CV Compatibility between SH-101 and Mono/Poly
jsquarewave
Gear: Mono/Poly, SH-101, Prophet 600, SQ-80, ARP Omni, Paia Fatman, MicroKorg, Moog MF-102, Electrokraft Space*Synth, Fender Rhodes, Wayfar MidiNES
Band: Leaders, DeLorean Sunset
Post by jsquarewave » Thu Oct 01, 2009 11:47 pm
I've been playing analog synths for a few years now, but am now just recently getting into synching them via midi and CV. I know there are two or three different types of CV, and that none of them like each other. So my question is this: Are my SH-101 and Mono/Poly linkable without buying some kind of converter? I'm finding conflicting information on the interweb.
Thanks!
steveman
Re: CV Compatibility between SH-101 and Mono/Poly
Post by steveman » Fri Oct 02, 2009 12:22 am
They both use 1V/octave for pitch. The gates I'm not sure about but would be surprised it it didn't work. Just plug it in and try it, the worst that can happen is that it won't trigger.
Z
Post by Z » Fri Oct 02, 2009 12:27 am
Both synths are compatible as they both use Volt per Octave CV scaling. Usually, Korg uses Volt/Hz rather than Volt/Octave.
Here's a video I made last summer for a fellow VSE'r where I control a SH-101 & MonoPoly with a TB-303:
space6oy
Post by space6oy » Fri Oct 02, 2009 12:42 am
space6oy wrote:thanks for the replies reassuring me the mobius would cooperate w/ my MS-20! have one running it as i type :D
mobius' manual also has this little chart...
MAKE - - - - CV TYPE - - - GATE TYPE
ARP - - - - - V/OCT - - - - POSITIVE
KORG - - - - HZ/V - - - - - NEGATIVE
MOOG - - - - V/OCT - - - - NEGATIVE
ROLAND - - - V/OCT - - - - POSITIVE
SEQUENTIAL - V/OCT - - - - POSITIVE
YAMAHA - - - HZ/V - - - - - NEGATIVE
handy!
:thumbleft:
avmus
Post by avmus » Sat Oct 03, 2009 5:04 pm
I also attest to the compatibility of the two. I used to own them both and link the two all the time. Never had an issue with the gates. Both are great synths.. enjoy!
Computer Controlled
Gear: SH-101 . TB-3 . TR-8 . Juno-1 w/PG-300 . TT-303 . Korg ES2 . Beatstep Pro . Pioneer RMX-500
Band: Computer Controlled
Post by Computer Controlled » Sun Oct 04, 2009 7:48 pm
The Gate can be switched between - or + triggers. The M/P uses V/Oct however. I used my x0xb0x to sequence it when i had my M/P. The ARP can only be triggered via a -trigger though.
Synths:
Avalon Bassline . TB-03 . JU-06 . MX-1 . Blofeld . MicroMonsta . Akai S5000
Drum Machines:
TR-09 . TR-8
