Free EX800/Poly800 raw samples
gcoudert
Real name: Gilles
Post by gcoudert » Wed Feb 25, 2009 11:05 pm
Before I sold my EX800 module many years ago, I sampled its unprocessed waveform combinations into my S2000 and made a CD of them. On the EX800, you could turn the 16', 8', 4' and 2' setting on or off for each of the two waveforms (squ/tri). Although it probably wasn't necessary, I sampled every single combination. I found the CD earlier today and thought I'd share those rather uninteresting samples with you. They are looped, trimmed and normalised but I'm not sure whether the loop points have been retained.
The samples are labelled as follows: SQU1011 means square wave with 16', 4' and 2' setting ON (and 8' OFF), etc.
You'll find them here: http://www.sendspace.com/file/19k25v
Please let me know if you found them useful.
Gilles
GC
JayEm
Real name: Jonathan
Gear: KorgPoly800 Monotron MonotronDuo MonotronDelay Monotribe VolcaBass MS20Mini MS2000 MFB522 Arturia Minibrute Yamaha CS-15D Tama TechstarTS305
Band: datapark / KNUCKLEFACE / JayEm
Re: Free EX800/Poly800 raw samples
Post by JayEm » Thu Feb 26, 2009 2:01 am
did you sample them at different pitches?
just curious
w00t
gcoudert
Real name: Gilles
Post by gcoudert » Thu Feb 26, 2009 5:59 pm
No, I didn't, it's probably just C3. I didn't think it would make much different for such simple waveforms. Does it?
GC
aeon
Post by aeon » Thu Feb 26, 2009 6:15 pm
gcoudert wrote:No, I didn't, it's probably just C3. I didn't think it would make much different for such simple waveforms. Does it?
Depends on the use. In general, it does. Simple waveforms work best with samples every fifth, or at least every octave, C1-C6.
cheers,
Ian
killedaway
Gear: Electribes x 6
Revolution
Monomachine MKII
microKORG
CS01
& more!
Band: killedaway/allyourblood
Post by killedaway » Thu Feb 26, 2009 8:59 pm
i grabbed it. thanks! could be of some use in my SFX-60 or ESX, neither of which offer multisampling.
1.5.9.13
1.5.9.13
gs
Post by gs » Sun Mar 01, 2009 4:02 pm
This is true. Without re-sampling at intervals like this, you'd get deep aliasing and all kinds of digital artifacts at the extreme pitch ranges.
The Poly800 had a kind of primitive DWGS that used square waves as sources. In the DW6000/8000 the DWGS was 8-bit, fixed (non-editable) and more fully developed... and in the DSS1 the DWGS waves are creatalbe/editable and increased to 12 bit. When you break down, say, a sawtooth multisample in the DSS1 digital waveform editor, you'd see that it's divided into multiple individual samples made every 6th or 7th semitone. That's the only way you'd get a realistic sawtooth sound comparable to a DCO in a PCM-based oscillator system like the Korg DWGS.
Spadz
Real name: Francis
Gear: Samplers, Synths, Guitars, Yamaha recorder, Atari computer and an 18 year Glenlivet.
Post by Spadz » Sun Mar 01, 2009 5:02 pm
If you guys really want those waves, I have a Poly-800. I could sample it if you want...
I'm not convinced they are so special but if the demand is there.
Spadz
If you don't know what you are doing, why are you doing it?
