TX802 = cheap TX816??
Alex E
Gear: Jupiter-6, Juno-60, Polysix, Emulator II, DX7, QX1, Arp Odyssey MKII, ESQ-1, Miami, M1r, Live 9, iMac MC309XX/A
Post by Alex E » Fri Jun 27, 2008 6:52 pm
Shouldn't the 8 part multi-timbral TX802 make the TX816 irrelevant? Is there something I'm missing here? Can the TF1 modules in the TX816 modulate and effect each other or something?
soundcloud.com/vectron
Jack Spider
Retired Moderator
Retired Moderator
Gear: -
Bit One
Boss DR-220
Boss DR-660
DSI Mono Evolver Keyboard
Korg LP-10
Roland XP-50
Yamaha QX21
Post by Jack Spider » Fri Jun 27, 2008 7:25 pm
With the TX-802 set to 8 different timbres, each one will be monophonic or duophonic, depending on whether the patch uses two voices or one.
Each of the 8 TF1 modules boasts the full 16-note polyphony and functionality of a DX7, so a full TX-816 gives 128 voices (and 48 operators!).
Alex E
Post by Alex E » Fri Jun 27, 2008 7:38 pm
Oh ok thank you. That explains a lot.
It's so annoying when synths have multi-timbrality that also limits the synth... It's almost pointless.
Synthaholic
Post by Synthaholic » Fri Jun 27, 2008 7:51 pm
Think of the TX816 as a box with 8 completely separate DX7s inside, and a MIDI thru box that sends your MIDI data to each of those modules. Each of those DX7s (actually TF1 modules) has 16 note polyphony, its own set of global parameters, LFO, patch memory, etc. You can use them individually or together, just like you would if you took 8 DX7s or TX7s and MIDIed them together. The "816" means 8 parts x 16 voices each.
The TX802 is more like a single DX7 (mkII) with 16 voice polyphony, where those 16 voices can be split up (in pairs) to create a multitimberal instrument. "802" - 8 parts x 2 voices each, but you can combine the parts to increase polyphony for each part. For example, you could have 2 8-voice parts, or 2 6-voice parts and 1 4-voice part, 4 4-voice parts, 1 14-voice part and 1 2-voice part, 1 16-voice part or any other combination. The 802 has 8 separate outputs, one for each 2-voice part, plus a pair of "mix" outputs that each part can be sent to. That way you don't have to use a submixer for the 802, unless you want to do different processing/panning for each part. You'll need a submixer (or be able to spare 8 inputs on your main mixer) to accomodate the 816.
As for your other question, the TF modules in the TX816 cannot modulate one another. Each voice has 6 operators; the modulation doesn't cross between voices or modules. Same for the TX802.
One other significant difference: The TX816 and its TF modules are based on the MK1 DX7, while the TX802 is based on the MKII. So the sound quality is different (grittier on the 816, you get that classic DX sound, cleaner on the 802).
desdinova
WTB: TF1s lol
Post by desdinova » Fri Jun 27, 2008 10:00 pm
Synthaholic wrote:As for your other question, the TF modules in the TX816 cannot modulate one another.
Not in the DX sense, of course, however using seperate modules to create a singular, more complex timbre is really where the beast shines.
I've got an 802 and a 516, wouldn't give up either.
The only real reason I could see dissuading someone from getting a TX-rack, outside of keeping out hunting competition :P, is that programming CAN be tedious. It's fairly easily rectified with a large IO midi interface or some creative routing and a MIDI patchbay. This is with a stock rack, I haven't bothered with the hardware module# tripping hack.
rerum concordia discors | genre: wankery
Z
Post by Z » Fri Jun 27, 2008 10:19 pm
I resold a TX816 at the beginning of the year. Here are the photos I took which will better explain its physical structure if you've never seen one.
AstroDan
Post by AstroDan » Fri Jun 27, 2008 10:25 pm
That looks like an excellent beginner's synth for programming.
Too futurist to live.
Sir Ruff
Band: Ruff in the jungle
Post by Sir Ruff » Sat Jun 28, 2008 12:02 am
I don't quite understand with the 816 why they didn't create some single midi IN type module... having 8 cables running from one TF1 to the next seems pretty silly.
Do you even post on vse bro?
desdinova
Post by desdinova » Sat Jun 28, 2008 2:36 am
Sir Ruff wrote:I don't quite understand with the 816 why they didn't create some single midi IN type module... having 8 cables running from one TF1 to the next seems pretty silly.
There's In/Out/Thru on the front for the whole rack ;P
The only reason to use the rear MIDI ports are for easing programming, or anal cabling in your racks.
Murderhausen
Gear: Anyone want a Polivoks?
Post by Murderhausen » Sat Jun 28, 2008 2:41 am
AstroDan wrote:That looks like an excellent beginner's synth for programming.
Genius!
Voyager XL*LittlePhatty*ElektronTrinity*ProOne*Mono/Poly*NordLead2X/3*Juno106*JX3P*JX10*JP8000*VirusKB*Blofeld*Ion*OctaveKitten*Polivoks*MS2000*AN1X*AlphaJuno1/2*ESQ1*SVC350*MG1*CS15*DX7II*etc...
Sir Ruff
Post by Sir Ruff » Sat Jun 28, 2008 3:54 am
oh yeah, duh.... :lol:
REwire
Post by REwire » Sat Jun 28, 2008 9:31 am
I just have 1 TF1 in it's box (a 116). Lot's of extra room in there so I use it to store stuff. I did test out a 802 and liked the 116 more; sorta louder and like's been said, grittier.
Buchla, Serge & Eurorack Modular; EML101; Minimoog; Synthacon; MS20; Nord2; NordG1; PolyEvoRack; MKS80; MKS50; TB303; Electribe EMX1; JV1080
http://www.REwireMusic.com
