Any one knows which synth creates this distinctive metallic clavi sound in Something about you song:
I came fairly close with the Prophet 5 but couldn't 100% nail it so I wonder if this could be sample from the Emulator? I'm also pretty sure it's not a DX7.
Technically, it's probably a TX-816 sound. Mike Lindup also had a TX-816 as well. It's a little more robust than a regular DX7 sound, and I've tried to program the same clav sound to no avail.
The polysynth sounds and pad sounds are definitely Prophet 5 though.
Re: Level 42 Something about you Clavi sound?
Posted: Sat Feb 12, 2011 4:14 pm
by Lucien
Many thanks for theinfo. The reason I didn't think it was the DX7 was that at the Wembley live video he had the TX816 and I didn't see those lights flashing when you hear the sequence and he used the DX7 for another sound.
Second in one of the live performances he played that sound on his Prophet 5 (but can't remember if it really sounded similar).
That said I certainly think the DX7 would be capable of that sound so will see if I can program that (earlier attemps I didn't quite get close to it but with DX7 you have huge # of parameters).
I wonder how reliable the DX7 famous examples page is?
Posted: Sat Feb 12, 2011 11:09 pm
by Lucien
I went through the DX7 library and certainly find clav sounds that sounds the same (with just 3 operators) except for the attack itself. If I slow the original sound it sounds pretty typical though still hard to reproduce:
Posted: Sun Feb 13, 2011 7:18 pm
by Lucien
I went through huge # of DX7 sounds but just couldn't quite get the attack sound correctly (although I think it still may be possible since it's definitely cross modulation).
Then I went back to Prophet 5 and notice with the polymod you actually get very close to that attack sound (perhaps only needed is to add right effect):
Edit: updated dead link (original recording and playing over it repeatedly for comparison):
I checked again sustain sound and I kind of expect that's Prophet as well but not sure.
Posted: Sun Feb 13, 2011 8:16 pm
by Lucien
Ok I think I got it figured out: I'm fairly sure it's all Prophet 5. The short attack sound has a low cutoff while the long sustained sound uses high cutoff. I couldn't quite get this right in the envelope though it might be possible.
But instead I could repro it assigning the filter to the modulation wheel. When you play the long sound you increase the modulation wheel all the way up.
Posted: Thu Feb 17, 2011 11:07 am
by elsongs
Lucien wrote:Ok I think I got it figured out: I'm fairly sure it's all Prophet 5. The short attack sound has a low cutoff while the long sustained sound uses high cutoff. I couldn't quite get this right in the envelope though it might be possible.
No way you can get those harmonics on a Prophet-5. It's got to be FM...But they could be layered.
Wally Badarou said in interviews that whenever he would record synth sounds with Level 42 as their producer, multiple synths would be layered with one another; the attack of one sound would be layered with the reverb of another.
That clav playing is actually characteristic of Badarou's style, so it's safe to assume he played the clav line himself. Ditto for the occasional lead synth sounds. Lindup played the Rhodes and the polysynth sounds.
Also, the same (or at least very similar) clav sound also appears in their song "Lessons In Love" (and also in their song "To Be With You Again"), both from their 1987 Running In The Family album.
Posted: Thu Feb 17, 2011 11:42 am
by iProg
It's a FM clav sound played on the DX-7 via the TX-816 rack. No P5.
Posted: Thu Feb 17, 2011 4:36 pm
by Lucien
I wouldn't believe it until I was able to reproduce the sound. I think it might be possible to do this on DX/TX but you need to reproduce the waveforms that are used to modulate (it's using poly-mod using 2 waveforms on 2 waveforms).
If you have Pro-53 or a Prophet 5 go to the ArpegKotoish preset which uses cross modulation.
Here is a recording without effects and it's pretty close especialy the attack phase:
Posted: Thu Feb 17, 2011 4:49 pm
by Lucien
elsongs wrote:...Also, the same (or at least very similar) clav sound also appears in their song "Lessons In Love" (and also in their song "To Be With You Again"), both from their 1987 Running In The Family album.
I checked clavi sound on Lessons in love and that's DX7 but it sounds different. It doesn't have the metallic characteristics. The clavi sound on "To be with you again" sounds layered and more like a harpsichord.
Check the live Wembley concert: check the TX816 lights: they don't light up when sequence is playing for something about you. They do light up later in the song after the bridge. So sound had to come from emulator (since he used dx7/ppg/prophet 5 for other sounds). So why go all the trouble and not use the TX816?
Posted: Thu Feb 17, 2011 10:29 pm
by bigman2005
Are we talking about the 12" version, or the single version that was played on the radio?
Posted: Thu Feb 17, 2011 11:11 pm
by bigman2005
From the Level 42 digest website, the following synths were used for the World Machine album where "Something About You" came from.
