waldorf micro Q info, patch and compatibility ?
- novielo
- Gear: in order of appearence:
sh2000 s612 nord modular mpc1000 kp3 ms-something cp-251 gameboy s6000 and other crappy stuff - Band: one-man band
- Location: by the river, st-jerome, quebec, canada, north america
hi, i just got a microQ as a partial trade for the sk-50d i use to have.
does the micro q is compatible with the Q? with patch editor and patch transfer. i'm confuse because on the waldorf site, there's different page for patch download but on various site i see the patch editor for the Q line.
Vote for the remix contest
Re: waldorf micro Q info, patch and compatibility ?
You can transfer patches between Q and microQ but they won't always sound identically.
Some parameters are scaled differently.
- novielo
thanks for your info. while looking at the present on the micro q i got, i've seen doct. is that you that program these preset?
so for i realy like this synth, the matrix is amazing. the only problem so far i have is that the mod wheel doesn't seem to do anything. i use a microkorg as a controler, i see that the microq receive it because the light respond to the movement, but when using the matrix and sending it to any parameters i ain,t got anything... i have to check if a compatibility in midi language is an isue, but i doubt it is.
- impaler42
- Real name: Shaikat
- Gear: Ensoniq Fizmo, Yamaha FS1R, E-mu Ultra Proteus, Korg Wavestation SR, Waldorf Blofeld
- Band: Grainshifter
the micro Q is one h**l of a synth. very comples, it takes a while to get a hold of, but there is so much you can do with it once you do.
- novielo
yes that thing is very deep! on the presets it usualy uses only 6 mod matrix even if there's 16 available and the texture of sound are very deep also.
- balma
- Real name: Mauricio
- Gear: DSI Tempest/Prophet 08/Roland V-Synth/Ensoniq Fizmo/E-mu MP7-XL7/Electribe ESX1/Radias/Waldorf MicroQ
I have a MICRO Q screaming yellow. Got it for $50!!!!
It has the same engine than the Q, but the Q has more poly and more knobs to manipulate parameters.
So the position of the extra knobs on the presets, is what makes the difference mentioned by DoCT, but they are almost the same instrument.
If you have any question in the future. PM if yoou want
https://soundcloud.com/balma
- crystalmsc
- Band: Crystaline
I like the drum part of the synth a lot, drum map just rock.
Kaossilatron - Voicillator
- balma
Definitly, for basses and warm pads. Also, some crazy timbres.
- lovedroid
- Gear: MEK, LP, uQ, P6, BS, SQ80, UF8, WS, Omen6, Sonar
- Band: New Modern Angels
Yup, almost the same, but there are actually some stuff in the big Q that the microQ doesn't have. The ones I recall at the moment are: PPG filter, scalable filter routing, step sequencer...balma wrote: It has the same engine than the Q, but the Q has more poly and more knobs to manipulate parameters.
Source: http://faq.waldorfian.info/faq-browse.php?product=q#21
Q: What's the difference between the Q and µQ series of synths?
A: This list is probably quite a bit longer than you expect. As a general guideline the microQ seems to have just the things that a typical sequencer->tone generator setup needs, while the Q is a performance synthesizer where many of the features won't be used or make much sense until you free it from the slavery of the sequencer and let it call the shots. The microQkb and the Qrack are mixed breeds in that respect although they stay true to their ancestry, so the microQkb is still farther from the Q than the Qrack is and the Qrack is nowhere near the microQ. Now for the (likely still incomplete) list of differences from the biggies to the weenies (my order, yours would probably look different):
The user interface. I'm not saying that one is better than the other, but that is something you'll notice right away and will in subtle ways shape your style of working with the synth.
The step sequencer (we'll come back to that later). Some folks may not need it, but even if you don't use it for playing notes it can still be used as a modulation source. [I plan to write up a Q-Tip on that as it has to be one of the most often overlooked features of the step sequencer.]
FX architecture. The Q has eight independent FX units arranged in four pairs. The microQ has four independent FX units and one global FX. Based on the questions here in this forum the architecture of the microQ is confusing to many users, as in essence the arrangement in the microQ means that a path will sound more often than not quite different in multimode than in single mode.
The Filter Routing _interpolation_. The filter routing (serial and parallel) itself is there on the microQ, it's the interpolation and associated modulation possibilities that are missing on the microQ. When it's used you won't be able to do even an imitation of the effect on the microQ.
No CV and switch inputs on the microQ (rack). The microQkb has one switch and one CV input vs two of them on the Q.
The PPG filter. There is a certain range of resonance settings where this filter sounds just so much better than the normal lowpass. But understand that the lowpass on the microQ and the Q will also sound different.
The XPhorm. Another trick the Q has up the sleeve that can yield stunning "modulations" that have no chance of being pressed into the ModMatrix.
Fixed vs. dynamic performance architecture. The Q does not care how many of it's voices are in use and how many features are used by each voice. The microQ will have a different number of voices depending on the general complexity of the patches.
Filter self oscillation. The microQ just doesn't, which is often easily worked around. Alongside with that the filter model generally is different from the Q which would be most noticeable at or around the point where self-oscillation would start on the Q.
A few differences in the actual sound dumps, some necessary due to the mentioned differences and some gratuitous, like the scaling of some parameters.
The Q's standard number of 16 firm voices can be doubled to 32, while the microQ's maximum number of dynamic voices can be tripled to 75.
Maximum delay length and reverb room size is smaller on the microQ.
