Is it possible to make your own PCM cards or ROMs?
Z
Post by Z » Mon Nov 09, 2009 6:43 pm
OK, so I've seen some YouTube videos where Alesis HR-16 has been modded with custom samples. How is that done? Can I do it to a Roland R-8M? What would be involved in making your own PCM cards for a R8 or similar instrument?
balma
Real name: Mauricio
Re: Is it possible to make your own PCM cards or ROMs?
Post by balma » Mon Nov 09, 2009 7:14 pm
Actually, you can. But it's pretty expensive.
THE E-MU ULTRA can actually burn your own ROMS. But each writeable ROM cost $300-400 each one, as much as the Ultra itself.
And this personal ROM can be used on E-mu modern romplers like the command stations.
That's a dream to me: mangling my own samples on a command station. Just the idea of doing that gives me a hard on....
https://soundcloud.com/balma
D-Collector
Post by D-Collector » Mon Nov 09, 2009 8:16 pm
Z wrote:OK, so I've seen some YouTube videos where Alesis HR-16 has been modded with custom samples. How is that done? Can I do it to a Roland R-8M? What would be involved in making your own PCM cards for a R8 or similar instrument?
It would be awesome to just take some cheap old drummachine, Yamaha RX type or something, and just install a new rom with awesome samples. Would blow everyones mind. :lol:
Sir Nose
Real name: Bob
Post by Sir Nose » Mon Nov 09, 2009 8:46 pm
Sample eproms are easily swapped in and out on the SCI Drumtraks. The Oberheim prommer can be used to burn new eproms. Eproms are also readily available with already burned samples. But, I do not know about the R-8M though.
As far as I know ROMS written with the E-mu Ultra are only usable with certain e-mu devices (things that accept the proteus series ROMs)
all that is good is nasty
aredj
Gear: A little bit of E-muAccessJomoxKorgRolandRadikalTechnologiesMOOG
Post by aredj » Mon Nov 09, 2009 9:25 pm
And those emu roms have gone the way of the dodo...
IF I ever actually saw one for sale. . I likely couldn't afford it..
Z
Post by Z » Tue Nov 10, 2009 12:03 am
Sir Nose wrote:Sample eproms are easily swapped in and out on the SCI Drumtraks. The Oberheim prommer can be used to burn new eproms. Eproms are also readily available with already burned samples. But, I do not know about the R-8M though.
I'm familiar with burning your own EPROMS for the early machines (Linn, SCI, Oberheim, Simmons), but those are a single drum sound per EPROM (sometimes multiple EPROMS).
I'm pretty sure that new later PCM machines have all their sounds on a single ROM.
I really like the R-8M, but would love to update the sounds. It would also be nice to have a ROM chip with even more sounds. Not sure how much is already loaded in there, but surely we have the technology for at least quadruple what's already in there.
Post by Stab Frenzy » Tue Nov 10, 2009 1:50 am
Digidesign started out as a company making custom ROMs for the Linndrum (IIRC) and look where they ended up. As people have already said, it can be done, but it's not really cost-effective these days when there are so many cheap samplers around.
gmeredith
Band: Warning Will Robinson
Post by gmeredith » Tue Nov 10, 2009 4:37 am
It's completely possible. These guys are doing it for the HR16 and Kawai R100 and others. The Roland would be no different in process I wouldn't think. Get in contact with them, they might help you try:
http://www.burnkit2600.com/diy-sound-roms/
http://www.burnkit2600.com/kawair100/
Cheers, Graham
Z
Post by Z » Tue Nov 10, 2009 4:51 am
Thanks, Graham. I just emailed them.
gmeredith
Post by gmeredith » Tue Nov 10, 2009 5:36 am
This guy here has made his own TR626 ROMS, which can't be far off an R8:
http://www.nekosynth.co.uk/wiki/RomHacker
He was on that other site going through the progress of it with them here:
http://www.burnkit2600.com/tr-626-rhythm-decomposer/
Cheers, Graham
crystalmsc
Band: Crystaline
Post by crystalmsc » Thu Nov 12, 2009 8:50 am
The Zadok SAM-1 for Wavestation, M and T series. Also the Alesis QS line allows sample transfer to the PCMCIA card through Soundbridge.
Kaossilatron - Voicillator
desdinova
Post by desdinova » Fri Nov 13, 2009 2:27 am
I've made custom PCMCIA flash cards to use in my QS, it's kind of a pain to find 100% legit working cards, especially for any kind of sane price.
rerum concordia discors | genre: wankery
gmeredith
Post by gmeredith » Fri Nov 13, 2009 2:55 am
What did you use to make your own QS cards? I was kind of interested in a rack QS a while ago for my own samples but got put off by the price of the cards
Cheers, Graham
polardark
Post by polardark » Fri Nov 13, 2009 3:18 am
Burning your own sample eeprom for older sample playback units is cheap. You just need an eeprom burner and an empty eeprom of a suitable size. Of course it helps if you know the format of the data you're trying to put in there as well and you should probably know your way around a hex editor.
desdinova
Post by desdinova » Fri Nov 13, 2009 3:58 pm
gmeredith wrote:What did you use to make your own QS cards? I was kind of interested in a rack QS a while ago for my own samples but got put off by the price of the cards
I used their software, soundbridge. If your QS is original though, you can't burn the cards, just read them. Only the S4+ and the qs6/7/8 keyboards can, iirc. Maybe the QS Piano+, too, I forget.
