Improve the sound of your Casio CZ
Post by madtheory » Mon Jun 29, 2009 11:17 pm
So I finally got around to trying the calibrations in the service manual for the CZ-1. The DAC offset voltage was the biggest change. I actually did it by ear, I played a random 8 note chord, and adjusted the VR for minimal noise. My CZ is a LOT cleaner sounding now. No hiss when you release the notes, and no crappy noises when you play chords. It's like I remember my CZ-5000 used to sound.
On the CZ-1 you have to remove the keyboard to get at the DAC section, which is a little awkward.
I've had a CZ-101 and CZ-1000 that had the same issue, so check it out- it might be worth doing on yours.
Juno6
Re: Improve the sound of your Casio CZ
Post by Juno6 » Tue Jun 30, 2009 7:51 am
Nice tip...
AstroDan
Post by AstroDan » Tue Jun 30, 2009 6:47 pm
Wow, didn't think you'd have to calibrate a digital synth. Can most digital synths be calibrated?
My DW-8000 has a certain wheeze on some notes...but I don't know if that's inherent and untreatable.
Too futurist to live.
michael stein
Band: S U R V I V E
Post by michael stein » Tue Jun 30, 2009 7:20 pm
madtheory wrote:and no crappy noises when you play chords.
I know this sound. Thanks for the tip didn't know you could fix this.
Post by madtheory » Tue Jun 30, 2009 11:00 pm
AstroDan wrote:Wow, didn't think you'd have to calibrate a digital synth. Can most digital synths be calibrated?
Even a digital synth has analogue bits! Furthermore, offset voltage seems to be an issue with older DACs, as far as I can make out anyway. Modern ones are more stable.
Go look for the DW-8000 service manual and see what can be done. If it's on the high notes, then it's probably aliasing- that's normal. I found the Casio one on the CZ Yahoo group. These are always a good source for info.
solderguy
Post by solderguy » Wed Jul 01, 2009 12:28 am
Thanks for posting this !
Will make sure to do this calibration when I finally get a CZ ! ( hankering for a CZ for some time now )
Operatron
Post by Operatron » Thu Oct 29, 2009 1:44 pm
thank you :)
Post by madtheory » Fri Oct 30, 2009 6:47 pm
You're welcome :)
Sexor
Gear: Prophet6, Jupiter-7, MS25, Juno-50, TR-303, Rhodes 63
Post by Sexor » Fri Oct 30, 2009 10:33 pm
I wonder if the JD-800 has something similar. I had one for a while and it sounded like 8-bit s**t.
Monkey business since 2007!
aeon
Post by aeon » Sat Oct 31, 2009 1:58 am
Sexor wrote:I wonder if the JD-800 has something similar. I had one for a while and it sounded like 8-bit s**t.
Yes, it does. I think Don Solaris has documented the process of calibrating the DAC.
cheers,
Ian
Mr Rich
Gear: Excessive.
Post by Mr Rich » Sat Oct 31, 2009 10:35 am
I know that sound too...
Mr Rich
(Eventually tired of Clint.)
Post by madtheory » Wed Mar 17, 2010 1:02 pm
FYI it is on page 59 of the service manual, which you can find here in the files section:
http://launch.groups.yahoo.com/group/CZsynth/
tekkentool
Real name: Steve
Band: none currently
Post by tekkentool » Wed Mar 17, 2010 11:00 pm
oh god i don't want to take off the keyboard of my cz-1, but the problems occurring sound exactly like the DAC's need calibration :(
tom Cadillac
Gear: FS1R, EPS, JP8000, Kaos pad, Ineko, SP606, Mopho, MP7 and so on....
Band: Bipolarbass
Post by tom Cadillac » Thu Mar 18, 2010 6:54 am
Do you know if the same stuff applies to the FZ1? I might be making a trip to the repair shop soon and might include the FZ1 on the 'to do' list? If I can hire a van that is! :D
"On the following day , the sorcery undespairingly continued: I changed my series, chose other sequences, cut other lengths, spliced different progressions, and hoped afresh for a miracle in sound." (Stockhausen)
Post by madtheory » Thu Mar 18, 2010 2:11 pm
tom Cadillac wrote:Do you know if the same stuff applies to the FZ1?
I don't know, but you can check the service manual, it's on that yahoo group also I think.
