Lots of LFOs
JackAstro
Lots of LFOs
Post by JackAstro » Fri Aug 20, 2010 11:48 pm
What synths have a lot of LOFs?
The Matrix 12 had 5 and the DSI stuff has 4. Please list some more.
Roby31
Real name: Roberto
Gear: Waldorf Micro Q (Yellow)
Access Virus TI 2 Desktop
Casio VL-1
Re: Lots of LFOs
Post by Roby31 » Sat Aug 21, 2010 12:08 am
Waldorf Q/uQ have three, but with their awesome "modulate everything with everything" you can set an extremely low pitched 2nd or 3rd oscillator to slowly modulate other parameters when you don't need their sound
Sorry for my unintentional killing of the English language. I'm Italian, you know :) - "What would Jexus do?" - Stew-diah
smoothcriminal
Real name: Matt
Re: Lots of LFOs
Post by smoothcriminal » Sat Aug 21, 2010 12:30 am
ESQ1 has 3
Jabberwalky
Band: Variar
Re: Lots of LFOs
Post by Jabberwalky » Sat Aug 21, 2010 2:23 am
If you consider a low pitched VCO to be an LFO than the evolver had 8. It's could be modulated as such.
Re: Lots of LFOs
Post by Stab Frenzy » Sat Aug 21, 2010 6:25 am
The Nord Modular G2 has about 50 or so, haven't actually tried to see how many I can fit in a patch but it's a lot.
I love LFOs.
retrosounds
Re: Lots of LFOs
Post by retrosounds » Sat Aug 21, 2010 6:30 am
The Korg Z1has 4.
And the Korg WaveStation has 2 LFOs for for each wave, so in total it has 8.
"Imagination is priceless"
"I bless the rains down in Africa"
Re: Lots of LFOs
Post by Stab Frenzy » Sat Aug 21, 2010 6:35 am
Oh Yeah, V-Synth has one for each Osc, filter etc. Maybe 8 or so all together? Haven't ever counted them.
ninja6485
Band: Subliminal Sea
Re: Lots of LFOs
Post by ninja6485 » Sat Aug 21, 2010 6:52 am
the korg radias has 2 dedicated lfo's, but 3 mod sequencers, which can be set to either wave or step, and are essentially 3 more extensive lfo's. plus you can assign 6 destinations to be modulated (which is including the lfo's.) so in total, you can modulate 9 things, with 5 of those things being a a different lfo or equivalant. 8-)
also, the virus ti has 3, but a huge matrix mod section which can cross modulate almost everything with almost everything else. the only thing i couldn't figure out was how to get it to modulate the filter env. attack and then have the filter env. attack modulate the release, and then the release modulate the decay, and so on. i could only use the envelope as a whole. otherwise extensive is an underastatement.
Zamise
Gear: Rollhand P00
Band: Quantum-Source
Re: Lots of LFOs
Post by Zamise » Sat Aug 21, 2010 7:31 am
The RT's Spectralis has at least 10 LFOs on the "Analog" mono syth part alone. 4 master LFOs and 6 additional LFOs. Plus, also use an input as well as a modulation source if you count that as LFO. I think you'll have to have at least one be the sound source though, unsure, there may be more LFOs?
sam
Re: Lots of LFOs
Post by sam » Sat Aug 21, 2010 8:40 am
The A6 is very flexible on the lfo front... :idea:
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
CS_TBL
Gear: All "In-The-Box"
Mainly FM8
Re: Lots of LFOs
Post by CS_TBL » Sat Aug 21, 2010 9:20 am
In FM synthesis, each operator could be used as an LFO, depending on the algo and on how aren't being used as carrier.
FM8 vids
I12
Re: Lots of LFOs
Post by I12 » Sat Aug 21, 2010 10:30 am
Mono Machine 3 per voice making it 18 for the 6 parts.
having parameter locks and slides give you plenty of scope as well
Dont bother its not worth it!
Hugo76
Re: Lots of LFOs
Post by Hugo76 » Sat Aug 21, 2010 11:25 am
Waldorf Blofeld has 3 per voice, so I guess in total it's 3x16.
pflosi
Re: Lots of LFOs
Post by pflosi » Sat Aug 21, 2010 11:52 am
sam wrote:The A6 is very flexible on the lfo front... :idea:
jep, it has 3 lfos, 3 loopable envelopes and both oscs can be used as modulation sources (they can be tuned very low if desired)
Re: Lots of LFOs
Post by meatballfulton » Sat Aug 21, 2010 2:39 pm
Jabberwalky wrote:If you consider a low pitched VCO to be an LFO than the evolver had 8. It's could be modulated as such.
6 actually, you can't use the analog oscs as modulators, only the digital ones.
