CZ-101 Memory solutions!!!!
slumbermonkey
Gear: Casio CZ101, SK1
Elektronika EM25
Paia Fatman
Etherwave Theremin
Korg Kaoss Pad 3
Akai APC40
Post by slumbermonkey » Tue Dec 14, 2010 11:22 pm
I have a CZ101 that I love to death but I want to stomp on its ugly interface every time I attempt to save a patch only to find it gone a week later. RA-3 cartridges are all but extinct it seems, I've heard of software patch libraries though, does anyone have a recommendation for a good Mac-based one? Or perhaps some other method for saving patches...?
solid state hive mind.
myspace.com/stevewoodzell
Re: CZ-101 Memory solutions!!!!
Post by madtheory » Tue Dec 14, 2010 11:35 pm
Try this maybe? I haven't used it myself:
http://www.sonicspot.com/soundlib/soundlib.html
Post by meatballfulton » Tue Dec 14, 2010 11:48 pm
CZEditor might work.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Wed Dec 15, 2010 1:22 am
Some guy on a CZ board was talking about cloning the RA-3 cartridge. Lemme see if I can find the link.
- Confucius
Juno6
Post by Juno6 » Wed Dec 15, 2010 3:05 am
A friend of mine did the following... he put an adaptor for iirc 3 AA batteries instead of the 6 big batteries. Apparently, that is not enough to power on the synth, but it´s enough to retain the internal patches.
Cheers.
slumbermonkey
Elektronika EM25
Paia Fatman
Etherwave Theremin
Korg Kaoss Pad 3
Akai APC40
Post by slumbermonkey » Wed Dec 15, 2010 4:39 pm
Thanks for the replies, very helpful. I'm curious about the battery thing - I'm able to retain patches for a matter of hours or days sans batteries. Long term internal storage needs batteries though, it seems...? I worry about remembering to change the AA's using that method. Externalizing seems like the best way, I was hoping for something along the lines of that RA-3 clone, if that is indeed possible.
Juno6
Post by Juno6 » Thu Dec 16, 2010 4:56 am
slumbermonkey wrote:Thanks for the replies, very helpful. I'm curious about the battery thing - I'm able to retain patches for a matter of hours or days sans batteries. Long term internal storage needs batteries though, it seems...? I worry about remembering to change the AA's using that method. Externalizing seems like the best way, I was hoping for something along the lines of that RA-3 clone, if that is indeed possible.
Here´s a topic about the battery mod.
http://www.vintagesynth.com/forum/viewt ... =5&t=56973
They´re supposed to last 9 months or more, so if you back up once in a while, I can´t think of any reason why you shouldn´t try it.
Cheers.
gmeredith
Band: Warning Will Robinson
Post by gmeredith » Thu Dec 16, 2010 6:09 am
Here you go:
gmeredith
Post by gmeredith » Thu Dec 16, 2010 6:12 am
gmeredith
Janis 1279
Post by Janis 1279 » Fri Aug 31, 2018 3:39 pm
Hi,
Thanks gmeredith,
Tested a 64-patch CZ RAM cartridge schematic with a one RAM chip HY6264. Only exception is inverted signal necessity from cartridge slot 6 pin as CS2 inverted as it goes in this schematic to IC2 pin 26. The schematic is like to EZ-CZ cartridge schematic for 4x16 patches, I thought.
briandc
Real name: brian
Gear: 3 Midi controllers and anything linux! :)
Post by briandc » Thu Sep 06, 2018 10:12 pm
Found this:
Hth!
brian
LinuxSynths.com
amSynth on Soundcloud
BritSynths
Post by BritSynths » Mon Sep 10, 2018 12:52 pm
That looks perfect
I've ordered one straight away
DW8000,MS2000B,JX3P,PG200,SH-32,JV-1010,MU90R, TX81Z,CZ101,VZ8M, Drumstation,AStation,XR10,RT-232,VirusB,K4R,Proteus 2000:Oscar,PhilipRees CSF,C16,Roland Gaia, Studiologic Sledge,Quasimidi Quasar,NanoSynth,NanoBass,Korg 03/RW, SR-88
