The New Tom Oberheim SEM Thread
- shaft9000
- Real name: Dave
- Band: moneymoneymoney
Re: Tom Oberheim to show new synth on Wednesday?
as long as the tolerances of modern components don't squeeze the characteristic personality out of the thing - consider me SOLD
I'm with otto, I want to see and hear reviews and know that it actually sounds as good as the vintage ones.
I don't want to be $800 disappointed by yet another modern synth that doesn't live up to the vintage sound.
but wow, I can't wait.
for sale/trade: EML-101
- Joey
- Band: BLUSH_RESPONSE
it will live up, it is the EXACT SAME circuitry.
http://wearereplicants.com
- Sir Ruff
- Band: Ruff in the jungle
yeah really... I don't know what reviews people could possibly want. For all intents and purposes, it's the same thing. I could see this turning into a 303 vs. xoxbox type comparison, but since there's no sequencer, it's not really the same. The only differences appear to be surface mount vs. through hole of the original, modern parts vs. vintage... and while I'm sure there's some validity to that argument, but seeing as I've never even played an original SEM, I'll let my ignorance work to my benefit.Joey wrote:it will live up, it is the EXACT SAME circuitry.
Do you even post on vse bro?
We will see... I'm optimistic but at the same time I wont be surprised if it doesn't sound the same. This does have some SMD and I know there was a big debate about that over on AH. Also it looks like the power supply is different. There is something to be said abotu the crappy design of older power supplies. The components are new and the tolerances likely tighter.
hello darkness, my old friend
- Sir Ruff
..yeah, was just re-reading that, but there was no ultimate verdict on if it would really affect the sound or not... but like someone else said, if it even sounds 90% as good as the original, I think most people would be satisfied... And realistically, since we're talking vintage synths-how many true synth heads would EVER think a new clone sounded the same as the original (justified or not)...otto wrote:We will see... I'm optimistic but at the same time I wont be surprised if it doesn't sound the same. This does have some SMD and I know there was a big debate about that over on AH. Also it looks like the power supply is different. There is something to be said abotu the crappy design of older power supplies. The components are new and the tolerances likely tighter.
Regardless, original SEMs easily go for over 1k these days with no mods at all... to be able to get one with full patch points for $800, methinks is a fantastic bargain.
No doubt Mr Ruff... the big thing though is that it does need to come close in sound. Otherwise there are lots of options on the market in all price points. I'm really not trying to be negative, I am very hopefull it will sound great. However, there is not a strong track record of new analog gear sounding like old analog gear (even if it still sounds great in its own way).
This pretty much killed my desire for a telemark either way.
- Overgear
- Gear: AX-73, S3000, MFC42, K5000R, K4r, K1, Nord 3R, MKS-50, Juno-106, JP-8000, CS-10, CS-15, TVS-1, PP SEM(x2), Rogue, Source, Pro-One, P-600, Mopho
I don't know how or if this affects your situation....If the vca cv input is the same as the old, you have to flip the switch in the lower center of the SEM to the right to use it - which disconnects env1 from the vca. Env 1 is on the left of the switch, the right goes to the external cv input for the vca so it's an either/or thing. I ran into this.maindeglorie wrote:OH MY GOD IT'S A MIRACLE.
There is a VCA control patch point, which means I would be able to control this with my French Connection!
Of course, with all the patch points and some ingenuity you can get around this.
- Real name: Unpronounceable
Technically not, unless Tom bought all the components to build them before 2006. He'll have to replace all of his original discrete components with RoHS compliant ones and make the board itself RoHS compliant if he wants to sell it in the EU. Will this make a difference? Hard to say, but a friend in erm another industry has been thanking his diety of choice that his industry is exempt from RoHS.Joey wrote:it will live up, it is the EXACT SAME circuitry.
- Sir Ruff
I hope for everyone's (and especially MY) sake, that this thing still sounds awesome, despite all the potential inhibitors to its original sound that have been brought up... Unfortunately, I won't have an original SEM to compare it to, so the comparisons will have to be left to others (ideally before I actually get mine!)
(release date is sept. 25 according to audiomidi)
I'm eagerly awaiting reviews of this new SEM, anyone in the loop get one early?
I wonder how long it will take if i order one now... only thing holding me back is the damn CA 9.75 sales tax bahhhh
- Gear: Roland JD-800
Roland JV-2080
Roland SH-101
Studio Electronics Omega 8
This is probably a dumb question, but how do you tune the oscillators? Is there some sort of auto-tuning mechanism built-in or do you need to tune them by hand?
I'm sure it's well calibrated upon purchase but at some point like any analog synth will need calibration after awhile, usually just tweaking trim pots I imagine.
How would you trigger the sem with just a pro solo? looking at the patch panel it looks like you could only trigger one oscillator at a time. Am I missing something? I was hoping to integrate the patch panel version into my setup but don't want to have to buy a new midi to cv converter.
Synths:Prophet 08,Prodigy,Mono/Poly,Juno 106
DX 21,Micro Q
Drums:X Base 09,MPC 1000,Battery 3
DX 21,Micro Q
that is a good point, i wonder if it you could just use a splitter cable from the pro solo? maybe there are regular cv/gate inputs on the back... but there are no pictures of the back anywhere
it really does sound good in the short demo, it's too bad tom isn't putting out some demos or letting somebody else do it. I would be salivating watching them
