude wrote:I think a good portion of those controllers allow for more than one message to be sent with the click of a button..
The Ground Control is the only one I'm aware of that's fully progammable to send different messages on different MIDI channels. But they're pricey, and like I said in the previous post, won't fit very well in front of an Apex stand, and it will have the effect of causing my keyboardist to stare at his feet.
I think we're going to go with a Digital Music MX8 which will allow us to filter the note on/off data, as well as do prg change mapping so we don't have to do a lot of patch duplication in the Jupiter.
