IC's long gone..
sqweebking
Gear: Roland, Moog, Yamaha, Korg, Novation, etc.
Band: sqweebking
IC's long gone..
Post by sqweebking » Fri Dec 17, 2010 3:54 am
So ive been wondering what will we do when the stock of all the rare and discontinued IC's from our coveted analog synths dries up. I was thinking last night about my Mono/Poly, im pretty sure its got a failing voice, which would most likely require replacing one of the SSM 2033 IC's that have been long discontinued. I know they can still be found every now and then, but what happens when they cant be? Is there any way to prolong the life of the remaining chips or prevent them from going wrong in the first place? For instance the Juno 106, it seems that most failed vcf chips can be mended by removing the coating from them. So thats a somewhat easy fix if the chip hasnt completely failed, but what about other IC's. Is there any rhyme or reason for them failing? Maybe a cheaper part up or downstream from it caused the failure?
Im obviously no electronic engineer, but id be curious what one had to say about this matter. I know these synths are getting old, and a lot of them need caps, op amps, etc. replaced or are these IC's just prone to fail after an undetermined length of time too? I was also curious what it might take to get a run of chips made? Datasheets for old discontinued chips are readily available but could they be duplicated somehow?
8bit9bot
No Longer Registered
Re: IC's long gone..
Post by 8bit9bot » Fri Dec 17, 2010 4:06 am
i worry about this stuff too ._.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Fri Dec 17, 2010 4:43 am
Last I heard, a run of custom ICs (including design of the dies) was about $100,000. Maybe some of the China places are hungry enough to go lower. A cheaper dirty solution would be to design small boards with the ICs in question duplicated by a group of modern chips. Maybe a flex cable to go to the original socket or pads.
The miniscule number of vintage synth nuts (compaired to the total of all nuts on the Earth) will no doubt scare anyone from attempting a large-scale repro pf the various chips. Been my dream for some years, but I'll have to leave that for you younger gents.
In the meantime, as chips get more and more scarce, the prices will go thru the roof... those who can afford them will have them...those who can't will go begging.
EDIT: Maybe in the future someone will design a single chip that can be programed to emulate many vintage chips.
Maybe in a surface-mount package that could be mounted on the correct-pinned header.
- Confucius
sqweebking
Band: sqweebking
Post by sqweebking » Fri Dec 17, 2010 4:58 am
To me, 100 people willing to pay $100 each for a chip that has failed and crippled a beloved synth doesnt sound too far fetched. Maybe im crazy, but one day it could come down to that..
As far as building replica's on small pcb's that could be pinned out to match the existing sockets or pads, would that run the risk of any copyright or patent infringement? If I had the knowledge id be more than willing to put in the time to help with such a project but for now it may have to remain a dream.
adhmzaiusz
Post by adhmzaiusz » Fri Dec 17, 2010 5:44 am
sqweebking wrote: As far as building replica's on small pcb's that could be pinned out to match the existing sockets or pads, would that run the risk of any copyright or patent infringement?
Hmmm this is a good question, because I know that actual circuits can be copyright but if you take a schematic and draw the circuit in a different way i'm pretty sure its not copyright. But within an IC theres no way of really seeing the circuit inside, when it could be a totally different circuit and same pin out.
Funny thing is, with the roland chips specifically ie the ba662, it is just a quad op amp which could probably be made pretty easy I assume. Be nice if some millionaire musician decided to reproduce these chips for the good of the earth.
Hybrid88
Post by Hybrid88 » Fri Dec 17, 2010 6:41 am
Yes, this does concern me too. Though I'd rather have the task of looking for CEM chips than the custom one's in the CS-80, or SSM's for that matter.
sqweebking wrote:To me, 100 people willing to pay $100 each for a chip that has failed and crippled a beloved synth doesnt sound too far fetched. Maybe im crazy, but one day it could come down to that..
Except 100 x 100 is 10,000, not the 100k Rhino said it'd cost :)
nathanscribe
Post by nathanscribe » Fri Dec 17, 2010 11:07 am
adhmzaiusz wrote:Funny thing is, with the roland chips specifically ie the ba662, it is just a quad op amp which could probably be made pretty easy I assume. Be nice if some millionaire musician decided to reproduce these chips for the good of the earth.
No it's not, it's a single OTA, like the CA3080, which is also out of production. But your general point stands, that there are several chips labelled by manufacturers with their own codes that can be substituted with generic equivalents.
sqweebking
Band: sqweebking
Post by sqweebking » Fri Dec 17, 2010 12:35 pm
Lol drunk math fail..
Altitude
Post by Altitude » Fri Dec 17, 2010 1:26 pm
PPl just need to start cloning the circuits with modern components. Already been done for the Juno chips and the BA662
th0mas
Band: GRAVITRONIC
Post by th0mas » Fri Dec 17, 2010 3:06 pm
As an avid DIYer with few vintage boards the looming crisis I most worry about is the trend for manufacturers to stop making their chips available in DIP and instead only SMD footprints. I'm getting older, not younger.. I don't see my accurracy improving to that degree :/
adhmzaiusz
Post by adhmzaiusz » Fri Dec 17, 2010 5:44 pm
Oh yea you are right, I was thinking of the IR3109 which is a quad something or other
cornutt
Gear: 6th
Post by cornutt » Fri Dec 17, 2010 6:00 pm
It's a quad OTA.
nathanscribe
Post by nathanscribe » Fri Dec 17, 2010 7:03 pm
I should add the 662 is also buffered internally, whereas the 3080 isn't, so it's not a direct replacement (pinout regardless).
I've seen some things cloned using PICs, but I have no idea how well they work:
http://www.electricdruid.net/index.php?page=projects
Computer Controlled
Gear: SH-101 . TB-3 . TR-8 . Juno-1 w/PG-300 . TT-303 . Korg ES2 . Beatstep Pro . Pioneer RMX-500
Band: Computer Controlled
Post by Computer Controlled » Fri Dec 17, 2010 11:03 pm
The BA6110 is a direct replacement for the 662.
Synths:
Avalon Bassline . TB-03 . JU-06 . MX-1 . Blofeld . MicroMonsta . Akai S5000
Drum Machines:
TR-09 . TR-8
sqweebking
Band: sqweebking
Post by sqweebking » Sat Dec 18, 2010 5:44 am
Sure there are modern equivelents to be used, and thankfully still analog synths being made. Are there any ways to prolong the existing IC's though? Or do we have to deal with the fact that one day these synths may die forever? :cry:
