Moog Rogue - Tackling the foam
Toris
Post by Toris » Mon Mar 02, 2009 9:43 am
The issue with the internal foam in the Rogue is well documented but just in case anyone on here owns one and hasn’t tackled it, I thought I’d have a go at my recently acquired Rogue over the weekend. Before I start I really don’t need any of the well known synth techs (or their wives) launching a scathing attack on what I’ve done, but I would welcome any constructive criticism or advice on how I could have done it better. I’m not a synth tech, nor am I trying to steal their business, I’m just wondering how other owners have tackled this problem.
I managed to ‘catch’ the foam on mine before it had completely turned to goo so that was a bonus:
The old foam removed with a scraper and Isopropyl alcohol:
After masking, I primed and sprayed the inside of the case to hopefully prevent corrosion. I also fitted some new foam with slits for the sliders. (I also cut round discs of foam for the rocker switches):
Keyboard assembly was stripped and cleaned:
Back together:
Err...now what?
Christopher Winkels
Re: Moog Rogue - Tackling the foam
Post by Christopher Winkels » Mon Mar 02, 2009 11:14 am
I'm not an expert on the foam either, but I must say that looks fantastic.
nathanscribe
Post by nathanscribe » Mon Mar 02, 2009 7:19 pm
Hmm, nice job. What's the foam, and where'd you get it? Might grab some.
guitarsandsynths
Real name: Angelo Metz
Band: Brazility
Post by guitarsandsynths » Mon Mar 02, 2009 7:28 pm
Nice job!
I have done the same on a MG-1. The foam had turned in to goo. It was all over the electronic components and deep into the sliders. I used lots of alcohol and q-tips.
Minimoog ModelD Prophet5 Roland Jupiter8 SH7 GR9 CSQ100 TR606 TR707 TR727 Oberheim OB8 ARP2600 KorgVC10 Rhodes73 Wurlitzer 200A ClavinetII DOTCOM PearlDRX1 TamaTS202 Simmons SDS9
Toris
Post by Toris » Mon Mar 02, 2009 10:59 pm
I used this stuff. It's quite high density and nothing seems to come off it i.e. into the sliders.
http://cgi.ebay.co.uk/12-x18-xl-sheet-2 ... 240%3A1318
The seller had some black at the time, worth an email to see if she's got any more.
Err...now what?
carbon111
Band: Carbon111
Post by carbon111 » Tue Mar 03, 2009 12:13 am
Any kind of foam is not a stable plastic - never put any foam in a synth. It will degrade in as little as six years. If a gasket is still wanted, nomex (carbon fiber), thin polycarbonate sheet or anything stable would be much better. Felt is also a no-no. :(
Toris was indeed lucky that his hadn't completely liquified yet. Disassembling sliders to get black tarlike goo out of them with solvents is no fun. :x
I've had a couple Moog Rogues that suffered this malady.
MG-1s and Opus3s are in danger as well.
Best Regards, James
My New album "Persephone":
Toris
Post by Toris » Tue Mar 03, 2009 12:48 am
The stuff I used was a form of styrofoam. They use that in buildings and it's lifespan is comparable to that of the building.
I'll still keep an eye on it though :-)
Err...now what?
xpander
Post by xpander » Tue Mar 03, 2009 6:47 am
you are lucky to catch it in that state... my Opus 3 is gooey with tar, its a shelved project for now. i bought a set of replacement pots from chipforbrains, too.
iProg
Real name: Carl
Gear: Prophet-5, Korg PolySix, Roland D-50, JV-1080
Band: ArtWithHeart
Post by iProg » Tue Mar 03, 2009 8:19 am
What did you use for cleaning the keys? (they really look clean)
My JX-10 could use some cleaning...
Toris
Post by Toris » Tue Mar 03, 2009 8:26 am
The key tops were taken off and just washed in mild soapy water (rightly or wrongly). I only had 32 keys to do not 76!
Err...now what?
iProg
Real name: Carl
Band: ArtWithHeart
Post by iProg » Tue Mar 03, 2009 8:46 am
Haha that takes a lot less time then!
I will try that. Does one really need to take off all the keys for cleaning them??
Toris
Post by Toris » Tue Mar 03, 2009 9:44 am
I took them off as it wasn't too much hassle. You can buy proprietary plastic polish on ebay. It's excellent for removing fine scratches and and cleaning key tops. I've got some of this stuff:
http://cgi.ebay.co.uk/GREYGATE-PLASTIC- ... dZViewItem
Still hard work but easier than taking 76 keys off.
Does your aftertouch work well on the JX? If not, it might be worth taking the keys off to repair that and clean them while you're on.
Err...now what?
iProg
Real name: Carl
Band: ArtWithHeart
Post by iProg » Tue Mar 03, 2009 9:57 am
All the technical aspects are fine on mine, but cosmetically it deserves some care I think.
I just need to scratch them clean with some polish, that's all!
Thanks for the recommendation of plastic polish, will look for it in stores today!
Beautiful Moog btw :D
Al Bleek
Gear: Mini Moog
Pro-One
Band: Instra:mental
Post by Al Bleek » Tue Mar 03, 2009 4:54 pm
Beatiful Moog
Toris
Post by Toris » Tue Mar 03, 2009 5:47 pm
Thanks, I really like the Rogue. I've always thought it would be a bit too limited. Having owned Prodigy/s in the past, it seemed even more 'stripped down' but the contour sync, pink noise and s/h are great. Tuning is also stable as a rock.
Err...now what?
