Virus C - Got any tips?
ipassenger
Post by ipassenger » Wed Jul 29, 2009 3:04 pm
I got a Virus C quite recently and I am liking it a lot. I've noticed that the two filters in series with the distortion in between hides a lot of different tones. The effects are good for onboard ones, my Machinedrum sounded sweet getting mangled by them.
Any fellow users got any funky tips?
Joey
Band: BLUSH_RESPONSE
Re: Virus C - Got any tips?
Post by Joey » Thu Jul 30, 2009 3:57 am
use the analog 1 pole filter, crank resonance, crank osc volume
modulate delay time with an lfo on a random waveform
set oscillator FM mode to IN L or IN R or IN L+R for an instant Freqbox like effect with whatever you put through the virus and oscillator 2
and many more things...
http://wearereplicants.com
felis
Post by felis » Thu Jul 30, 2009 4:23 am
If you've got the keyboard version - set amplitude release time to max. Then in the mod matrix set a negative value for release velocity to mod the amp release till you get a nice snappy cutoff when you release the keys quick, and a nice long floaty release time when you release the keys slow.
After you get it dialed in, apply it to whatever gives you giggles - lfo speed/amp, filter cutoff or resonance - whatever works.
If you don't have the keyboard version, get a keyboard with release velocity to control it.
adhmzaiusz
Post by adhmzaiusz » Thu Jul 30, 2009 4:25 am
modulate the arpeggiator pattern with an lfo to get more patterns
the lfo flexibility is where its at with this synth, there are so many possibilities
polyklinik
Gear: VCO, VCF, THC, LSD
Post by polyklinik » Thu Jul 30, 2009 7:35 am
adhmzaiusz wrote:modulate the arpeggiator pattern with an lfo to get more patterns
huuh, sounds good! is it possible on the older versions? (A,B, Rack)??????
ipassenger
Post by ipassenger » Thu Jul 30, 2009 11:32 am
Joey wrote:use the analog 1 pole filter, crank resonance, crank osc volume
Ahh nice, I like the analog filter but I do miss the nastyness of the rectifier followed by another filter when I use it.
Joey wrote: modulate delay time with an lfo on a random waveform
Ahh cunning... :) Not tried either of these yet.
ipassenger
Post by ipassenger » Thu Jul 30, 2009 11:34 am
felis wrote:If you've got the keyboard version - set amplitude release time to max. Then in the mod matrix set a negative value for release velocity to mod the amp release till you get a nice snappy cutoff when you release the keys quick, and a nice long floaty release time when you release the keys slow.
Hmm.. ok have a desktop but am pretty sure my controller does rel vel. ;)
ipassenger
Post by ipassenger » Thu Jul 30, 2009 11:37 am
Not done this yet but read about it in the manual. Whilst I like arpegiators its all too easy to end up walking down the dodgy trance path. :D
The lfos are indeed very good, nice that you can use them as extra envelopes when necessary. Definately need to do more with them tho... The more time I spend with it the more I like it.
ipassenger
Post by ipassenger » Thu Jul 30, 2009 11:39 am
I'd imagine you can do it on the older ones.. Just look for Arp pattern in the destinations on the assignable modulation slots. :)
nuketifromorbit
Post by nuketifromorbit » Thu Jul 30, 2009 3:27 pm
I just picked up a C myself, its scheduled to arrive tomorrow. Just out curiosity when one scans the onboard wavetable with an lfo does it result in a smooth transition or in a IMO cooler ppg jagged transition? Sound on Sound seemed to hint that it resulted in the later, I'd just thought I'd ask her to make sure.
ipassenger
Post by ipassenger » Thu Jul 30, 2009 4:19 pm
Its prettyrough n glitchy, definately not smooth.
Yoozer
Post by Yoozer » Thu Jul 30, 2009 10:08 pm
It's not a wavetable but spectral waveforms (short, single cycle, looped); viz. Korg MS2000 DWGS.
nuketifromorbit
Post by nuketifromorbit » Fri Jul 31, 2009 2:38 am
Yoozer wrote:It's not a wavetable but spectral waveforms (short, single cycle, looped); viz. Korg MS2000 DWGS.
Yeah, thats what I figured, I just used the incorrect terminology. I always thought a wavetable was a set/collection of such waveforms?
Joey
Post by Joey » Fri Jul 31, 2009 5:45 am
yeah the TI's have wavetables, but not the C
felis
Post by felis » Fri Jul 31, 2009 10:22 pm
Modulating the delay time is always good for a WTF?
It works much nicer than most other synths.
