Jupiter 8 - cross modulation effect
Junjon
Post by Junjon » Wed Mar 18, 2009 8:46 pm
I'm wondering how u guys are using the cross modulation effect.
Since there is a pitch change I find it a bit unusable for playing.
Any tips? tricks? advices?
killertofu
Re: Jupiter 8 - cross modulation effect
Post by killertofu » Wed Mar 18, 2009 8:56 pm
If your JP8 is unusable for playing.. Sell it to me! Ill find a use for it ;)
elmacaco
Post by elmacaco » Wed Mar 18, 2009 9:03 pm
I found it pretty useless on my Jupiter 6. Good for some synth effects and such with osc sync, but I would have much rather had filter FM personally.
hfinn
Post by hfinn » Wed Mar 18, 2009 9:21 pm
It's mostly usable when OSC2 is used as an LFO.
clusterchord
Real name: Tomislav
Band: Nimbus Dei
Post by clusterchord » Sun Mar 22, 2009 4:50 am
if used slightly to bring warble n animation to vco1, i re-tune the instrument to accomodate new pitch. made a few awesome metallic pads i use this way.
also its great when used in low freq mode as second lfo, esp if u use PWM waveform and set the PWM source to very slow LFO. or i use it full-out via env, for clangorous, organic? metal fx. here's an example of these two apps, with random apreggio. besides crossmod i'm tweaking reso, filter, env and vco sync as well:
http://www.babic.com/SYN/JP-8/clc_JP8_fx-tweak-arp.mp3
guitarsandsynths
Real name: Angelo Metz
Band: Brazility
Post by guitarsandsynths » Sun Mar 22, 2009 6:17 pm
If I remember correctly I used some heavy cross mod on this vid.
Synths are not supposed to play only "melodies" or "chords" or "tempered" music. Open your minds and ears!!!!
Minimoog ModelD Prophet5 Roland Jupiter8 SH7 GR9 CSQ100 TR606 TR707 TR727 Oberheim OB8 ARP2600 KorgVC10 Rhodes73 Wurlitzer 200A ClavinetII DOTCOM PearlDRX1 TamaTS202 Simmons SDS9
Stafftunes
Real name: Staff
Gear: Jupiter 6, JX-3P, Nord Rack 2, Blofeld, TX81z,JV2080, RY30, A4000, SK30 + Misc stuff
Band: Stafftunes
Post by Stafftunes » Sun Mar 22, 2009 10:39 pm
time for my first ever post....
I don't know what it's like on the JP8, but I use cross mod extensively on my Jupiter 6. If you use it just slightly it's great for adding a bit of almost de-tuned dirt to sounds, especially basses. I don't know if you can do this on the JP8, but syncing the oscillators as well as using cross mod greats some really fat dirty sounds especially if you set VCO1 1 or 2 octaves higher than VCO2. Nice for some dirty bass again, set VCO 2 to triangle or square and set the mix more towards VCO2.
You can also just create some whacko nearly in tune/out of tune leads with cross mod. Check out my track 'Deepdive'
http://www.myspace.com/stafftunes
5min 40s - the 'whoop whoop' pitch env sound doing the lead melody is the JP6 with a cross-mod patch....
Pighood
Post by Pighood » Mon Mar 23, 2009 3:05 am
When using cross mod and sync together, it's possible to get the pitch tracking to invert itself on a Jupiter-8. Sick s**t. I got all kinds of verklempt kitty noises that way.
Triton Pro * V-Synth * Q * Andromeda * Fizmo * MEK * Virus TI * A-100 * X-Station
Naive Teen Idol
Gear: Roland Jupiter 6, Studio Electronics MIDIMini, DSI Evolver, Linn LM-2 Linndrum, Roland TR-77, Roland GR-300, Novation Remote SL 25
Post by Naive Teen Idol » Sun Sep 06, 2009 2:48 am
I just got my JP-6 back from the shop after about (yikes) a year and a half -- and just did what Stafftunes suggested re. basses and cross-mod. He's absolutely right -- in fact, I think it's what people mean when they say that while the straight up Jupiter 6 bass isn't super fat, you can make it pretty heavy by strategically adding in harmonic grit like cross mod. Nice suggestion.
garranimal
Post by garranimal » Mon Sep 07, 2009 3:17 am
Ditto on the cross mod + sync idea.
If using cross mod by itself, I like using very small amounts just to add subtle complexity to the patch.
XpanderXt
Post by XpanderXt » Tue Sep 08, 2009 9:56 pm
I use cross mod on the MPC5000 VA all the time.
This video has an example of the cross mod doing the typical bell thing. It's about 9 minutes in on the video.
This video has an example at the beginning where I'm doing more of a osc sync thing with it. The audio is a bit overdriven on this one though.
Cross mod is just Exponential FM as opposed to linear FM (DX7). Play with it more especially in conjunction with sync. Try different waveforms on the two oscillators. Try removing key tracking from the modulating oscillator, (Prophet 5 poly mode style). Play with it, it has a lots of sonic possibilities.
Max Websta
Real name: Max Websta
Gear: Minimoog,Clavinet C, Oberheim OB-SX, Yamaha YC-45D,K2vx,Yamaha EX5, Ensoniq ASR 10,Chroma Polaris, Oberheim Dx,Tascam 388 and Tascam Sx-1Le,
Post by Max Websta » Thu Sep 10, 2009 2:00 am
My Jupiter 8 cross mod and pwm are reversed. When I moved the pwm slider I get the cross mod effect and vice versa. Strange. I've had it a couple years and had no issues. I don't if a previous owner was messing around with the guts and mixed them up. It doesn't bother me, I just thought it was a weird issue to have.
