c-ya
- OriginalJambo
- Gear: Check my sig
Re: synths in the cold......
I'm in the same situation as you now that I've moved a s**t load of my gear to another premises. At first the room wasn't heated and I didn't have much trouble but now that the nights are getting much colder I've installed a few heaters. One night I forgot to leave the heaters on the anti-freeze setting and stupidly left it for another day.
As the temperature outside was really plummeting I decided to go check all the gear was okay. First thing I powered on was the Polysix. Now all the LEDs usually flash briefly when you hit the power switch, but for some reason they stayed illuminated and nothing seemed to work! I panicked and then phoned my synth tech who told me it'd either be a power supply issue or a panel scanning issue. Fortunately he also mentioned that when he gigged his old Memorymoog it would refuse to work if the conditions weren't acceptable, so severely hoping (and doubting!) this would be the case I rushed it home.
I stuck it in the most well-heated room in the house for about 2 hours and had a look inside. Nothing seemed out of place so I crossed my fingers and powered it up. Thankfully I was extremely lucky - it fired up as if nothing had happened and one of the patch buttons that never seemed to work had somehow miraculously fixed itself.
Anyway, I went back and powered up the rest of the gear - a DX7, a JX-10 and a V-Synth. And the rack gear too. No problems whatsoever.
So based on my experience if it's a fragile, old synth I seriously wouldn't recommend it - my Polysix is now safe at home, as is the rest of my analogue gear. Sure in this instance it was likely some sort of safety net KORG had implemented in the unit that caused it to seize up, but I'd still say that you should avoid it if possible!
- Z
I was going to ask a similar question. I've got a couple of Rhodes sitting in my warehouse and Texas temps are now getting low. I really don't have room to move them into one of my offices (my fellow Dallas VSErs can attest to my limited office space cluttered with synths), but could make room if it is a life or death issue for the pianos.
- Old Iron Giant
- Gear: Virus Ti2, Indig2, EmuXL7, Microkorg.
- Band: KHz+
check your user manual-
It should tell you the optimum temperatures for operation, and the damage point of High / Low temp's.
Humidity is the enemy.
will do. thanks...
pointless tread now
- pflosi
a mate told me once that he used to put his 303 in the freezer before recording cause it sounds better then
- Expert Member
Last edited by clubbedtodeath on Fri Dec 18, 2009 12:05 am, edited 1 time in total.
- TrondC
- Gear: Machinedrum UW & Monomachine Mk2's
Korg KP3 & Zero 4 - Band: Siesta Submarina
totally OT, but Old Iron Giant, that avatar... W T F?
I love japaneese utter randomness
- stephen
- Gear: Laptop
House Brick
Renoise
Loomer Aspect
FM8 - Location: UK
Re: c-ya
This is weird.... someone quits and then there's some weather talk....
Edit: oh wait, looks like a wrong-thread post. Oops... (exit stage left, whistling nonchalantly)
Stephen(2)
- space6oy
TrondC wrote:totally OT, but Old Iron Giant, that avatar... W T F?I love japaneese utter randomness
- Stab Frenzy
I wonder how he found that out in the first place?pflosi wrote:a mate told me once that he used to put his 303 in the freezer before recording cause it sounds better then
Re: c-ya
Was the OP embarrassed by his question or something?
Did someone attack him in the thread?
Why so many edits and the "c-ya, I'm out" thing? I'm confused...
.....i have some things that create and sculpt sound.
- pflosi
I don't know... good questionStab Frenzy wrote:I wonder how he found that out in the first place?pflosi wrote:a mate told me once that he used to put his 303 in the freezer before recording cause it sounds better then
- tekkentool
- Real name: Steve
- Band: none currently
my guess is he was high.pflosi wrote:I don't know... good questionStab Frenzy wrote:I wonder how he found that out in the first place?pflosi wrote:a mate told me once that he used to put his 303 in the freezer before recording cause it sounds better then
where's dr. sine around when you need high advice?
