Japan "Burning Bridges"- what synths?
iProg
Real name: Carl
Gear: Prophet-5, Korg PolySix, Roland D-50, JV-1080
Band: ArtWithHeart
Re: Japan "Burning Bridges"- what synths?
Post by iProg » Wed Feb 02, 2011 11:49 am
Micke: In the beginning of the second verse in "Ghosts" there is a drifty slop-detuning soft brass playing some notes. Is that the P5 or OB-X?
Micke
Post by Micke » Wed Feb 02, 2011 4:28 pm
The OB-X does the detuned melody as well as the sustained chords. The staccato chords are from the P5.
iProg
Real name: Carl
Band: ArtWithHeart
Post by iProg » Wed Feb 02, 2011 4:32 pm
Allright!
I've been listening a lot to my Japan CD's recently, sadly due to the tragic passing of Mick Karn.
Are there any other Polymoog parts than the Nightporter strings?
Micke
Post by Micke » Wed Feb 02, 2011 6:23 pm
Yes, the Polymoog was also used on Quiet Life, Rhodesia and European Son (although the latter could be an ARP Omni, or both).
Barbieri also used a Mellotron on some of the earlier tracks, try to see if you can figure out which ones ;-)
Micke
Post by Micke » Fri Feb 04, 2011 2:57 pm
So have you figured out yet which songs with Japan that feature the Mellotron :?:
iProg
Real name: Carl
Band: ArtWithHeart
Post by iProg » Mon Feb 07, 2011 11:05 am
Micke wrote:So have you figured out yet which songs with Japan that feature the Mellotron :?:
Haven't noticed any mellotron on either Tin Drum or GTP, so if I'm not mistaken it has to be on some of the older albums...which I haven't heard yet.. :?
Micke
Post by Micke » Mon Feb 07, 2011 3:23 pm
You guessed right, there is no mellotron on GTP nor Tin Drum. I'm not sure though what was used for the choir-ish sounds towards the end of "Swing"...could be a VP-330.
iProg
Real name: Carl
Band: ArtWithHeart
Post by iProg » Mon Feb 07, 2011 3:49 pm
Micke wrote:You guessed right, there is no mellotron on GTP nor Tin Drum. I'm not sure though what was used for the choir-ish sounds towards the end of "Swing"...could be a VP-330.
It reminds me of a choir-ish sound that Queen used, and I saw a studio video of the recording of "One Vision" and "Innuendo" where I think the VP-330 was featured.
prophonic
Post by prophonic » Thu Jan 24, 2019 11:44 pm
@Micke: do you know which keyboards were used by Richard live on tour before the GTP album ?
I just wonder if he used any sequencer in '79 when they started to play European Son.
There is a bootleg from 79 at Budokan and the intro 'sequence' is speeding up.
Thanks.
Micke
Post by Micke » Fri Jan 25, 2019 9:26 pm
If I recall correctly for the '79 tour Richard used the Micromoog, Roland 700 'laboratory system" controlled by an Oberheim mini-sequencer,
ARP/Solina string ensemble and a Wurlitzer electric piano.
prophonic
Post by prophonic » Sun Jan 27, 2019 8:22 am
Amazing info, thanks Micke. I assume he didn't have the chunky Roland effects units (Space Echo, SBF-325) with him on tour, so probably MXR pedals ?
Lukcook
Post by Lukcook » Wed Feb 06, 2019 11:20 pm
prophonic wrote:Amazing info, thanks Micke. I assume he didn't have the chunky Roland effects units (Space Echo, SBF-325) with him on tour, so probably MXR pedals ?
Hello
I would really apreciate if you could answer me this questions.
I have a DSX Sequencer and the Oberheim OB8.
Can this sequencer save different patches on each track? For example, Bass part on sequence 1 track 1. And string part on sequence 1 and track 2.
I was trying everything. The manual mentions the 0 button. This 0 button saves the patches and splits. But can it save different patches for each track??
Thanks for everything and sorry for interuption.
Cheers
Luka
tim gueguen
Post by tim gueguen » Thu Feb 07, 2019 11:20 pm
No, the OB8 is bitimbral. You can only get two different sounds out of it at once.
