I'm looking for some gnarly bass sounds for my minimoog...
Savitar
Post by Savitar » Thu Nov 26, 2009 11:03 am
Got a minimoog voyager and I'm looking to get some dirty, raunchy-as-****, bass sounds to play around with. something with a house/electro vibe. anyone got some patch ideas?
Syn303
Gear: Quite a bit...
Band: Syn303
Re: I'm looking for some gnarly bass sounds for my minimoog...
Post by Syn303 » Thu Nov 26, 2009 11:28 am
there are a couple of patch books for the minimoog, these will also work on the voyager series. I only have the minimoog patch book II, as i can't seem to find the 1st one. here is a link to get you started though: http://songinbooks.blogspot.com/2008/05 ... ok-ii.html
tekkentool
Real name: Steve
Band: none currently
Post by tekkentool » Thu Nov 26, 2009 12:19 pm
just get in there and make some come on ;)
Sexor
Gear: Prophet6, Jupiter-7, MS25, Juno-50, TR-303, Rhodes 63
Post by Sexor » Thu Nov 26, 2009 1:10 pm
Sorry, the Voyager doesn't do electro-bass. Get an EA-1. It's got better presets.
edit: ok sorry, stupid/nasty comment, but seriously did you ever try turning those knobs yourself?
Monkey business since 2007!
Savitar
Post by Savitar » Thu Nov 26, 2009 6:35 pm
Of course. But I'm but a student to the diverse sounds and aural manipulation of complex synthesizer electronics. That's why I'm here.
Hair
Post by Hair » Thu Nov 26, 2009 6:38 pm
aren't most modern electro-house bass sounds essentially 2-osc closely tuned saws or squares with wide open filters?
Solderman
Post by Solderman » Thu Nov 26, 2009 8:50 pm
Mute Osc3. Use the pedal bus to send Osc3 to filter and set resonance at around 3 or 4. Use the modwheel bus to send low-speed LFO to Wave. Tune Osc 2 to taste.
--Solderman no more.
Savitar
Post by Savitar » Thu Nov 26, 2009 9:25 pm
Awesome. Thanks man.
FrankieMusic
Post by FrankieMusic » Thu Dec 03, 2009 7:31 am
I have a recipe for a heavy bass sound. I discovered it myself. Basically it sounds like a much heavier and fatter version of a singlular sawtooth wave.
Set oscillator 1 to 32'. Make it a square wave (a pure square wave to start with). Set oscillator 2 to 16' and make it a sawtooth wave. Set the fine tune knobs on each to the center position. Use the filter and envelopes as you see fit.
Do it and tell me what you think!
otto
Post by otto » Thu Dec 03, 2009 9:21 pm
Savitar - just a tip. If you refer to your Moog as a Voyager rather than a minimoog your subjects will be a lot clearer. I realize Moog call it a “Minimoog Voyager” but most people associate minimoog with the original minimoogs, model D, what have you. Most people call the new “Minimoog Voyagers” just Voyagers to have a clear distinction as they are different in many ways.
hello darkness, my old friend
Savitar
Post by Savitar » Thu Dec 03, 2009 9:47 pm
def a fat bass. i'm also looking for like 80's bass effects. funky s**t too!
michael stein
Band: S U R V I V E
Post by michael stein » Thu Dec 03, 2009 9:53 pm
Run headphone output back into filter input with patch cable. Headphone volume will control amount of grit/distortion.
shaft9000
Real name: Dave
Band: moneymoneymoney
Post by shaft9000 » Fri Dec 04, 2009 1:00 am
set OSC 2 to (hard)Sync. route filter EG to modulated OSC2 frequency. vary modulation amount and the filter EG's attack and decay times while playing. also change the waveshape for different "sync textures".
Savitar
Post by Savitar » Fri Dec 04, 2009 3:13 am
hard sync being the 1-2 sync on/off switch?
Savitar
Post by Savitar » Fri Dec 04, 2009 3:21 am
And how do I rout the filter EG?
