Studio Workhorse: the 2011 thread
- Junior Member
- Gear: Too much (not enough).
- madtheory
- Real name: Tomas Mulcahy
Re: Studio Workhorse: the 2011 thread
Pro Tools, Kontakt, Kontakt, Kontakt, Lexicon, V Synth. I find myself using XPand for a lot of things too...
- el pr0n
- Real name: Rory
- Gear: Roland SH-32, Ableton Live, Pure Data, Telecaster, Jazzmaster.
- Band: Peaks
If I need to beat out an arrangement or sort out what's going on with a whole track, Impulse an Analog in Ableton. If I'm trying to sort out one synth part, Roland SH-32.
"Music must be listened to; it is not enough to hear it. A duck hears also." - Igor Stravinsky
If you like tunes;
Peaks on SoundCloud | Peaks on Facebook | Peaks on YouTube | Peaks on MySpace
If you like tunes;
- silikon
- Real name: Ms. Jackson
- Gear: Random bullshit with knobs and buttons.
- Band: Year with no summer
Depends on the task...
Drums: Maschine or Battery
Mono/Bass/Noise: Moog Voyager
Pads/Atmosphere/Chords: Andromeda and Kontakt
...but that's right now... I find that definition changes with whatever I'm working on at the moment. A bit of ADD I have, perhaps. Choices for effects are largely plugin (for now) and extremely random.
echo 1 > /dev/awesome
- meatballfulton
- Moderator
- Gear: Logic Pro X
Motif XF6...gigging keyboard, master keyboard, DAW controller.
As I said in the other thread. I'm using my roland xp50 as my head synth, just because I like the sequencer.
- Phollop Willing PA
- Senior Member
- Gear: Korg, Moog, Roland, Alesis, ARP, Yamaha, Future Retro
My KORG PROPHECY is the master controller coupled with a ROLAND MC 505 GROOVEBOX into a ROLAND MC 50 sequencer which spreads out to a KORG MS2000R, an EMU ULTRA PROTEUS, a MOOG VOYAGER and a ROLAND JP8000 which acts a submaster controller going into a YAMAHA QX7 sequencer, KORG SDD DIGITAL DELAY SD 40000, KENTON PRO MK 2 MIDI to CV parrallel to a FUTURE RETRO ORB sequencer which are connected to a MACBETH M5 and the ORB MIDI thru goes to an ALESIS SR 18 drum machine.
It's basically two setups that interconnect.
My studio recorder is a KORG D3200 with a KAOS PAD2 and a ROLAND RE 20 space echo.
I used to have a KORG KARMA which acted as master controller but I got rid of it because it sounded too good. In other words, the presets were distracting and no matter what I did, I couldn't really avoid feeling that I was manipulating someone else's work. I needed to get back to some sort of basics.
- No Longer Registered
Writing new stuff I take 1 of 3 regulars to start something off
Yamaha SG / Radias / Korg ESmk2
- Neonlights84
- Gear: Moog Minimoog Model D
Behringer DeepMind12
Novation UltraNova
Korg MS20 mini
Korg EMX-1 - Band: Winter's Glow
It is most certainly my Little Phatty.
Gear: Novation Ultranova, Korg Monotribe, Korg Electribe EMX-1, Electro-Harmonix Memory Boy, Lexicon MX200.
- garranimal
I'm going more and more to Andi. It's just so good at everything analog: bass, pads, weird sounds, arpeggios.
- Zamise
- Gear: Rollhand P00
- Band: Quantum-Source
Still a Yamaha RS7000 for me and don't see that changing any time soon.
- antilles
- Real name: David
- Gear: Virus C, String Melody II, Triton, MS-20, M1, Juno-60, Paraphonic 505, SH-09, VK-09, JD-800, JD-990, Pro One, CS-30, SY-1, TX81Z
- Band: Antilles
Mine is Roland JD-990 and Access Virus C. They are the first synths I turn on, when I'm in my studio.
- StepLogik
- Expert Member
- Gear: Gauntlets of Ogre Power, Vorpal Sword, Chain Mail +3, Ring of Invisibility, Staff of the Magi, Boots of Speed
Roland MV-8800 - despite several annoying quirks and some expensive diversions (Fantom-G, I'm looking at you...), this thing gets the job done when it comes to MIDI sequencing. rock solid timing. feels like using an old version of cubase on an atari - no slop, no crashes.
Yamaha AN-200 - more fun than any groovebox should be. i bought this to use mainly as a sound module since i'm big fan of the AN-1x VA engine. even after all these years, it sounds so good to my ears. but the groovebox functions of this box are a hoot and the drum samples are very good. its a great tool when inspiration is needed. if only it had more tracks...
Korg mircoStation - housey organs, housey pianos, housey strings. all that good 90's s**t from the M1 is right here
Renoise, Reaktor, Ableton Live & Korg M3.
I have a feeling I'll be spending a lot og time with my incoming iPad, though.
And hopefully I'll have some time for my other gear that's currently gathering dust. I definately should spend more time with the V-Synth & RS7000, those are both excellent machines.
- Junior Member
- Gear: Yamaha Motif ES rack/DX7//TG77/SY77/AN1X/MM08 MicrowaveXT/ Korg DW8000/M3r/ Ensoniq ESQ-1 /Mirage Rack/ Nord Micro DSI Mopho Roland Juno 106/D550
- Band: Split Second
Have quit gigging, so have brought the Motif ES rack home and put it in the mix for the first time so it's getting a lot of use..
