Korg MiniKorg 700s or 770?
- Junior Member
- Gear: Univox K-2 Mini-Korg 2
- Location: Northfield, Illinois or Milwaukee, Wisconsin (I go back and forth a lot)
Hey guys. I have the Univox Mini-Korg K-2 (AKA MiniKorg 700s). I like it, but I've been looking into the 770. I can't see too many differences, except VCO 1 goes to 64' (opposed to the 700s which goes to 32'), has an external input, and fine tune. Both have ring modulators, and both have 2 VCOs (the second being the ring modulators on both). Question is, should I sell the 700s and get the 770 (can the 770 do all the sounds that the 700s can?), if I can get the 770 for basically what I paid for the 700s? Any help would be appreciated, thanks.
- hfinn
- Expert Member
- Gear: http://soundcloud.com/heath-finnie
- Junior Member
Not sure. I've never had experience with it; some synths have awesome external signal processing, some have not-so-good ones. Don't know anything about the one on the 770.hfinn wrote:Well, it sounds like you'd be doing it basically to go to 64' on the VCO. Apart from that they don't seem very different... Do you think you would use the external input?
- LesDeuxLoveOrchestra
- Junior Member
I own a 770, and I have to say that I never use the 64' option. It's actually too deep to be be usable, at least for my purposes. On the other hand, the external signal input is invaluable, because (i) it allows me to ring-modulate other instruments (e.g. my 606's hi-hats); (ii) it allows me to apply Korg's wonderful envelope-controllable high-pass filter to sounds from other monosynths. (Admittedly, what makes this kind of patching genuinely useful is that my 770 has been modified with CV and Gate inputs.)
- Junior Member
Damn. That made me think about a 770 all over again. Man. I was starting to take JS' advice too.Vast Halo wrote:I own a 770, and I have to say that I never use the 64' option. It's actually too deep to be be usable, at least for my purposes. On the other hand, the external signal input is invaluable, because (i) it allows me to ring-modulate other instruments (e.g. my 606's hi-hats); (ii) it allows me to apply Korg's wonderful envelope-controllable high-pass filter to sounds from other monosynths. (Admittedly, what makes this kind of patching genuinely useful is that my 770 has been modified with CV and Gate inputs.)
- hfinn
- Expert Member
Well keep in mind his was modified... If you want to use a ring modulator on other instruments I highly recommend the Moog MF-102drummy wrote:Damn. That made me think about a 770 all over again. Man. I was starting to take JS' advice too.Vast Halo wrote:I own a 770, and I have to say that I never use the 64' option. It's actually too deep to be be usable, at least for my purposes. On the other hand, the external signal input is invaluable, because (i) it allows me to ring-modulate other instruments (e.g. my 606's hi-hats); (ii) it allows me to apply Korg's wonderful envelope-controllable high-pass filter to sounds from other monosynths. (Admittedly, what makes this kind of patching genuinely useful is that my 770 has been modified with CV and Gate inputs.)
