sorry for the many specific questions, im just keen to clear up some of these things before i purchase a blofeld
Not really, no.. Using either some tricky arp and/or LFO action you might be able to get a very basic rhythm going,hinotori wrote:so that would make 48 simultaneous samples within one multipatch ? Is there anyway to "sequence" the oscillator selection ? so for example, inside the seq/arpeg you could make a simple percussion pattern stepping between different samples as oscillators within a single patch ?
WOW! I had no clue that was supported.. that's what I get for commenting only on what I thought I knew based on the waldorf forum talk and not what I have done myself. Sorry for the misinformation, I should have mentioned in my post it was just what I thought based on the mailing list posts!blitzdj86 wrote:th0mas wrote:You can get the same effect but since samples are just oscillator replacements you will need to make a seperate patch for every sample you want to play, then make a multipatch, load each single patch, and configure the low/high key to separate the keybed for each sample you want. tadaaaahinotori wrote:does anyone know if you are able to keymap several samples in a single patch ? kind of like a sampler...
Actually you dont,
<snipped schooling me>
D'oh! I think if they fix the bugs though, the Blofeld is a ridiculously amazing synthesizer as it is.. and I don't even have the sample upgrade yet!blitzdj86 wrote: Also for anyone hoping for improvements to the blofeld, besides minor fixes and such - Apparently the space where they store the OS.. is full...
I dont see why they couldnt use a few KB of the sample flash memory. . but yeah.. I asked them about the possibility of a proper sequencer and they said there's no more room to put new stuff in, and they'd have to rewrite the entire OS...!
