Analog modular synthesizer
- supercluster
I'm thinking about investing in an analog modular system. I want to get something that is compact and somewhat portable - i saw that doepfer has briefcase enclosures. i also want something reliable and reasonably affordable.
Does anyone have any suggestions for solutions?
Doepfer?
Doepfer?
Doepfer A-100, MPC1000, Alesis Ion
Roland Re-20, Moog MF-105, Moog MF-102, boss me50-b
For sale: Yamaha RS7000, Korg Kontrol49
- seamonkey
- Real name: Rick
The stuff from synthesizers.com sounds quite impressive to me and the prices are very reasonable.
Here's a link:
http://www.synthesizers.com/index.html
Here's a link:
- Gear: Sage XP 4wt 10
Sage TXL 3wt 710 - Location: Salt Lake City, UT
True, nice modular, I even had a 22 spacer for a while. But after getting eurorack stuff I sold it. I thought that working with the big jacks and modules was cool for a while, but it ended up being a lot of work and took up too much space. Plus you get such a wider variety of modules with the other forms (eurorack or frack). Yeah, I know you can fit some other types into a dot com case, but you need spaces or modifications - it's usually not just plug and play.seamonkey wrote:The stuff from synthesizers.com sounds quite impressive to me and the prices are very reasonable.
Here's a link:
I was afraid the small size of the eurorack stuff would be difficult to work with, but that hasn't been the case at all. It's nice having the small cables and not having to stretch to make patches.
- seamonkey
- Real name: Rick
Very interesting, I hadn't given the eurorack design much thought. I'm curious what system you went with? I know you can mix and match but what basic system did you start with?tunedLow wrote:True, nice modular, I even had a 22 spacer for a while. But after getting eurorack stuff I sold it. I thought that working with the big jacks and modules was cool for a while, but it ended up being a lot of work and took up too much space. Plus you get such a wider variety of modules with the other forms (eurorack or frack). Yeah, I know you can fit some other types into a dot com case, but you need spaces or modifications - it's usually not just plug and play.seamonkey wrote:The stuff from synthesizers.com sounds quite impressive to me and the prices are very reasonable.
Here's a link:
The Doepfer A-100 looks good, how does it soundwise stack up against your memory of the dot.com stuff?
I would love to have a small analogue modular system in my studio some day (note small)lol maybe start off with something like the Doepfer mini system.
- shaft9000
- Real name: Dave
- Band: moneymoneymoney
...and it sounds freaking awesome; a lot better than typical doepfer systems imho.
only troubles are the 1/8" jacks and limited limited range of modules available in this format atm. unless you plan on going hogwild with like 5 different filters this is a very tempting entry.
I started out with a 2 rack case and only a few sound processing modules. I only just recently bought a vco for it. I still have a few modules to go to make it a stand-alone synth.seamonkey wrote:
These are the modules I currently have:
Plan B VCO,
Plan B voltage processor
Live Wire Dalek Madulator
Doepfer complex envelope generator
Doepfer SSM style filter
Doepfer wave multiplier
Doepfer bucket brigade delay.
I'm going to finish filling the case with an amp, quad envelope, and a slew limiter. The next case I get I'm going to build myself with their DIY kit. For that one I want for that is another VCO or two, a new filter, a more traditional LFO, another amp, more multiples.
So until I get an amp and more traditional evelopes, I'm running the last out into a Minimoog Voyager's input in, there I use its amp and envelopes (where it also goes through the Voyager's filters). As far as the sound it's kind of hard to say, since it depends on what you get. For VCO's there are choices from Plan B, Doepfer, Cwejman, and Analogue Solutions, and filters by all of the above as well. So you'll get a different sound depending on which of those you get (there may be more than that from other makers, I don't remember names). Then as far as cv, most of those makers have their own envelopes, and so they'll have different snappy-ness to them as well, etc. Anyway, it seems like the eurorack stuff is pretty flexible as far as sound goes.
