complimenting a 303 and drumstation
princefan3
Post by princefan3 » Fri May 23, 2008 4:15 pm
trying to compete with a 303... for space in a track is proving to be hard work.
a lot of what i hear is just additions of further percussion to build a track
...i have a jp8000 which i can get some lovely backing arpeggios going, but i find, i have to either, give way to one machine or the other.
is there a machine that you could suggest that compliments a 303...
was thinking of a further cheaper midi bass unit..ie freebass in order to add a extra more controllable dimension...
how does everybody else work in this field
sacredcow
Post by sacredcow » Fri May 23, 2008 6:11 pm
I'd suggest a novation nova or jx-8p
PowerMac G4 dual, DSI MoPho, E-MU XL-7, Korg ES-1mkii, Korg EA-1, Novation Nova, Kawai K4, Casio vz10m, Casio ht700, Yamaha PSS-480
(5 good trader references and counting)
Yoozer
Re: complimenting a 303 and drumstation
Post by Yoozer » Fri May 23, 2008 10:13 pm
princefan3 wrote:trying to compete with a 303... for space in a track is proving to be hard work.
Everybody else knows what those 3 or 4 knobs on a mixer titled "EQ" do.
You want space, cut everything away that you can't hear.
ford442
Real name: Noah
Band: Noah Cohn
Post by ford442 » Fri May 23, 2008 11:09 pm
right now i've got my SH101 going along with my FR-777 which is very 303-ish and having some fun results.. weren't the two built at the same time to compliment each other by the way? (101 and 303?)
if you really want to save space i would suggest looking into softsynths if you havent already.. i only have 3 synths on my desk - no drum machine - i do everything else with software..
xonox
Post by xonox » Fri May 23, 2008 11:22 pm
I usually try sounds that do not compete for the same note range as the patterns i use on my 303 clones. I like pads using both a low pass and a high pass filter. I can remove some low end to not clutter up the sound too much and filter out the harsh high frequencies.
Something along those lines can be heard on my "acid emulations" ep on http://www.quikphix.org
No 303 was used but sounds used are in the same register.
Zamise
Gear: Rollhand P00
Band: Quantum-Source
Post by Zamise » Sat May 24, 2008 2:15 am
A TB-303 shouldn't compete much with a JP8000. Are you talking an MC-303? I can imagine an MC-303 competing with a JP8000 in a mix. Maybe try a V-Synth to compliment any one or all of them if your looking to stay with the Roland brand. If its a TB-303 your talking about then with the JP8000 and a V-Synth you'd have an Analog, a Digital, and a PCM. If its an MC-303, then I'd say get something Analog, an MC-202 perhaps or an SH-101 maybe if can do it. Maybe just trying another manufacturer of synth with what you've got as well would help your problem.
Mooger5
Post by Mooger5 » Sat May 24, 2008 2:32 am
106 unison bass. Blend it with the 909 kick and the 303 will float nicely in between...
Herrare umanum est.
Post by Stab Frenzy » Sat May 24, 2008 2:45 am
Damn, I wanted to make that smart-arsed answer. ;)
Rhizomorph
Post by Rhizomorph » Sun May 25, 2008 10:10 am
Ok Iam just gonna say WTF?!!!!!!!!!!! I have a JP8000 and yesterday i bought a TB-303 and a Novation drumstation :shock:
mome rath
Post by mome rath » Sun May 25, 2008 4:35 pm
Rhizomorph wrote:Ok Iam just gonna say WTF?!!!!!!!!!!! I have a JP8000 and yesterday i bought a TB-303 and a Novation drumstation :shock:
HOLY BUCKETS
god elton can't you suck
