Imagine you are famous, and you can choose a manufacturer and create a synth?
These are mine :
the SYB-6 "BASS SYNTHESIZER" takes the best from the SYB-3 and SYB-5 and go beyond :
- 8 knobs !
- the deep SYB-3 "SAW" waveform (mode 1) with lower octave and LFO modes (modes 2 and 3).
- the fat SYB-5 "SQUARE" waveform (mode 4) with lower octave and LFO modes (modes 5 and 6).
- vocal sound from the SYB-5 : the genuine PULSE-2 (mode 7) waveform.
- two more sounds : DOUBLE PULSE ( mode 8 ) and SINE (mode 9).
- mode 10 and 11 : WAVE SHAPE normal/reverse.
- LFO RATE effect.
- the SYB-3 NOISE effect with a "noise level" knob.
- WAH input (with the optionnal Roland EV-5 expression pedal).
The SYB-7 is not like the SYB-3 and the SYB-5, not even like the powerfull SYB-6. The SYB-7 is devoted to the synthetic sounds : if it has no stereo outputs, or EXP input, or filters like other SYB, the graphic controls make it a complete synthesizer : Attack, Decay, Sustain, Release, Frequency, Resonnance, Rate (for LFO effect), and you can choose between the deep and oldschool SYB-3 "SAW" waveform or the punchy and sharp SYB-5 "SQUARE" waveform. No LEVEL knob ? Of course : the SYB-7 follows the input source level, you can control it simply with your instrument.
the SYB-8 "BASS SYNTHESIZER" is another way to play synth bass. The attack level and the decay time depends on your input sound, you just have to adjust Frequency and Resonnance knobs. You'll find also the LFO rate (mode "3" for saw,"6" for square and "9" for pulse), the EV-5 Expression input, and this time the Wave Shape is not a filter for external sound : now you can modulate the SYB synth sound with the Wave Shape (modes 1/2, 4/5, 7/8). And modes 2, 5, 8 are one octav. lower.
For the musicians who love the SYB sound but want to play "free hands" :
- THE 11 SOUND MODES FROM THE BOSS SYB-3
- THE LFO FROM THE SYB-5 WITH 3 WAVEFORMS THAT CAN BE USED AS A SECOND SYNCHRONISED VCO
- THE 16 STEP SEQUENCER FROM THE ROLAND EF-303
- A REVERB EFFECT
THIS IS........ THE BOSS SYB-16 !
You can program a pattern with the graphic sequencer or use it like a standard SYB with an external sound source to trig the synth sound. And if you use the sequencer, you can plug a tempo footswitch into the "Input", or synchronise the BPM with another machine.
