using monos like polys
Sexor
Gear: Prophet6, Jupiter-7, MS25, Juno-50, TR-303, Rhodes 63
Post by Sexor » Sun Jul 20, 2008 10:47 am
You're playing pretty cheesy chords though....
Do people somtimes refer to you as Cheezy Rider?
-sorry... I'll shut my trap now.
Monkey business since 2007!
CZ Rider
Post by CZ Rider » Sun Jul 20, 2008 11:04 am
Sexor wrote:You're playing pretty cheesy chords though....
It's a mono synthesizer with two oscillators? Everybody knows you can't play chords on a monosynth. Not even the cheezy ones. :roll:
Sexor
Post by Sexor » Sun Jul 20, 2008 11:08 am
You DARE defy my opinion? I'm calling my lawyers and I will see you in chord.
clubbedtodeath
No Longer Registered
Post by clubbedtodeath » Sun Jul 20, 2008 1:47 pm
Sexor wrote:You DARE defy my opinion? I'm calling my lawyers and I will see you in chord.
Don't disturb harmony of the forum, eh?
Gear: TB-303, MC-505, MC-09, V-Synth GT, FR-777, FR-XS, MFB: Synth II, EMU Proteus 2500/CS, FS1R, Supernova II, Fusion 6HD, ER-1 MKII
Band: 23, A23P, Piss Ant
Re: using monos like polys
Post by 23 » Sun Jul 20, 2008 2:29 pm
dddoherty@hotmail.com wrote: anyway, how do you go about using excellent patches on an amazing mono to do the things you would do on a poly, what are your tricks?
In the event that you can treat (trigger) osc on an individual basis, there's some moderate pseudo duphonic things that can be pulled. I've found the amount of monosynths that allow for this to be rather limited however.
Finally, the most effective means I've found....
SAMPLING!
ned-ryarson
Post by ned-ryarson » Mon Jul 21, 2008 5:06 pm
SAMPLING!
what do u mean?
ronP
Gear: BEHRINGER Xenyx 802; CASIO MT-70; KORG EA-1 mkII, MicroKorg, microSTATION, MicroX, Mini-KP, Monotron; ROLAND Micro Cube; ZOOM FS01, MRS-4B, MRT-3B
Band: Keyfish
Post by ronP » Mon Jul 21, 2008 5:39 pm
Hi. Using a KORG Electribe EA-1 mkII . . .
. . . I have two mono parts at my fingertips. So, I set both parts to a (two-note) fifth or third chord by detuning one oscillator in relation to other. Next, set one part to play continuously as a drone and play the other part manually. The combination of parts in sequence creates major and minor (and their related 7ths), depending on what notes you press. These pads are thin, yet musically useful when chorused, flanged, phased, or delayed.
8)
BEHRINGER Xenyx 802; CASIO Casiotone MT-70; KORG Electribe EA-1mkII, microKORG, mini-KP; QUIKLOK T20 T-REX Series X;
ROLAND Micro-CUBE; YAMAHA PSS130, PSS140; ZOOM FS-01, MRS-4B, MRT-3B
Wanted: BOSS DR-110; CASIO CZ-101; YAMAHA CS-01, DX-100
aeon
Post by aeon » Mon Jul 21, 2008 6:18 pm
dddoherty@hotmail.com wrote:how do you go about using excellent patches on an amazing mono to do the things you would do on a poly, what are your tricks?
  • Set VCOs as desired and (multi)sample away, loop if needed, then assign synthesis parameters on the sampler.
  • Break chords into mono lines, sequence each line, and multi-track the monosynth.
  • Program a custom multi-voice diatonic pitch shifter on Eventide - play single notes, get out chord voicings - and have it sound musical.
  • Use a looper to overdub and build up chord voicings in real-time.
  • Careful use of delays to smear and blend sound in a textural fashion - usually precision digital - some with integral pitch-shift - into a lush ambience for pad stuff.
cheers,
Ian
ned-ryarson
Post by ned-ryarson » Mon Jul 21, 2008 7:43 pm
jesus this evolvers crazy. shitloads of fun to be had in the lfo section
