Another Moog Little Phatty/Moog Prodigy Question
JordanGLV
Post by JordanGLV » Sat Jul 12, 2008 3:48 am
Hey everybody,
I have another question about my new Moog Little Phatty. Before I had my LP I owned a Moog Prodigy. The Prodigy had a Modulation wheel and a pitch wheel just like the LP (except in opposite positions) Anyway I noticed that the pitch wheel on the LP acts more like a standard pitch wheel in that when it is used the actual pitch of the note raises or lowers a half or whole step. However on my Prodigy the pitch wheel didn't change the actual note it more or less seemed to be controlling the filter amount.
I can get a similar effect by using the modulation wheel on my LP to control the filter envelope but it's not nearly as dramatic as the sounds I could get with the wheel on my Prodigy.
Ok hopefully some of that made a little sense (I'm still trying my best to learn) What I would like to figure out is... Is there any way to use the Mod or pitch wheel on my LP to create an effect similar to the pitch wheel on a Moog Prodigy?
Thanks in advance for putting up with me and for any advice you can offer!
Jordan
DocT
Post by DocT » Sat Jul 12, 2008 7:16 am
The pitch wheel in normal Prodigies acts like standard pitch wheel as well. Except when oscillator sync is on, then the pitch wheel only affects the pitch of the slave oscillator, what may occasionally sound like the filter amount were changed.
Did you eventually have a customized Prodigy ?
theglyph
Re: Another Moog Little Phatty/Moog Prodigy Question
Post by theglyph » Sat Jul 12, 2008 2:44 pm
JordanGLV wrote:Is there any way to use the Mod or pitch wheel on my LP to create an effect similar to the pitch wheel on a Moog Prodigy?
Try this:
Mod Source: Filter Env.
Mod Destination: Filter
Mod Amount: Maximum (i.e. fully clockwise)
Filter cutoff: To taste (but probably midway or less)
Filter EGR Amount: 12:00 (midway)
Filter KB Amount: Maximum
Filter Env Attack: Minimum
Filter Env Sustain: Maximum
(Filter Env Decay and Release don't seem to make much of a difference but set them to a minimum position anyway)
With some Resonance and Overload the affect is much more dramatic!!
Perhaps try these settings on the calibration preset to get a feel for it.
I hope this is what you are looking for!! :D
Cheers,
theglyph
Eurorack modular, Voyager w/351,MF101.102.104.105B, LP Stage, Juno-106, Siel DK600, Paia 9700, Nord Electro 2, Ensoniq MR76
JordanGLV
prodigy
Post by JordanGLV » Sat Jul 12, 2008 3:07 pm
I'm out of town for a wedding right now but I'm going to try those setting as soon as I get home. Hopefully it's what I'm looking for.
As far as my Prodigy goes, as far as I know it has never been modified. I did always play with the oscillator sync switched on. If for some reason my pitch wheel was a glitch or a modification it was one of the best glitches ever. I love that effect.
DocT
Re: prodigy
Post by DocT » Sat Jul 12, 2008 4:12 pm
JordanGLV wrote:I did always play with the oscillator sync switched on. If for some reason my pitch wheel was a glitch or a modification it was one of the best glitches ever. I love that effect.
Your pitchwheel worked flawless then. You might however discover just a few interesting capabilities of your Prodigy if you switch sync off once ;)
JordanGLV
Post by JordanGLV » Sat Jul 12, 2008 4:22 pm
unfortunately I sold it (on this forum actually) to raise enough money to buy my LP I hope someday to buy another Prodigy it's such a cool little synth. I'll be sure to experiment with it a little more next time. I can't wait to get home and try the settings suggested I really hope it's what I'm looking for.
Thanks again for all the help!
Jordan
carbon111
Band: Carbon111
Post by carbon111 » Sat Jul 12, 2008 5:12 pm
With osc sync engaged, the pitchwheel on the prodigy ends up affecting timbre, not pitch.
You can get a similar result on the LP by turning oscillator sync on, assigning filter envelope as mod source and oscillator 2 as the destination. Set the amount knob to taste. Now, use the modwheel while playing the keyboard.
You may want to read the extremely helpful "Synth Secrets" series on the Sound on Sound website:
http://www.soundonsound.com/sos/allsynthsecrets.htm
...start with the earliest tutorials at the bottom of the list.
Best Regards, James
My New album "Persephone":
JordanGLV
Post by JordanGLV » Sat Jul 12, 2008 6:11 pm
awesome thanks for the link! You have all been very helpful
shaft9000
Real name: Dave
Band: moneymoneymoney
Post by shaft9000 » Mon Jul 14, 2008 8:57 pm
a CV pedal connected to the filter VC jack creates wide fast sweeps, also. plus you get a free hand.
JordanGLV
Post by JordanGLV » Tue Jul 15, 2008 1:38 am
shaft9000
Real name: Dave
Post by shaft9000 » Sat Jul 19, 2008 3:54 pm
i dunno...i got a Moog one; they're cheap plus have an attenuator:
http://www.musiciansfriend.com/product/ ... sku=702989
