tr-909 - sample based?
solaristica
Post by solaristica » Fri Mar 05, 2010 4:20 pm
I just saw some Roland executive of the nineties saying on Modulations that great electronic music documentary that the TR 909 is sample based... Doesn't that disqualify it as "analogue" ?
griffin avid
Re: tr-909 - sample based?
Post by griffin avid » Fri Mar 05, 2010 4:28 pm
I always thought (like most drum machines) that certain elements like clap and snap were sample based.
Where's the link to that video? I'd like to see it too.
kuroichi
Post by kuroichi » Fri Mar 05, 2010 4:34 pm
The hi hats and cymbals are samples, all the other sounds are analogue.
roland4387
Gear: TB-303(x's 2), EML 101, System 100 Model 101, TR-808 & 606, SH-2, ARP Odyssey MKII, Korg MS-20, Xbase999, Korg KMS-30, SBX-80, Future Retro Mobius
Post by roland4387 » Fri Mar 05, 2010 4:36 pm
Kick, snare, and toms are analog. All the rest are 8 bit samples.
Syn303
Gear: Quite a bit...
Band: Syn303
Post by Syn303 » Fri Mar 05, 2010 4:39 pm
The 707 is all sample based and it's the cheaper version of the 909, but the 707 is sound of chicago acid house though.
solaristica
Post by solaristica » Fri Mar 05, 2010 4:46 pm
So it's sort of a hybrid... analogue and digital sample... Thanks for clarifying.
Someone posted the entire movie on YouTube. "Modulations"...
About 8:30 minutes the Roland guy comes in... The whole movie is worth checking it out though...
micahjonhughes
Post by micahjonhughes » Fri Mar 05, 2010 6:28 pm
There are three 8-bit samples used by the 909: one for the hi hats, one for the crash, and one for the ride. All of the other sounds are fully analog, including the clap.
kuroichi
Post by kuroichi » Fri Mar 05, 2010 9:58 pm
roland4387 wrote:Kick, snare, and toms are analog. All the rest are 8 bit samples.
looking at your equipment list and reading this just confused me.....
nathanscribe
Post by nathanscribe » Sat Mar 06, 2010 12:37 am
micahjonhughes wrote:There are three 8-bit samples used by the 909: one for the hi hats, one for the crash, and one for the ride. All of the other sounds are fully analog, including the clap.
Top marks. Extra house-points could have been obtained by explaining that the noise source for the snare, claps, etc, is digitally generated using CMOS, unlike the 808, for example, which uses a transistor.
:ugeek:
micahjonhughes
Post by micahjonhughes » Sat Mar 06, 2010 12:54 am
I'll admit that I don't understand how CMOS chips generate "digital" noise. We could debate whether noise generated by CMOS chips or amplified circuit noise is better. Beats the DCO v. VCO battle.
nathanscribe
Post by nathanscribe » Sat Mar 06, 2010 12:56 pm
While a true analogue noise source is a voltage fully variable over a wide range, CMOS-generated noise is either up or down. On a scope it looks like a pulse wave gone apeshit - a seemingly random mixture of wide and narrow pulses and gaps changing fast. Sonically, I'm guessing here to some degree, but I expect this has a similar effect to mixing a bunch of randomly varying high-frequency square waves - which is similar to how the noise is generated for 606/808 cymbals (they use something like 6 simultaneous square waves at fixed frequencies).
It's not truly random though - the noise is a cycle that will repeat over time. How long it takes depends on the configuration of the circuit - the number of stages in the shift register that forms part of it. The 909 uses two 4006 (14-stage I think), with multiple tap-off points, which is about as close to random as I've seen a circuit like this get.
Some synths used an all-in-one chip for noise, which I can't recall the name of right now - it's in the Moog Rogue, for example - and that I suspect is digital, as the noise audibly cycles when you listen to it in isolation. Not a massive problem in most patches though, I find.
Yoozer
Post by Yoozer » Sun Mar 07, 2010 2:12 pm
nathanscribe wrote:Top marks.
I thought 6-bit, not 8-bit. At least, that's what http://www.colinfraser.com/tr909/my909.htm says.
micahjonhughes
Post by micahjonhughes » Sun Mar 07, 2010 6:07 pm
The samples could be 6-bit.
nathanscribe
Post by nathanscribe » Sun Mar 07, 2010 6:47 pm
Oops, yeah I'd forgotten about that. They come out through 6-bit DACs. I lose. :oops:
Computer Controlled
Gear: SH-101 . TB-3 . TR-8 . Juno-1 w/PG-300 . TT-303 . Korg ES2 . Beatstep Pro . Pioneer RMX-500
Band: Computer Controlled
Post by Computer Controlled » Mon Mar 08, 2010 7:04 am
Modulations, while fun to watch, isn't exactly the place to go to for true facts. As already stated, the HHs and cymbals are 6 bit samples. The rest is all analogue.
Synths:
Avalon Bassline . TB-03 . JU-06 . MX-1 . Blofeld . MicroMonsta . Akai S5000
Drum Machines:
TR-09 . TR-8
