trance drum ideas
derma_tek
Band: Derma-Tek
trance drum ideas
Post by derma_tek » Fri Mar 28, 2008 3:40 pm
i'm looking for something new for trance-type drums, something that will compliment my machinedrum, i already went the analog route, and wasn't what i was looking for.
i'm kind of thinking maybe a korg emx or quasimidi 309
what do you guys think?
shaft9000
Real name: Dave
Band: moneymoneymoney
Post by shaft9000 » Fri Mar 28, 2008 5:24 pm
what are you missing in your sound that you want to add?
quasimidi make quality stuff but i haven't used them longer than a 1/2 hr at a time so no expertise here. similar to the emx, but from a previous era. they get the hiccups unless MIDI-slaved, so be wary.
i think you should also consider something you can sample/load new sounds into.
re: emx . i say go for the esx 1st, and then pick up an emx later if you dig it. i've had both for years. emx is aggro mostly, and limited to digisynth and PCM drums. esx is smoother and warmer imo, uses just samples, albeit sample management is slow - but for drums alone it rocks and the fx section(same on emx but esx is somehow more inviting and better-sounding than emx to my ears) is a blast.
but if you just want slamming aggro, then emx is the ticket.
in pure sound quality the spectralis is IT if you can spare the dosh and don't mind some menu-diving.
and of course there's the mighty RS7000. tough to beat although some say the MV Rolands are their favorite by far. But no xOx grid there.
derma_tek
Band: Derma-Tek
Post by derma_tek » Fri Mar 28, 2008 6:50 pm
shaft9000 wrote:what are you missing in your sound that you want to add?
i forgot about the rs7000, can you comment on the included drum sounds at all?
shaft9000
Real name: Dave
Post by shaft9000 » Fri Mar 28, 2008 7:21 pm
can't comment because i don't have one. there's some demos on YouTube and a few mp3s you can google to get an idea.
i will be getting an rs7k before long though...the esx is best used as a custom soundset drummachine & fx box i find...for full-fledged sequencing & sampling the rs7k should be much better. it's got a slightly cut-down a3000 engine after all.
Yoozer
Post by Yoozer » Sat Mar 29, 2008 12:03 am
Hugo76
Post by Hugo76 » Sat Mar 29, 2008 3:17 am
Regarding the RS7000;
I like it a lot. The synth sounds aren't that good, to say the least (only 1 element patches), but the drum sounds are great imo.
Anyways, I'd say get a sampler if you're after drums, and the RS7000 is superb for this purpose... ;)
i_watch_stars
Post by i_watch_stars » Sat Mar 29, 2008 5:33 am
.....aaaaaannnd you've just won this....
..BRAND NEW CAR!!!
JP-8080, Virus B, TG-77, JD-990, D-550, XV-5080, CS1x, Matrix 1000, SE-1, SuperNova II Pro Rack, MKS-50, EMX-1, TX-802, Nord Rack 2X, Korg RADIAS
Soundwave
Post by Soundwave » Sat Mar 29, 2008 1:53 pm
309 without a doubt if you already have a Machinedrum. It does all the dirty ,heavy sounds the Machinedrum can't quite get right. The EMX is just a beginners Machinedrum as there's nowt on there that the Elektron can't already do and then some.
nick_emulated
Post by nick_emulated » Sat Mar 29, 2008 2:49 pm
get an emulator....destroy some breakbeats w/ gain...layer them behind your machine drum doing tr type sounds...works awesome for trance/acid/acid breaks/tech/dnb :D
altho i think the 909/emulator combo is better....the machinedrum is a bad mamba jamba no doubt...but it just doesnt have thunder of say a 909 or a jomox clone(xbase/airbase)...where the machinedrum excels IMO is at the more wacked out percussive sounds....like what the dx7IIFD would do if u put some powerful blotter in its floppy drive and started programming percussion 8) ...just my opinion tho...im one of those ppl that had a machine drum, played w/ it for a few months, sampled it, and re-sold it.
Soundwave
Post by Soundwave » Sat Mar 29, 2008 5:19 pm
nick_emulated wrote:get an emulator....destroy some breakbeats w/ gain...layer them behind your machine drum doing tr type sounds...works awesome for trance/acid/acid breaks/tech/dnb :D
You don't get a Machinedrum for static sounds :roll: and a 309 can do a very good 909 especially the kick and hat.
hyphen nation
Gear: boxes that make noises
Post by hyphen nation » Sun Mar 30, 2008 3:05 am
nick_emulated wrote:...im one of those ppl that had a machine drum, played w/ it for a few months, sampled it, and re-sold it.
um, I am confused...due to the nature of the MD being a powerful sequencer / and a synth that lets you dial in such a wide range of percussive, I don't know how you could effectively sample it...I suppose the kits are fun and interesting in their own right...I spend my time on the MD making my own sounds...
What about investing in some filters to pair up with the MD? I would say check out the Jomox stuff if you haven't {I know you thought the analog thing wasn't good for you, but they are the other boxes I would really like...or start saving for the DSI/Linn box when it finally gets here...
killedaway
Gear: Electribes x 6
Revolution
Monomachine MKII
microKORG
CS01
& more!
Band: killedaway/allyourblood
Post by killedaway » Sun Mar 30, 2008 10:19 am
Soundwave wrote:The EMX is just a beginners Machinedrum as there's nowt on there that the Elektron can't already do and then some.
they aren't even close to being the same thing. and while the MD can cover some of the same ground as the EMX, it won't replace it (and vice versa, of course).
1.5.9.13
1.5.9.13
nick_emulated
Post by nick_emulated » Sun Mar 30, 2008 2:36 pm
sampled loops, then chop-chop-chopped them up w/ zero-x beat creator, then scsi them to the emulator for re-sequencing.
the MD is a good drum machine....just not my cup of tea...and soundwave....i wasnt really using it for static sounds....i was using it to compliment the 909 and mpc(mostly w/ crazy metallic sounds, like i used to get from a dx200)...ive had a 309 before...and aside from its usefulness live(having a knob that can change the sample is the most brilliant thing about that box), its no-where near what the 909 or even a jomox can do sonically...a 309 next to a 909 is like comparing a fiero to a ferrari....both are fun, but the ferrari is the superior machine.
